The SYS:Utilities/PrefsObjectsEditor tool seems to work fine - unless you run MemGuard, which reveals a hit. This is the relevant Sashimi output:
Dump of context at 0x7fd70ba0
Trap type: DSI exception
Machine State (raw): 0x2f030
Machine State (verbose): [ExtInt on] [User] [FPU on] [IAT on] [DAT on]
Instruction pointer: 0x1902ab0
Crashed process: PrefsObjectsEditor (0x56b37340)
0: 0000000d 54c11410 00000000 56b37340 00000000 01902aa0 01902aa0 020a9824
8: 5fdf95d0 02260000 554b2e60 01816cfc 42422024 58cba1fc 00000000 00000000
16: 566566c0 6f8c360c 00000000 155aa23c 58cb0000 54c118c0 02260000 00000000
24: 00000400 54c118c0 20000000 54c11448 56b37340 060e161c 00000000 81838587
CR: 48422042 XER: 00000008 CTR: 01816cfc LR: 01902aa0
ESR: 00000000
DEAR: 060e1628
mcsrr0: 0x0
csrr0: 0x0
Disassembly of crash site:
01902aa0: 7c7c1b79 mr. r28,r3
01902aa4: 41820074 beq- 0x1902B18
01902aa8: 57fd103b rlwinm. r29,r31,2,0,29
01902aac: 4182006c beq- 0x1902B18
>01902ab0: 83dd000c lwz r30,12(r29)
01902ab4: 2f9e0000 cmpwi cr7,r30,0
01902ab8: 419e0060 beq- cr7,0x1902B18
01902abc: 7fc3f378 mr r3,r30
01902ac0: 38800035 li r4,53
01902ac4: 48031125 bl 0x1933BE8
Fault caused by load operation
Registers pointing to code:
r5 : module Kickstart/dos.library.kmod at 0x01902AA0 (section 0 @ 0xC4C4)
r6 : module Kickstart/dos.library.kmod at 0x01902AA0 (section 0 @ 0xC4C4)
r7 : module Kickstart/kernel at 0x020A9824 (section 1 @ 0x49828)
r9 : module Kickstart/rtg.library at 0x02260000 (section 1 @ 0x5E4)
r11: module Kickstart/kernel at 0x01816CFC (section 0 @ 0x16D00)
r17: module PrefsObjectsEditor at 0x6F8C360C (section 5 @ 0x5F0)
r20: module golded:etc/plugins/textbar.api at 0x58CB0000 (section 0 @ 0x87C)
r22: module Kickstart/rtg.library at 0x02260000 (section 1 @ 0x5E4)
ip : module Kickstart/dos.library.kmod at 0x01902AB0 (section 0 @ 0xC4D4)
lr : module Kickstart/dos.library.kmod at 0x01902AA0 (section 0 @ 0xC4C4)
ctr: module Kickstart/kernel at 0x01816CFC (section 0 @ 0x16D00)
Stack Backtrace:
(0x54c11410) module Kickstart/dos.library.kmod at 0x01902AB0 (section 0 @ 0xC4D4)
(0x54c11430) module Kickstart/dos.library.kmod at 0x019364D4 (section 0 @ 0x3FEF8)
(0x54c11490) module Kickstart/dos.library.kmod at 0x01913EF8 (section 0 @ 0x1D91C)
(0x54c114b0) module PrefsObjectsEditor at 0x6F8C3978 (section 5 @ 0x95C)
(0x54c11d00) module Kickstart/newlib.library.kmod at 0x01A45F54 (section 0 @ 0x2098)
(0x54c11d70) module Kickstart/newlib.library.kmod at 0x01A46BFC (section 0 @ 0x2D40)
(0x54c11f10) module Kickstart/newlib.library.kmod at 0x01A46D78 (section 0 @ 0x2EBC)
(0x54c11f50) _start:_start()+0x170 (section 1 @ 0x170)
(0x54c11f90) module Kickstart/dos.library.kmod at 0x01918F3C (section 0 @ 0x22960)
(0x54c11fc0) module Kickstart/kernel at 0x0183BD20 (section 0 @ 0x3BD24)
(0x54c11fd0) module Kickstart/kernel at 0x0183BDA0 (section 0 @ 0x3BDA4)
(0x54c11fe0)
(0x0) module Kickstart/kernel at 0x021BDC56 (section 1 @ 0x15DC5A)
WARNING: Backchain pointer loops
Stack pointer (0x54c11410) is inside bounds
Redzone is OK (4)
68k register dump
Page information:
Page not found
Task 0x56b37340 (PrefsObjectsEditor) bad access @ 0x60e1628, pc = 0x191818c, lr = 0x1918150,
Task 0x56b37340 (PrefsObjectsEditor) bad access @ 0x1b3299c, pc = 0x181257c, lr = 0x1818168,
Possible PrefsObjectsEditor bug
The Rear Window blog
Re: Bug: PrefsObjectsEditor
And what did you do to achieve that output?
Every command/keystroke, please.
@tonyw
Very simple:
- I booted into Workbench.
- Executed Memguard and Sashimi.
- Opened the SYS:Utilities drawer and clicked on the PrefsObjectsEditor icon.
- Here comes the hit.
Very simple:
Re: Possible PrefsObjectsEditor bug
So, has anyone actually tried to run MemGuard and reproduce the hit? I've recently reported MemGuard hits in SketchBlock and NetSurf - in both cases they were real (and have since been fixed by the authors) so I don't think I'm just imagining things.
@Trixie
I just tests it on my latest beta / peg2, and just dbl-click on icon even bring not memguard hit, but classic GR instead
I.e. i just run it after hard reboot and its happy crashes.
Another funny momment, that its never crashes if i run it from context menu, but crashes all the time if i run it from icon on wb. If i change in icon of prefsobjecteditor from "workbench" to "shell" , then it runs fine. So, seems something wrong with parsing of WB args or so ?
I will ask now in mailing list if anyone can reproduce, and then will make a BZ
Hidden Text - Click to Show :
@Trixie
BZ done, #8256 with your and my crashlogs
@kas1e
Thank you! Now let's hope someone actually looks at what the problem might be.
@Trixie
Fixed alreadyNow let's hope someone actually looks at what the problem might be.
Wow, that was quicker than a nun's first curry
