Poseidon/deneb problems under os4.1
mech
Post by mech »
Hello all,
I have been having troubles getting the USB to work on the A4000/mediator setup
Machine Specs:
A4000 in mediator pro tower with mediator
Cyberstorm PPC 604e/233 060/60 128MB ram
32GB compact flash for harddrive adopted to the UWSCSI via acard 7720uw
buster 11
radeon 9250 128MB,rtl8029 ethernet,deneb with latest bootloader,zoram 256MB
my deneb has to be below my zoram i noticed,the zoram is in the top most zorroslot(closest towhere the mediator connectos to the motherboard slot.
I have commented out the original os4.1 usb stuff in kicklayout_A4000 file
installed poseidon 4.4
no jumpers on deneb and using the pio usb driver
i have tried it with/without the jumper on the deneb disabling the bootrom
I tried removing all the stuff in the deneb flash
I tried adding just poseidon library 4.4 in the flash
I run trident and add the piousb driver into it all is well until i put the card online,then the grim reaper rears its ugly head.
i have attached a crash log. Hopefully someone can help me figure out whats going on here because i am at a loss.
i did some quick checks just fyi the card worked perfectly under 3.9 with no issues(and still will).All memory also shows fine under os3.9
I must be missing something under os4 thats not set right? :?
-mech-
mech
Re: Poseidon/deneb problems under os4.1
Post by mech »
appears the forum will not take my crashlog file as a upload :(
so here my ridiculously long crashlog :mrgreen:
Hidden Text - Click to Show :
Crash log for task "usbhw<DEVS:USBHardware/denebpiousb.device/0>"
Generated by GrimReaper 53.2
Crash occured in module kernel at address 0x08809740
Register dump:
0: 00000000 0907D490 25050750 0000008A 0907D4B8 00000064 3B239170 80808000
8: 090561A0 00000000 0909E994 00000008 48FF4F84 3AAF4BA8 0000000C 00000001
16: 3FFFB000 3B239174 00000000 0885A64C 52057050 00000000 091A0000 0907D4B8
24: 09000000 09000000 00000001 FFFFFFFF 0909E308 0907D5F0 FFFFFFFF 091A1E96
0: nan 2.65249e-315 0 4.5036e+15
4: 0 0.5 nan nan
8: 65536 1.67772e+07 1e+61 1e-59
12: nan nan nan 2.98406e-315
16: 1.01185e-320 1.03613e-317 6.63287e-316 1.85905e-316
20: 1.18673e-314 1.93505e-314 1.03247e-314 nan
24: nan nan nan nan
28: nan nan nan 0
FPSCR (Floating Point Status and Control Register): 0x00000000
Machine State (msr) : 0x00003072
Condition (cr) : 0x24FF4F44
Instruction Pointer (ip) : 0x08809740
Xtended Exception (xer) : 0x20000002
Count (ctr) : 0x08831744
Link (lr) : 0x0880972C
DSI Status (dsisr) : 0x40000000
Data Address (dar) : 0x00000003
680x0 emulated registers:
DATA: 00000000 00000032 3AAF4BDC 00000004 00000000 00000000 00000001 00000000
ADDR: 80100000 3B13A000 3FFAD1A4 00003110 3AE52894 3AB2E490 3B13A1EC 3AAF4BAC
FPU0: 0 0 0 0
FPU4: 0 0 0 0
Symbol info:
Instruction pointer 0x08809740 belongs to module "kernel" (HUNK/Kickstart)
