AmiUpdate 2.20 Preference Bug
Locked
HKvalhe
Post by HKvalhe »
Hi. Been a while. AmiUpdate was automatically updated to version 2.20. Everything is working just fine, except for a small bug.
There seems to be a bug when trying to open the Preference in AmiUpdate 2.20, and this message below showed up.
AmiUpdate saying it uses version 1 opening the Preference, while it should use version 2 regarding the application.library.
Also, there was 2 updates regarding a Greek and Danish language for AmiUpdate. It was not entirely succesfully installed, so they were put in the ignore list below.
2 non-successful updates ignored in the list.
I hope something can be done to address these small issues. They are not critical, but annoying...
Written by
Helge Kvalheim, Norway
ssolie
Re: AmiUpdate 2.20 Preference Bug
Post by ssolie »
AmiUpdate is a 3rd party application and you should be contacting the author.
Locked
