Hi to all
Few weeks a go I bought the OS 4.1 Classic to convert my A4KD's in dual Systems 3.9 - 4.1
But after long time fighting with the "new" OS I'm really frustrated....
Bassically my systems have:
- CSPPC
- UW-SCSI HDD's & DVD's
- Mediator 4000D
- Elbox FastATA MK-V
- Voodoo3 3000
- Elbox Radeon 9200 256MB
- ZoRAM
- DENEB
- Toccata
Under 3.9 BB3 I use the UW-SCSI devices to Boot & work, and the Elbox FastATA MK-V with two HDD's connected for backup purpouses. Well, OS 4.1 Classic don't boot with the FastATA MK-V Installed.....
Also under 3.9 I use my Voodoo3 for Warp3D games/apps & Radeon to HiRes Workbench at 1600x900 32 bit and more memory on the system. Well, OS 4.1 Classic don't work with two PCI boards installed. I need to take out the Radeon if I want Warp3D in both systems. But 16MB VRAM and GPU of the Voodoo3 are, of course, very poor compared with the power of the Radeon.....
I don't know, but OS 4.1 Classic appears like designed for A1200 systems..... Maybe a new Update is in developmment? Maybe a new kernel, drivers & libraries with bugs fixed?
I think, lot of people needs/wants a dual system, not only 4.1 Classic......
Thanks in advance & Best regards
Pablo
AmigaOS 4.1 Classic - Hardware issues
- tommysammy
Re: AmigaOS 4.1 Classic - Hardware issues
A dualboot System is not very hard to made
Look here
http://www.a1k.org/forum/showthread.php?t=25498
I use two pci gfx cards.
Look here
Hi tommysammy,
Thanks a lot mate, But I'm very sorry I don't understand Deutsch
Maybe you can post a little explanation here in English?
Thanks in advance.
Thanks in advance.
- tommysammy
Please buy the new AmigaFuture 91.Inside is an article about AmigaOS4.1 Classic.
I had wrote this article.
There I described exactly how it works
You can buy the englisch issue