Stack trace:
native kernel module kernel+0x00009740
68k Stack trace:
Address of 68k IP 0xfffffffe not found
3ad60108 - "DEVS:USBHardware/denebpiousb.device" Hunk 0000 Offset 00000100 (SegList: eb58001)
0909e308 - "Kickstart/kernel" Hunk 0001 Offset 0004e304
091a1e96 - "Kickstart/kernel" Hunk 0001 Offset 00151e92
1e963aaf - "OWB" Hunk 0005 Offset 00b38aa7 (SegList: f3445fd)
0882fd14 - "Kickstart/kernel" Hunk 0000 Offset 0002fd10
3c030000 - "CURRDIR:icudata.owb" Hunk 0006 Offset 00397ff8 (SegList: f0ba885)
08827240 - "Kickstart/kernel" Hunk 0000 Offset 0002723c
08820544 - "Kickstart/kernel" Hunk 0000 Offset 00020540
1e96091a - "OWB" Hunk 0005 Offset 00b35912 (SegList: f3445fd)
68k disassembly:
fffffff6: XXXXXXXX illegal address
fffffffa: XXXXXXXX illegal address
fffffffe: XXXXXXXX illegal address
00000002: XXXXXXXX illegal address
00000006: XXXXXXXX illegal address
System information:
CPU
Model: 604e V9.516
CPU speed: 233 MHz
FSB speed: 66 MHz
Extensions: performancemonitor
Machine
Machine name: CyberStormPPC/A4000
Memory: 125940 KB
Extensions: bus.zorro bus.pci classic.aga classic.ecs classic.ocs classic.customchips
Expansion buses
PCI/AGP
00:01.0 Vendor 0x1102 Device 0x0002
Range 0: 0000FFE0 - 00010000 (IO)
00:01.1 Vendor 0x1102 Device 0x7002
Range 0: 0000FFD8 - 0000FFE0 (IO)
00:02.0 Vendor 0x10EC Device 0x8029
Range 0: 0000FFA0 - 0000FFC0 (IO)
00:04.0 Vendor 0x1002 Device 0x5960
Range 0: 60000000 - 68000000 (PREF.MEM)
Range 1: 0000FE00 - 0000FF00 (IO)
Range 2: 68000000 - 68010000 (MEM)
00:04.1 Vendor 0x1002 Device 0x5940
Range 0: 70000000 - 78000000 (PREF.MEM)
Range 1: 68010000 - 68020000 (MEM)
Zorro
Manufacturer 0x0E3B Product 0x20
Board has memory
Zorro III
Board @ 0x40000000
Size 256 MB
Subsize auto
Manufacturer 0x089E Product 0x21
Zorro III
Board @ 0x50000000
Size 16 MB
Subsize same
Manufacturer 0x089E Product 0xA1
Zorro III
Board @ 0x60000000
Size 512 MB
Subsize same
Manufacturer 0x0E3B Product 0x10
Zorro III
Board @ 0x80000000
Size 16 MB
Subsize same
Manufacturer 0x0E3B Product 0x13
Board has ROM
Zorro II
Board @ 0x00e90000
Size 64 KB
Manufacturer 0x1212 Product 0x17
Zorro II
Board @ 0x00ea0000
Size 64 KB
Libraries
0x3ede20e8: ISO-8859-15.charset V52.1
0x3ede2068: english-british_ISO-8859-15.language V52.1
0x091a1e96: exec.library V53.16
0x3ff8e534: vilintuisup.library V0.9
0x3ff8e408: cgxvideo.library V42.1
0x3fe440e0: cybergraphics.library V43.0
0x3af7a0c0: Popasl.mui V20.197
0x3cbbff50: Scrollgroup.mui V20.225
0x3ccf1e70: expat.library V53.3
0x3c72eab8: pthreads.library V53.7
0x3c72ebb8: icudata.owb V1.5
0x3cbbfc30: fuelgauge.gadget V53.7
0x3d603f40: muipop.library V20.321
0x3cbbf9b0: wav.datatype V53.4
0x3cbbfb90: sound.datatype V53.4
0x3cbbf868: xenbar.image V20.187
0x3cbbf730: Floattext.mui V20.193
0x3cbbf5f0: Imagedisplay.mui V20.198
0x3cbbf410: Pendisplay.mui V20.189
0x3cbbf2d0: Numericbutton.mui V20.200
