SYBA SD-VIA-1A5E1IR USB2 in MicroA1
amigaonefan
Post by amigaonefan »
I thought I would just start a new thread about this card and my experiences with it rather than clogging up any of the existing threads about the micro and Sirion USB.
I recently purchased a multi function PCI card for the microA1 that has 4 usb2 ports, based
on the VIA VT3104 USB2 controller and a VIA VT6421 IDE/SATA controller on one card. You can
view it here: http://www.sybausa.com/productInfo.php?iid=801
Note - I found that unless I tighten down the card with the slot connector screw, I would get
lots of lockups when I plugged in or unplugged USB devices.
To get this card to "work" with OS4.1 update 5, I do the following:
In startup-sequence I comment out the following:
;If EXISTS S:Network-Startup
; Run >NIL: <NIL: *>NIL: Execute S:Network-Startup
;EndIf
This prevents the 3com ethernet device from being loaded. As pointed out by someone else
in this group, there is a contention between the 3com therent device and the EHCI module
of Sirion....at least, that's how it looks. I guess it could also be a hardware/interrupt level issue
perhaps on the microa1/AmigaOneXE.
I turn off the intenal USB0 and USB1 ports of the micro A1 in uboot.
I then powerup the micro A1.
Yes, all the USB kickstart modules are active, even EHCI.
If I insert any USB1.1 device into any of the four ports of the multicard, I see
the popup showing it has been recognized and installed. It then becomes
accessible - printers, usb mice, even USB to serial converters are recognized
(though the usb to serial converter does not have a driver).
If I plug a 2Gig flash drive into the multicard, I get a few different possible
results as follows (note tht this flash drive works fine on the internal USB1.1 of the micro
under normal operation):
#1 Sometimes, the flash drive is recognized after about 3 to 10 seconds, during
which time the USB attachment window shows blanks for vendor, product and class,
and "locating device" underneath. Then the device is found. It is mounted and can be
used, but is VERY slow, far slower than USB1 speed. It often seems to hang up for
minutes.
Here is a usb.log from when that happens.. I have plugged in a USB mouse and a USB
printer (or serial converter) and then the flash drive is plugged in to port 3:
Hidden Text - Click to Show :
I: [07:33:30] USB stack | | ==========
I: [07:33:30] USB stack | | USB System Software Task started
I: [07:33:30] USB stack | | Starting HCDs...
W: [07:33:30] UHCI Controller Task Unit 0 | UHCI | Rear USB ports are disabled in UBoot prefs.
W: [07:33:30] UHCI Controller Task Unit 0 | UHCI | Front USB ports are disabled in UBoot prefs.
I: [07:33:30] USB stack | New Fkt | Fkt 0x6FF5FDC0 at level -1
I: [07:33:30] USB stack | New Fkt | Fkt 0x6FF5FE60 at level 0
I: [07:33:31] USB stack | New Fkt | Fkt 0x6FF5FF00 at level -1
I: [07:33:31] USB stack | New Fkt | Fkt 0x6FE1F010 at level 0
I: [07:33:31] USB stack | New Fkt | Fkt 0x6FE1F0B0 at level -1
I: [07:33:31] USB stack | New Fkt | Fkt 0x6FE1F150 at level 0
I: [07:33:31] USB stack | | ...HCDs started.
