Fedora
Fedora
Has anyone been able to install Fedora?
Has anyone been able to install Fedora and got error just before the login and found a solution?
Has anyone experienced not being able to patch linux-3.5.7 with nemo_3.5.7.patch (process never ends)
Would be nice with some advice because I can not see the solution right now :)
Thank you in advance
Re: Fedora
musa wrote: Has anyone experienced not being able to patch linux-3.5.7 with nemo_3.5.7.patch (process never ends)
Forget that ...my fail forget the < :(