0x3cbbf230: muiwinborder.class V20.274
0x3cb4acfc: xpkSQSH.library V1.10 (Legacy)
0x3da6ad3c: xpkSMPL.library V1.0 (Legacy)
0x3cbc02ac: xpkSHRI.library V2.2 (Legacy)
0x3ccf4dbc: xpkRLEN.library V1.3 (Legacy)
0x3d7d19fc: xpkRAKE.library V1.7 (Legacy)
0x3ccf4b7c: xpkNUKE.library V1.7 (Legacy)
0x3d7d197c: xpkNONE.library V1.4 (Legacy)
0x3ccf5f5c: xpkMASH.library V1.98 (Legacy)
0x3d7d1ed8: xpkLZMA.library V52.2
0x3ccf5e52: xpkIMPL.library V1.0 (Legacy)
0x3ccf409c: xpkIDEA.library V1.3 (Legacy)
0x3ccf463c: xpkHUFF.library V0.64 (Legacy)
0x3d7d1cfc: xpkHFMN.library V1.36 (Legacy)
0x3d7d1bfc: xpkFRLE.library V1.0 (Legacy)
0x3ccf415c: xpkFEAL.library V1.5 (Legacy)
0x3e53763c: xpkFAST.library V1.10 (Legacy)
0x3d999eec: xpkENCO.library V1.3 (Legacy)
0x3d99988c: xpkDUKE.library V1.6 (Legacy)
0x3d9a097c: xpkDLTA.library V0.1 (Legacy)
0x3d960a1c: xpkCBR0.library V1.0 (Legacy)
0x3d8236fc: xpkBZP2.library V1.7
0x3d823674: xpkmaster.library V5.2
0x3ccf59a0: Gauge.mui V20.223
0x3ccf57c0: TextEditor.mcc V15.31
0x3ccf5720: NListtree.mcc V18.29
0x3ccf5680: NFloattext.mcc V19.58
0x3ccf5540: NListview.mcc V19.77
0x3ccf5400: NList.mcc V20.122
0x3ccf5360: BetterString.mcc V11.17
0x3ccf5220: TheButton.mcc V26.5
0x3ccf5040: TheBarVirt.mcc V26.5
0x3ccf5180: Virtgroup.mui V20.368
0x3d8e0f30: TheBar.mcc V26.5
0x3d8b5b48: amissl_v097g.library V3.7
0x3d8e0d68: amisslmaster.library V3.7
0x3d99f4ec: codesets.library V6.6
0x3d9601e2: paula.audio V4.33 (Legacy)
0x3d9a89a8: Separator.docky V53.2
0x3d620660: muirexx.library V20.281
0x3da81700: slider.gadget V53.11
0x3d60394c: muiconfig.library V20.349
0x3da815c0: getfont.gadget V53.6
0x3da81480: getfile.gadget V53.7
0x3d6031c8: clicktab.gadget V53.34
0x3da776f8: muigfx.library V20.533
0x3da812a0: checkbox.gadget V53.8
0x3da81160: arexx.class V53.3
0x3da7d3e8: muilowlevel.library V20.366
0x3da7d074: asl.library V53.38
0x3e4ee5f0: requester.class V53.16
0x3e9f9d70: space.gadget V53.4
0x3e4d3048: chooser.gadget V53.14
0x3e9f9cd0: penmap.image V53.5
0x3e9f9b90: bitmap.image V53.6
0x3e9f9c30: integer.gadget V53.9
0x3d6003e8: screenblanker.library V53.3
0x3d5fdb6c: muimaster.library V20.2309
0x3e3ed978: listbrowser.gadget V53.38
0x3e49e290: string.gadget V53.15
0x3fb3d548: popupmenu.class V53.2
0x3e49e7e8: popupmenu.library V53.5
0x3e9f99b0: scroller.gadget V53.10
0x3e63026e: rawwrap.class V4.4 (Legacy)
0x3ed8a33e: ethwrap.class V4.4 (Legacy)
0x3e9e79ee: ptp.class V4.4 (Legacy)
0x3e53672e: simplemidi.class V4.4 (Legacy)
0x3e75187e: dfu.class V4.4 (Legacy)
0x3e88de6e: bootmouse.class V4.4 (Legacy)
0x3e53627e: bootkeyboard.class V4.4 (Legacy)
0x3e88e0be: egalaxtouch.class V4.4 (Legacy)
0x3ed8a91e: dm9601eth.class V4.4 (Legacy)
0x3e9f957e: serialpl2303.class V4.4 (Legacy)
0x3e9f94de: serialcp210x.class V4.4 (Legacy)
0x3ed8ac0e: rtl8150eth.class V4.4 (Legacy)
0x3e62e71e: printer.class V4.4 (Legacy)