I: [07:33:31] USB Fkt Init | Init Fkt | Fkt 0x6FF5FE60 is {Vendor: 0x0000, Product: 0x0000, Class: 09.00}
I: [07:33:31] USB Fkt Init | Init Fkt | Fkt 0x6FE1F010 is {Vendor: 0x0000, Product: 0x0000, Class: 09.00}
I: [07:33:31] USB Fkt Init | Init Fkt | Fkt 0x6FE1F150 is {Vendor: 0x0000, Product: 0x0000, Class: 09.00}
I: [07:33:31] USB Fkt Init | Init Fkt | Fkt 0x6FF5FE60 initialized
I: [07:33:31] USB Fkt Init | Init Fkt | Fkt 0x6FE1F010 initialized
I: [07:33:31] USB Fkt Init | Init Fkt | Fkt 0x6FE1F150 initialized
I: [07:33:31] hub.usbfd | HUB | Hub "Rear Roothub (uhci.usbhcd/0)" has TT thinktime of 8 full speed bittimes and protocol 0
I: [07:33:31] hub.usbfd | HUB | Hub "Front Roothub (uhci.usbhcd/1)" has TT thinktime of 8 full speed bittimes and protocol 0
I: [07:33:31] hub.usbfd | HUB | Hub "Rear Roothub (ehci.usbhcd/0)" has TT thinktime of 8 full speed bittimes and protocol 0
I: [07:33:31] hub.usbfd | HUB | All ports are empty
I: [07:33:31] hub.usbfd | Sys_EndInitialAttachmentPhase | Initial USB Attachment Phase terminated
I: [07:33:31] hub.usbfd | HUB | Port 1 of hub "Rear Roothub (uhci.usbhcd/0)" disabled - port is empty.
I: [07:33:31] hub.usbfd | HUB | Port 2 of hub "Rear Roothub (uhci.usbhcd/0)" disabled - port is empty.
I: [07:33:31] hub.usbfd | HUB | Port 1 of hub "Front Roothub (uhci.usbhcd/1)" disabled - port is empty.
I: [07:33:31] hub.usbfd | HUB | Port 2 of hub "Front Roothub (uhci.usbhcd/1)" disabled - port is empty.
I: [07:33:36] USB stack Process | | USB System Software Process started.
I: [07:33:36] USB stack Process | | Reading FD descriptors...
I: [07:33:37] USB stack Process | | ...FD infos read
I: [07:33:37] USB stack Process | | Starting HCDs...
I: [07:33:37] USB stack Process | | ...HCDs started.
I: [07:33:37] USB stack Process | Sys_EndInitialAttachmentPhase | Initial USB Attachment Phase terminated
I: [07:33:37] USB stack Process | | USB stack fullbooted
I: [07:34:07] EHCI Controller Task Unit 0 | EHCI | Device at port 0 is a lowspeed device. Giving up ownership.
I: [07:34:07] hub.usbfd | HUB | Device found on port 1 of hub "Rear Roothub (uhci.usbhcd/0)".
I: [07:34:07] hub.usbfd | Hub port | Device at port 1 of hub "Rear Roothub (uhci.usbhcd/0)" is low-speed.
I: [07:34:08] USB stack | New Fkt | Fkt 0x684fe1e0 at level 1
I: [07:34:08] hub.usbfd | HUB | Device on hub port 1 successfully added.
I: [07:34:08] USB Fkt Init | Init Fkt | Fkt 0x684fe1e0 is {Vendor: 0x413C, Product: 0x3200, Class: 00.00}
I: [07:34:08] USB Fkt Init | Init Fkt | Fkt 0x684fe1e0 initialized
I: [07:34:08] hid.usbfd | HID driver | USB Interface bound
I: [07:34:14] hub.usbfd | HUB | Device found on port 2 of hub "Rear Roothub (ehci.usbhcd/0)".
I: [07:34:14] EHCI Controller Task Unit 0 | EHCI | Device at port 1 is a fullspeed device. Giving up ownership.
I: [07:34:14] hub.usbfd | HUB | Port 2 of hub "Rear Roothub (ehci.usbhcd/0)" reset timed out
W: [07:34:14] hub.usbfd | HUB | Resetting hub port 2 and trying again
I: [07:34:14] hub.usbfd | HUB | Reset request for port 2 failed (error -23)
E: [07:34:14] hub.usbfd | HUB | Resetting port 2 of hub "Rear Roothub (ehci.usbhcd/0)" failed. Device adding aborted
I: [07:34:14] hub.usbfd | HUB | Device found on port 2 of hub "Rear Roothub (uhci.usbhcd/0)".
