new u-boot ? uboot?
satiropan
new u-boot ? uboot?
Post by satiropan »
hello, I have this AmigaOne G3-SE board with u-boot version 1.1.4, 16 march 2006.
I have seen on the u-boot site, there are many other more recent versions.
the more recent one that still has the board/MAI/Amigaone folder is in the u-boot-2010.06.tar.bz2 archive.
should I upgrade my u-boot to this last one? of course I would write it on a new eprom chip and keep aside in safe the original one.
what do you think?
regards
Satiropan
PPA1200 (Poor Portable Amiga 1200): BPPC-160MB,
BVision-CGX4, HD 10GB, slim DVD R/W, Asus VW161D
display, 3COM Lan PC card, OS4.1FE
AmigaOne G3-SE 600MHz, 1GB, Radeon 9200 128DDR,
CS4281 sound card, RTL8029, SiI3114, OS 4.1.6 & OS4.1FE
http://www.oldfab.webs.com
Re: new u-boot ? uboot?
Don't try to install the U-Boot from any Internet site. The U-Boot in the A1s is a special version containing dongle code, and it can only be updated or changed by running Hyperion's U-Boot Updater.
satiropan
Post by satiropan »
tonyw wrote:Don't try to install the U-Boot from any Internet site. The U-Boot in the A1s is a special version containing dongle code, and it can only be updated or changed by running Hyperion's U-Boot Updater.
well, my plan is to write it on a spare eprom, and keep the original in safe...
Satiropan
ssolie
Post by ssolie »
satiropan wrote:what do you think?
I think we should get you an AmigaOne 500 system. ;)
satiropan
Post by satiropan »
but I would lose the enjoyment of the fight with the amigaone g3-se! instead now, apart from the 3com chip not working, it seems almost ok.
at the momento i have radeon 9200 256MB ddr, sb live! that will be soon swapped with a muse 5.1, Nec USB card, rtl3189, os4.1up6.
of course the tendency is to improve every little thingy I can.
regards
Satiropan