0x3ed8904e: pegasus.class V4.4 (Legacy)
0x3ed8962e: palmpda.class V4.4 (Legacy)
0x3ed8991e: moschipeth.class V4.4 (Legacy)
0x3e9e984e: massstorage.class V4.4 (Legacy)
0x3ebb8e8e: hub.class V4.4 (Legacy)
0x3e8abe8e: usbvideo.class V4.4 (Legacy)
0x3e75044e: usbvideo.vhi V1.4 (Legacy)
0x3e8abcae: usbaudio.class V4.4 (Legacy)
0x3ebb8d32: usbaudio.audio V4.4 (Legacy)
0x3ebd6d3e: stir4200.class V4.4 (Legacy)
0x3e9f939e: cdcacm.class V4.4 (Legacy)
0x3ffb7872: camdusbmidi.class V4.4 (Legacy)
0x3ebd6b6e: bluetooth.class V4.4 (Legacy)
0x3ed89c0e: asixeth.class V4.4 (Legacy)
0x3e9f35d4: usergroup.library V4.30
0x3ebb8720: mathieeedoubbas.library V52.1
0x3ec79490: bsdsocket.library V4.292
0x3ec6982c: textclip.library V52.2
0x3ede4d60: button.gadget V53.12
0x3ede4ea0: glyph.image V53.3
0x3ec684c0: window.class V53.34
0x3ede4c20: label.image V53.11
0x3ec66248: layout.gadget V53.17
0x3ec66320: bevel.image V53.6
0x3ede49a0: drawlist.image V53.3
0x3ede4860: png.datatype V53.4
0x3eddb654: picture.datatype V53.3
0x3ee1c768: timezone.library V53.6
0x3ee1de38: application.library V53.10
0x3ff8b93c: ft2.library V53.1
0x3fbf208c: workbench.library V53.25
0x3edd9348: emulation.library V41.446
0x3edd2ca0: Picasso96API.library V2.356
0x3eddde80: gadtools.library V53.4
0x3fffb6cc: commodities.library V53.1
0x3edf8140: datatypes.library V53.4
0x3f5ed8cc: icon.library V53.12
0x3ee3c8d8: version.library V53.2
0x3f4c6d40: iffparse.library V53.1
0x3ffb5ccc: locale.library V53.3
0x3ff7341c: diskfont.library V53.4
0x3ff8f558: petunia.library V53.3
0x3ff8f498: diskcache.library V3.30
0x3ffad1a4: dos.library V53.58
0x3ff8e8f4: usbprivate.library V53.6
0x3ff92f2c: massstorage.usbfd V53.6
0x3ff92e98: bootmouse.usbfd V53.1
0x3ff92e18: bootkeyboard.usbfd V52.3
0x3ff8e7ac: hub.usbfd V53.6
0x3ff8e60c: usbresource.library V53.6
0x3ff8a478: hunk.library V53.3
0x3ff8f354: elf.library V53.12
0x3fbea4d0: intuition.library V53.30
0x3fc36150: rtg.library V41.4340
0x3ff92a20: ATIRadeon.chip V53.20
0x3ff929a4: PCIGraphics.card V53.2
0x3ff9d530: keymap.library V53.1
0x3ffa682e: poseidon.library V4.4 (Legacy)
0x3ff9fc30: layers.library V53.5
0x3ffb4420: graphics.library V53.4
0x3ff8a044: nonvolatile.library V53.2
0x3ff9e318: newlib.library V53.10
0x3ff901ac: utility.library V53.3
0x3ff9d0a8: expansion.library V53.1
0x3e7c104e: hid.class V4.4 (Legacy)
0x3ff7391e: rexxsyslib.library V45.7 (Legacy)
Devices
0x3ae52894: denebpiousb.device V1.23 (Legacy)
0x3d961ad4: audio.device V53.2
0x3d9a6e74: ahi.device V6.6
0x3e537684: usbraw.device V4.4 (Legacy)
0x3e5374a4: usbethwrap.device V4.4 (Legacy)
0x3e750b74: dm9601eth.device V4.4 (Legacy)
0x3e750db4: serialpl2303.device V4.4 (Legacy)
0x3e750c34: serialcp210x.device V4.4 (Legacy)
0x3e750a54: rtl8150eth.device V4.4 (Legacy)
0x3e750ab4: usbparallel.device V4.4 (Legacy)
0x3e7508d4: usbpegasus.device V4.4 (Legacy)