I: [07:34:14] hub.usbfd | Hub port | Device at port 2 of hub "Rear Roothub (uhci.usbhcd/0)" is full-speed.
I: [07:34:15] USB stack | New Fkt | Fkt 0x684fe3c0 at level 1
I: [07:34:15] hub.usbfd | HUB | Device on hub port 2 successfully added.
I: [07:34:15] USB Fkt Init | Init Fkt | Fkt 0x684fe3c0 is {Vendor: 0x067B, Product: 0x2303, Class: 00.00}
I: [07:34:15] USB Fkt Init | Init Fkt | Fkt 0x684fe3c0 initialized
W: [07:34:15] USB FD fkt start | BindInterfaceDriver | No interface driver of fkt 0x684fe3c0/ifc 0x68f40ed0 {Class 255.00} has been found
W: [07:34:15] USB FD fkt start | FD launcher | Could not bind any suitable interface driver for fkt 0x684fe3c0
I: [07:34:25] hub.usbfd | HUB | Device found on port 3 of hub "Rear Roothub (ehci.usbhcd/0)".
I: [07:34:25] hub.usbfd | Hub port | Device at port 3 of hub "Rear Roothub (ehci.usbhcd/0)" is high-speed.
I: [07:34:25] USB stack | New Fkt | Fkt 0x684fe460 at level 1
I: [07:34:25] hub.usbfd | HUB | Device on hub port 3 successfully added.
I: [07:34:25] EHCI Controller Task Unit 0 | EHCI | Port 2 is not in reset state.
E: [07:34:26] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
I: [07:34:26] USB Fkt Init | Init Fkt | Fkt 0x684fe460 is {Vendor: 0x0930, Product: 0x6544, Class: 00.00}
E: [07:34:27] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:28] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:29] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
I: [07:34:29] USB Fkt Init | Init Fkt | Fkt 0x684fe460 initialized
E: [07:34:30] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:31] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:32] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:33] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
I: [07:34:33] MassStorage Device Task | Massstorage | Lun 0 has device type 0x00 (Direct access) and is removable
E: [07:34:34] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:35] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:36] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:37] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:38] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:39] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:40] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:41] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:42] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:43] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:44] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:45] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:46] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:47] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:48] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:49] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:50] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:51] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:52] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:53] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:54] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:55] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:56] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:57] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:58] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:34:59] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:00] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:01] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:02] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:03] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:04] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:05] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:06] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:07] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:08] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:09] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:10] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:11] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:12] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:13] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:14] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:15] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:16] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:17] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:18] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:19] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:20] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:21] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:22] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:23] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:24] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:25] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:26] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:27] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:28] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:29] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:30] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:31] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:32] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:33] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:34] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:35] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:36] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:37] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:38] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:39] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:40] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:41] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:42] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:43] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:44] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:45] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:46] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:47] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:48] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:49] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:50] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:51] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:52] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:53] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:54] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:55] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:56] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:57] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:58] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:35:59] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:00] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:01] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:02] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:03] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
I: [07:36:04] hub.usbfd | HUB | Detaching Function removed from hub port 3
I: [07:36:09] hub.usbfd | HUB | Device found on port 4 of hub "Rear Roothub (ehci.usbhcd/0)".
I: [07:36:09] hub.usbfd | Hub port | Device at port 4 of hub "Rear Roothub (ehci.usbhcd/0)" is high-speed.
I: [07:36:09] USB stack | New Fkt | Fkt 0x684fe460 at level 1
E: [07:36:09] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
I: [07:36:09] hub.usbfd | HUB | Device on hub port 4 successfully added.
I: [07:36:09] EHCI Controller Task Unit 0 | EHCI | Port 3 is not in reset state.
