Hello,
I have just found a glitch that occurs after the AmiUpdate was launched (and closed), when trying to change screen mode (or GUI) settings. Even though no other windows where opened, Intuition shows it’s standard request to close all windows. So more, this request doesn’t stop system tries to change screen mode (as it happens normally). Screen blinks every few seconds and it’s not possible to ‘proceed’. The only way is to choose ‘cancel’.
This problem occurs on my Sam440ep flex 800MHz, AOS 4.1 u6 and AmiUpdate 2.7.
Best Regards,
Radov
AmiUpdate vs ScreenMode
Re: AmiUpdate vs ScreenMode
Hello.
Tryed it here on X1000 with Kickstart 53.39,Workbench 53.11, AmiUpdate 2.27
and its the same.
Tears
and its the same.
Tears
Confirmed.
There's a bugtracker for AmiUpdate on amiupdate.net, you should make an entry for it there.