0x3e7507b4: usbpalm.device V4.4 (Legacy)
0x3e750694: usbmoschipeth.device V4.4 (Legacy)
0x3e7502d4: usbscsi.device V4.4 (Legacy)
0x3e750214: usbstir4200.device V4.4 (Legacy)
0x3e9d7da4: usbmodem.device V4.4 (Legacy)
0x3ed959f4: usbbluetooth.device V4.4 (Legacy)
0x3e9d7e64: usbasixeth.device V4.4 (Legacy)
0x3e8ad2b8: rtl8029.device V53.2
0x3ff722f0: usbsys.device V53.6
0x3ff719b8: highway.usbhcd V1.7
0x3fffb338: console.device V53.1
0x3ff8e2f4: trackdisk.device V52.3 (Legacy)
0x3ff913f0: ramdrive.device V52.6
0x3ff9d77c: input.device V53.3
0x3ff72034: keyboard.device V52.1
0x3ff714f4: cybppc.device V53.1
0x3ff9fcd4: gameport.device V52.1
0x3ff912d0: timer.device V53.1
Tasks
ClickToFront (Waiting)
Stack: 0x3dbe4004 - 0x3dbf3ffc, pointer @ 0x3dbf3a80 (Cookie OK)
State: Process (Waiting)
usbhw<DEVS:USBHardware/denebpiousb.device/0> (Crashed)
Stack: 0x3aae5004 - 0x3aaf4ffc, pointer @ 0x0907d490 (Cookie OK)
State: Process (Crashed)
input.device (Waiting)
Stack: 0x3fc3e000 - 0x3fc4e000, pointer @ 0x3fc4df00 (Cookie OK)
State: Task (Waiting)
SFS DosList handler (Waiting)
Stack: 0x3fb27004 - 0x3fb28ffc, pointer @ 0x3fb28f20 (Cookie OK)
USB stack (Waiting)
Stack: 0x3fbae000 - 0x3fbb2000, pointer @ 0x3fbb1f20 (Cookie OK)
cybppc.device (Waiting)
Stack: 0x3fc4e000 - 0x3fc5e000, pointer @ 0x3fc5df00 (Cookie OK)
Signals: SigRec 0xe0000000, SigWait 0x00000000
page_sweep (Waiting)
Stack: 0x3fb81004 - 0x3fb88ffc, pointer @ 0x3fb88e70 (Cookie OK)
rtl8029.device.0.up (Waiting)
Stack: 0x3e71a004 - 0x3e729ffc, pointer @ 0x3e729f10 (Cookie OK)
Signals: SigRec 0xe0008000, SigWait 0x00000100
rtl8029.device.0.do (Waiting)
Stack: 0x3e6ea004 - 0x3e6f9ffc, pointer @ 0x3e6f9f20 (Cookie OK)
Signals: SigRec 0xc0008000, SigWait 0x00000100
DF0 (Waiting)
Stack: 0x3fb33004 - 0x3fb34ffc, pointer @ 0x3fb34ed0 (Cookie OK)
Signals: SigRec 0xa8000100, SigWait 0x00000000
DH0 (Waiting)
Stack: 0x3fb21004 - 0x3fb22ffc, pointer @ 0x3fb22eb0 (Cookie OK)
Signals: SigRec 0xe0000100, SigWait 0x00000000
reaper.task (Waiting)
Stack: 0x3ef6b004 - 0x3ef72ffc, pointer @ 0x3ef72ea0 (Cookie OK)
RAM (Waiting)
Stack: 0x3f493004 - 0x3f49affc, pointer @ 0x3f49aca0 (Cookie OK)
CD0 (Waiting)
Stack: 0x3fb2d004 - 0x3fb2effc, pointer @ 0x3fb2ef20 (Cookie OK)
FtpF (Waiting)
Stack: 0x3f673004 - 0x3f674ffc, pointer @ 0x3f674eb0 (Cookie OK)
MosF (Waiting)
Stack: 0x3f679004 - 0x3f67affc, pointer @ 0x3f67aeb0 (Cookie OK)
WKf (Waiting)
Stack: 0x3f66d004 - 0x3f66effc, pointer @ 0x3f66eeb0 (Cookie OK)
os4F (Waiting)
Stack: 0x3f667004 - 0x3f668ffc, pointer @ 0x3f668eb0 (Cookie OK)
os39F (Waiting)
Stack: 0x3fb39004 - 0x3fb3affc, pointer @ 0x3fb3aeb0 (Cookie OK)
pager (Ready)
Stack: 0x3eebf004 - 0x3eedeffc, pointer @ 0x3eedeee0 (Cookie OK)
State: Process (Ready)
ENV (Ready)
Stack: 0x3eea5004 - 0x3eea6ffc, pointer @ 0x3eea6da0 (Cookie OK)
Signals: SigRec 0x80000000, SigWait 0x80000100
trackdisk.device (Waiting)