E: [07:36:10] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
I: [07:36:10] USB Fkt Init | Init Fkt | Fkt 0x684fe460 is {Vendor: 0x0930, Product: 0x6544, Class: 00.00}
E: [07:36:11] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:12] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:13] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
I: [07:36:13] USB Fkt Init | Init Fkt | Fkt 0x684fe460 initialized
E: [07:36:14] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:15] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:16] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:17] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
I: [07:36:17] MassStorage Device Task | Massstorage | Lun 0 has device type 0x00 (Direct access) and is removable
E: [07:36:18] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:19] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:20] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:21] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:22] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:23] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:24] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:25] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:26] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:27] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:28] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:29] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:30] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:31] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:32] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:33] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:34] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:35] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:36] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:37] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:38] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:39] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:40] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:41] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:43] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:45] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:47] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:49] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:51] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:53] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:55] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:36:57] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
I: [07:36:58] hub.usbfd | HUB | Detaching Function removed from hub port 4
I: [07:37:03] hub.usbfd | HUB | Device found on port 3 of hub "Rear Roothub (ehci.usbhcd/0)".
I: [07:37:03] hub.usbfd | Hub port | Device at port 3 of hub "Rear Roothub (ehci.usbhcd/0)" is high-speed.
I: [07:37:03] USB stack | New Fkt | Fkt 0x684fe460 at level 1
E: [07:37:04] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
I: [07:37:04] hub.usbfd | HUB | Device on hub port 3 successfully added.
I: [07:37:04] EHCI Controller Task Unit 0 | EHCI | Port 2 is not in reset state.
E: [07:37:05] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
I: [07:37:05] USB Fkt Init | Init Fkt | Fkt 0x684fe460 is {Vendor: 0x0930, Product: 0x6544, Class: 00.00}
E: [07:37:06] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:37:07] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
I: [07:37:07] USB Fkt Init | Init Fkt | Fkt 0x684fe460 initialized
E: [07:37:08] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:37:09] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:37:10] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:37:11] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [07:37:12] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
I: [07:37:12] MassStorage Device Task | Massstorage | Lun 0 has device type 0x00 (Direct access) and is removable
#2 Sometimes the flash drive shows the USB attachment window with all blank entries,
and "locating device" underneath, and after 30 seconds closes. The device is not found.
Here is the usb.log of when that happens:
I: [21:35:51] USB stack | | ==========
I: [21:35:51] USB stack | | USB System Software Task started
I: [21:35:51] USB stack | | Starting HCDs...
W: [21:35:51] UHCI Controller Task Unit 0 | UHCI | Rear USB ports are disabled in UBoot prefs.
W: [21:35:51] UHCI Controller Task Unit 0 | UHCI | Front USB ports are disabled in UBoot prefs.
I: [21:35:51] USB stack | New Fkt | Fkt 0x6FF5FDC0 at level -1
I: [21:35:51] USB stack | New Fkt | Fkt 0x6FF5FE60 at level 0
I: [21:35:52] USB stack | New Fkt | Fkt 0x6FF5FF00 at level -1
I: [21:35:52] USB stack | New Fkt | Fkt 0x6FE1F010 at level 0
I: [21:35:52] USB stack | New Fkt | Fkt 0x6FE1F0B0 at level -1
I: [21:35:52] USB stack | New Fkt | Fkt 0x6FE1F150 at level 0
I: [21:35:52] USB stack | | ...HCDs started.
