Hello!
A recent issue to me is that my Competition Pro that I use with RunInUAE suddenly does not work anymore. I am not completely sure as to when it stopped working but I am sure it did work with update 4 at least (AOS 4.1).
To explain, whatever game I run, be it whdload or adf, only the fire-button is recognised, not the stick movement. I have tried two joysticks (got three) and the behaviour is the same, also the joystick works in WinUAE. So the question would be, does anyone else have this issue? I have not done anything "special" to my system, it got update 6 installed with all the updates that has been made available through AmiUpdate. I have not bothered to try any other games/emulators since E-UAE has been the program that has always worked and recently stoped doing so.
I got another issue that I should make another thread about I guess but I have already read about it elsewhere so I guess that it is somehow known. Tell me if you want a separate thread or information regarding this one (codes from AllKeys?). I have bought a new keyboard where a few keys are not recongised in AOS. They are seen by AllKeys though.
Competition Pro issues
Re: Competition Pro issues
For Competition Pro in RuninUAE.
1) Plugin the Competition pro
2) Go into AmigaInput and set the Joystick to lowleverl.library Port 1
3) Start RunInUAE and select default Joystick to Joy1 (main real Joystick)
4) Start your adf / WB3.1 etc and Rightklick in the RuninUAE-Window and set Joystick to Joy1 (same as in 3)
RunInUAE ask you "This will reset UAE - Yes/No" Select Yes
5) After Reset and reload the last Action (or Game) you should use your Joystick
6) Repeat this for every new Game or setup a .uaerc for a Game with joystick=joy1 inside .
Have fun.
Have fun.