Stack: 0x3fbee000 - 0x3fbf0000, pointer @ 0x3fbeff90 (Cookie OK)
Signals: SigRec 0x00000300, SigWait 0x00000000
URL (Waiting)
Stack: 0x3e948004 - 0x3e9c2ffc, pointer @ 0x3e9bfc20 (Cookie OK)
CON (Waiting)
Stack: 0x3d7c1004 - 0x3d7d0ffc, pointer @ 0x3d7d0de0 (Cookie OK)
CON (Waiting)
Stack: 0x3dad6004 - 0x3dae5ffc, pointer @ 0x3dae5de0 (Cookie OK)
CON (Waiting)
Stack: 0x3db63004 - 0x3db72ffc, pointer @ 0x3db72de0 (Cookie OK)
CON (Waiting)
Stack: 0x3ee23004 - 0x3ee32ffc, pointer @ 0x3ee32de0 (Cookie OK)
CON (Waiting)
Stack: 0x3dbbc004 - 0x3dbcbffc, pointer @ 0x3dbcbde0 (Cookie OK)
CON (Waiting)
Stack: 0x3dbf8004 - 0x3dc07ffc, pointer @ 0x3dc07de0 (Cookie OK)
CON (Waiting)
Stack: 0x3d54d004 - 0x3d55cffc, pointer @ 0x3d55cde0 (Cookie OK)
AUDIO (Waiting)
Stack: 0x3e91e004 - 0x3e92dffc, pointer @ 0x3e92dec0 (Cookie OK)
CON (Waiting)
Stack: 0x3ef87004 - 0x3ef8effc, pointer @ 0x3ef8ede0 (Cookie OK)
RAW (Waiting)
Stack: 0x3f49f004 - 0x3f4a6ffc, pointer @ 0x3f4a6de0 (Cookie OK)
CON (Waiting)
Stack: 0x3f4bb004 - 0x3f4c2ffc, pointer @ 0x3f4c2de0 (Cookie OK)
dos_nbmd_process (Waiting)
Stack: 0x3fc0a004 - 0x3fc0bffc, pointer @ 0x3fc0bf20 (Cookie OK)
dos_lock_handler (Waiting)
Stack: 0x3fc04004 - 0x3fc05ffc, pointer @ 0x3fc05f10 (Cookie OK)
console.device (Waiting)
Stack: 0x3fb89000 - 0x3fb91000, pointer @ 0x3fb90f70 (Cookie OK)
Signals: SigRec 0xf0000000, SigWait 0x00000000
RexxMaster [] (Waiting)
Stack: 0x3e839004 - 0x3e848ffc, pointer @ 0x3e848f50 (Cookie OK)
TEXTCLIP (Waiting)
Stack: 0x3e934004 - 0x3e943ffc, pointer @ 0x3e943eb0 (Cookie OK)
Workbench [Workbench] (Ready)
Stack: 0x3e381004 - 0x3e390ffc, pointer @ 0x3e390e80 (Cookie OK)
Signals: SigRec 0x80000000, SigWait 0x80000000
TextEditor.mcc clipboard server (Waiting)
Stack: 0x3cc65004 - 0x3cc74ffc, pointer @ 0x3cc74f00 (Cookie OK)
NListtree.mcc clipboard server (Waiting)
Stack: 0x3cc95004 - 0x3cca4ffc, pointer @ 0x3cca4f00 (Cookie OK)
NList.mcc clipboard server (Waiting)
Stack: 0x3ccb1004 - 0x3ccc0ffc, pointer @ 0x3ccc0f00 (Cookie OK)
BetterString.mcc clipboard server (Waiting)
Stack: 0x3cccd004 - 0x3ccdcffc, pointer @ 0x3ccdcee0 (Cookie OK)
Stack: 0x3d6a1004 - 0x3d6b0ffc, pointer @ 0x3d6b0f40 (Cookie OK)
ContextMenus Command Dispatcher [ContextMenus Command Dispatcher] (Waiting)
Stack: 0x3d92a004 - 0x3d939ffc, pointer @ 0x3d939f40 (Cookie OK)
Stack: 0x3d5e9004 - 0x3d5f8ffc, pointer @ 0x3d5f8db0 (Cookie OK)
Stack: 0x3dc55004 - 0x3dc64ffc, pointer @ 0x3dc64f00 (Cookie OK)
RinghioServer (Ready)
Stack: 0x3daf2004 - 0x3db11ffc, pointer @ 0x3db117a0 (Cookie OK)
Signals: SigRec 0xd8001000, SigWait 0x10000100
OWB [OWB] (Ready)
Stack: 0x3c093004 - 0x3c112ffc, pointer @ 0x3c10dd00 (Cookie OK)
Signals: SigRec 0x07800000, SigWait 0x00000000
AmiDock (Ready)
Stack: 0x3db7f004 - 0x3db8effc, pointer @ 0x3db8e930 (Cookie OK)
Signals: SigRec 0x00000100, SigWait 0x00000100
