OWB gives screen corruption on Radeon + Mediator 4000Di
johnfante
Post by johnfante »
I have a A4000 with CSPPC and Mediator MK2Di.
In the Mediator is:
Radeon 9200 - 256MB (bought with the Mediator from Elbox)
Network (Realtek RTL 8029AS)
Empty
SB128
Besides that I have a CVPPC installed on the CSPPC for OS3.9 gaming.
The system is running fine (on the Radeon) but I sometime get massive screen corruption when I use OWB (latest version) and only OWB.
First it comes as small vertikal pink lines (couple of CM's long) in the OWB window when I move it. The lines disappear when I load a new webpage. But often after a while the whole screen corrupts (everything kind of blurs) and I have to reset to get a functioning system back.
The problems only comes when I use no 3D effects and transparent windows. When I use 3D effects the problems is not there. At least I have not noticed.
I have also another similar issue. When I for instance what to extraact a lha file and Unarc asks where It should unpack the file to I get small horizontal lines en the left of my screen. Just a couple of whites ones and they disappear at once. The same lines appear when I use the sliders on large webpages.
I am not sure if this is a hardware problem or software related. I did not have that kind of problems when I was running on the CVPPC and used my Adriana network card. Hope someone can help.
I have attached a couple of debugbufferdumps I made after it corrupted the screen.
Errordump.zip
Two dumps after the error came
(3.75 KiB) Downloaded 773 times
X5000 :-)
Re: OWB gives screen corruption
Which version of OS4 are you using? 4.1 with the latest update 6 installed?
If you do, you should have been offered an update to ATIRadeon.chip very recently. Is that update installed?
Also, when you say OWB latest version, do you mean the Reaction OWB, i.e. version 3.32, or do you mean MUI-OWB (which is only released in one version so far, 1.9)?
johnfante
Post by johnfante »
I am running 4.1 update 6 and all recent updates including ATIRadeon.chip. I tried to rollback that specifik update to see if that made the difference but the result was the same.
I am running Reaction OWB (version 3.32). Installed version 3.31 via the CD and then replaced that version with the latest.
X5000 :-)
johnfante
Post by johnfante »
Just wanted to add that I am aware that I am not using the recommended PCI card order from the FAQ,
The reason is that my network card collides with the Mediator PCI bridgecard. The capacitators are to tall and it wont fit in the buttom slot.
X5000 :-)
JohnFante wrote:I am running 4.1 update 6 and all recent updates including ATIRadeon.chip. I tried to rollback that specifik update to see if that made the difference but the result was the same.
Okay, just wanted to rule that out, as I remember there were some similar problems with earlier versions of some of the modules recently updated (although I don't remember exactly which ones).
I haven't been running Reaction OWB for quite a while, as I'm happily using MUI-OWB instead. But back when i did, I remember having concluded that 3.32 had some problems, so I reverted back to 3.31 which worked nicely. But as far as I remember, the problems were not related to graphic glitches, so ... Anyway, worth a try, maybe?
JohnFante wrote:Just wanted to add that I am aware that I am not using the recommended PCI card order from the FAQ,
I don't know much about the various PCI solutions, my only classic OS4 machine is an A1200 with BPPC and BVision.
Let's hope some of the A4k experts chime in.
johnfante
Post by johnfante »
I have tried the MUI version of OWB but I get the same problem :-( (the MUI version is way better than the REACTION version thou).
I have taken a picture of the screen corruption and made a dumpdebugbuffer
They are here:
https://dl.dropbox.com/u/139090/Error%20MUI-OWB.JPG
https://dl.dropbox.com/u/139090/mui-owb.zip
And I do not have this problem in 3.9. There the Radeon works without any issues.
X5000 :-)
JohnFante wrote:And I do not have this problem in 3.9. There the Radeon works without any issues.
Maybe you should rename the thread so it includes the words Radeon and Mediator. It might attract the attention of the people with the required knowledge.
johnfante
Post by johnfante »
Good advice. Will do. :-)
X5000 :-)
Calgor
Re: OWB gives screen corruption on Radeon + Mediator 4000Di
Post by Calgor »
Surprised no one has looked at this. You will have to give me a few days. Look at my sig for my setup, I also have CVPPC and Radeon but in Mediator A4000T. I have not noticed such a problem before. But I do remember there could previously be potential for problems when using multiple screens (i.e. Mediator and CVPPC). PM me in 3 days time if no answer.