TCP/IP Control (Ready)
Stack: 0x3e75f004 - 0x3e76effc, pointer @ 0x3e76edc0 (Cookie OK)
Signals: SigRec 0xf8009080, SigWait 0x40000000
Poseidon Event Broadcast (Ready)
Stack: 0x3e6be004 - 0x3e6cdffc, pointer @ 0x3e6cdf50 (Cookie OK)
Signals: SigRec 0xc0001000, SigWait 0x60000100
screenblanker.library timing dispatcher (Ready)
Stack: 0x3da8e004 - 0x3da9dffc, pointer @ 0x3da9dea0 (Cookie OK)
PoPo (Poseidon Popups) (Ready)
Stack: 0x3e4dc004 - 0x3e4ebffc, pointer @ 0x3e4ebf50 (Cookie OK)
Signals: SigRec 0xfc001000, SigWait 0x40000000
ramlib (Waiting)
Stack: 0x3ee89004 - 0x3ee92ffc, pointer @ 0x3ee92f20 (Cookie OK)
Trident (Waiting)
Stack: 0x3aa99084 - 0x3aaa8fc4, pointer @ 0x3aaa8240 (Cookie OK)
Signals: SigRec 0x00000010, SigWait 0x44000000
TCP/IP Superserver [TCP/IP Superserver] (Waiting)
Stack: 0x3e77b004 - 0x3e78affc, pointer @ 0x3e78aa00 (Cookie OK)
Signals: SigRec 0xd0000080, SigWait 0x00000000
YAM (Waiting)
Stack: 0x3daa2004 - 0x3dab1ffc, pointer @ 0x3dab1700 (Cookie OK)
Signals: SigRec 0xff54b000, SigWait 0x00000080
ContextMenus [] (Waiting)
Stack: 0x3dbd0004 - 0x3dbdfffc, pointer @ 0x3dbdfc50 (Cookie OK)
Signals: SigRec 0xe0001000, SigWait 0x00000100
pthread id 1 [OWB] (Waiting)
Stack: 0x3b827004 - 0x3b8a6ffc, pointer @ 0x3b8a6e30 (Cookie OK)
Stack: 0x3e797004 - 0x3e7a6ffc, pointer @ 0x3e7a6de0 (Cookie OK)
Signals: SigRec 0xf8003000, SigWait 0x00000000
Stack: 0x3ed87000 - 0x3ed87fa0, pointer @ 0x3ed87f10 (Cookie OK)
ScreenBlankerEngine (Waiting)
Stack: 0x3d68d004 - 0x3d69cffc, pointer @ 0x3d69cbe0 (Cookie OK)
Signals: SigRec 0xd8001000, SigWait 0x00000100
« IPrefs » (Waiting)
Stack: 0x3ed47004 - 0x3ed56ffc, pointer @ 0x3ed56530 (Cookie OK)
Signals: SigRec 0x0000f000, SigWait 0x40000100
ASYNCWB (Waiting)
Stack: 0x3d57d004 - 0x3d58cffc, pointer @ 0x3d58ce70 (Cookie OK)
muigfx.library (Waiting)
Stack: 0x3d976004 - 0x3d985ffc, pointer @ 0x3d985ef0 (Cookie OK)
Signals: SigRec 0x40001000, SigWait 0x00000100
DefIcons (Waiting)
Stack: 0x3d569004 - 0x3d578ffc, pointer @ 0x3d578dc0 (Cookie OK)
RAWBInfo (Waiting)
Stack: 0x3d510004 - 0x3d51fffc, pointer @ 0x3d51fec0 (Cookie OK)
TCP/IP Log (Waiting)
Stack: 0x3e7ab004 - 0x3e7baffc, pointer @ 0x3e7baf00 (Cookie OK)
Background CLI [c:noclick] (Waiting)
Stack: 0x3e7ef04c - 0x3e7fefc4, pointer @ 0x3e7fef00 (Cookie OK)
ConClip (Waiting)
Stack: 0x3e8c2004 - 0x3e8d1ffc, pointer @ 0x3e8d1eb0 (Cookie OK)
USB stack Process (Waiting)
Stack: 0x3ea03004 - 0x3ea12ffc, pointer @ 0x3ea12ee0 (Cookie OK)
datatypes.library (Waiting)
Stack: 0x3eb3e004 - 0x3eb4dffc, pointer @ 0x3eb4df10 (Cookie OK)
DST watcher (Waiting)
Stack: 0x3ec82004 - 0x3ec91ffc, pointer @ 0x3ec91f20 (Cookie OK)
dos_signal_server (Waiting)
Stack: 0x3fc10004 - 0x3fc11ffc, pointer @ 0x3fc11f10 (Cookie OK)
Signals: SigRec 0x0000e000, SigWait 0x00000000
Picasso96 (Waiting)
Stack: 0x3ed6f004 - 0x3ed7effc, pointer @ 0x3ed7edb0 (Cookie OK)
ramlib.support (Waiting)
Stack: 0x3ee7b004 - 0x3ee84ffc, pointer @ 0x3ee84f10 (Cookie OK)
Signals: SigRec 0x80004000, SigWait 0x00000000
dos_filedir_notify (Waiting)
Stack: 0x3fb59004 - 0x3fb5cffc, pointer @ 0x3fb5cad0 (Cookie OK)
Signals: SigRec 0x40000000, SigWait 0x00000000
Sound_ObjectHandler (Waiting)
Stack: 0x3d82b004 - 0x3d83affc, pointer @ 0x3d83ae90 (Cookie OK)
Signals: SigRec 0x4000f000, SigWait 0x00000100
dos_appdir_server (Waiting)
Stack: 0x3fc16004 - 0x3fc17ffc, pointer @ 0x3fc17cc0 (Cookie OK)
idle.task (Ready)
Stack: 0x3ff89000 - 0x3ff8a000, pointer @ 0x3ff89fd0 (Cookie OK)
State: Task (Ready)
DarrenHD
Post by DarrenHD »
mech wrote:Hello all,
Machine Specs:
buster 11
-mech-
Hi mech, I can't really say I've ever seen that crash, and I have a similar setup to you. One of the developers will have to decode the crashlog for you I'm afraid.
I have a Deneb in my A4000T/Mediator, with Radeon, RTL8029, and using UW scsi as well...and it's working.
One thing you have to make sure is that there are no other hardware drivers installed - so look in devs:usbhardware and make sure that only the DenebPIO (and DMA - it's ok to leave it) drivers are present. Delete any subway, highway, or other card drivers as I have heard that can crash the machine.
Darren
mech
Post by mech »
FIXED FIXED FIXED i am a happy camper.
I found the problem,it was the swap jumper on the mediator board,i thought it was set right but i rechecked and it was not. This proves assumption is the mother of all FUps'
/me shoots self in foot :oops:
thanks for your time guys..
darren excellent tutorials,they need to be in the official faq.. i had assumed after reading the FAQ that i couldn't use my SB128! so i ordered a solo. I stumbled on your tutorials and made the sb128 work(just one issue,the SB128 doesnt show in the list of AHI prefs to set to music unit only paula modes show.i'llwork on it next.
my setup of cards in the mediator is not exactly like the faq and that may be it.
trivial stuff to fix..
thanks for the help! Its sweet to have it all working in 1600x900x32! i'm sure the deneb will take a hit without dma(i need to test a usb dongle and see what kind of cpu time it eats on transfers now)If its not bad i will ditch the slow 8029.
Mech
DarrenHD
Post by DarrenHD »
mech wrote:FIXED FIXED FIXED i am a happy camper.
Mech
Hey, glad it is working :)
For the Deneb, I didn't really notice much difference in DMA vs PIO modes...it was really hard to tell so I don't think you lose much. Using a USB ethernet adapter connected to the Deneb I can get nearly 1MB/sec transfer rate on my local network. The RTL8029 PCI card tops out about 6-750KB/sec, so using a USB adapter on the Deneb is faster, at least if you want the fastest local network. Probably doesn't matter much for Internet connections unless you have a very fast connection.
Darren