I: [21:35:52] USB Fkt Init | Init Fkt | Fkt 0x6FF5FE60 is {Vendor: 0x0000, Product: 0x0000, Class: 09.00}
I: [21:35:52] USB Fkt Init | Init Fkt | Fkt 0x6FE1F010 is {Vendor: 0x0000, Product: 0x0000, Class: 09.00}
I: [21:35:52] USB Fkt Init | Init Fkt | Fkt 0x6FE1F150 is {Vendor: 0x0000, Product: 0x0000, Class: 09.00}
I: [21:35:52] USB Fkt Init | Init Fkt | Fkt 0x6FF5FE60 initialized
I: [21:35:52] USB Fkt Init | Init Fkt | Fkt 0x6FE1F010 initialized
I: [21:35:52] USB Fkt Init | Init Fkt | Fkt 0x6FE1F150 initialized
I: [21:35:52] hub.usbfd | HUB | Hub "Rear Roothub (uhci.usbhcd/0)" has TT thinktime of 8 full speed bittimes and protocol 0
I: [21:35:52] hub.usbfd | HUB | Hub "Front Roothub (uhci.usbhcd/1)" has TT thinktime of 8 full speed bittimes and protocol 0
I: [21:35:52] hub.usbfd | HUB | Hub "Rear Roothub (ehci.usbhcd/0)" has TT thinktime of 8 full speed bittimes and protocol 0
I: [21:35:52] hub.usbfd | HUB | All ports are empty
I: [21:35:52] hub.usbfd | Sys_EndInitialAttachmentPhase | Initial USB Attachment Phase terminated
I: [21:35:52] hub.usbfd | HUB | Port 1 of hub "Rear Roothub (uhci.usbhcd/0)" disabled - port is empty.
I: [21:35:52] hub.usbfd | HUB | Port 2 of hub "Rear Roothub (uhci.usbhcd/0)" disabled - port is empty.
I: [21:35:52] hub.usbfd | HUB | Port 1 of hub "Front Roothub (uhci.usbhcd/1)" disabled - port is empty.
I: [21:35:52] hub.usbfd | HUB | Port 2 of hub "Front Roothub (uhci.usbhcd/1)" disabled - port is empty.
I: [21:35:57] USB stack Process | | USB System Software Process started.
I: [21:35:57] USB stack Process | | Reading FD descriptors...
I: [21:35:58] USB stack Process | | ...FD infos read
I: [21:35:58] USB stack Process | | Starting HCDs...
I: [21:35:58] USB stack Process | | ...HCDs started.
I: [21:35:58] USB stack Process | Sys_EndInitialAttachmentPhase | Initial USB Attachment Phase terminated
I: [21:35:58] USB stack Process | | USB stack fullbooted
I: [21:36:17] EHCI Controller Task Unit 0 | EHCI | Device at port 3 is a lowspeed device. Giving up ownership.
I: [21:36:17] hub.usbfd | HUB | Device found on port 2 of hub "Front Roothub (uhci.usbhcd/1)".
I: [21:36:18] hub.usbfd | Hub port | Device at port 2 of hub "Front Roothub (uhci.usbhcd/1)" is low-speed.
I: [21:36:18] USB stack | New Fkt | Fkt 0x687751e0 at level 1
I: [21:36:18] hub.usbfd | HUB | Device on hub port 2 successfully added.
I: [21:36:18] USB Fkt Init | Init Fkt | Fkt 0x687751e0 is {Vendor: 0x413C, Product: 0x3200, Class: 00.00}
I: [21:36:18] USB Fkt Init | Init Fkt | Fkt 0x687751e0 initialized
I: [21:36:18] hid.usbfd | HID driver | USB Interface bound
I: [21:36:31] hub.usbfd | HUB | Device found on port 3 of hub "Rear Roothub (ehci.usbhcd/0)".
I: [21:36:32] hub.usbfd | Hub port | Device at port 3 of hub "Rear Roothub (ehci.usbhcd/0)" is high-speed.
I: [21:36:32] USB stack | New Fkt | Fkt 0x687753c0 at level 1
I: [21:36:34] hub.usbfd | HUB | Device on hub port 3 successfully added.
I: [21:36:34] EHCI Controller Task Unit 0 | EHCI | Port 2 is not in reset state.
I: [21:36:52] hub.usbfd | HUB | Detaching Function removed from hub port 3
E: [21:36:52] USB Fkt Init | Init Fkt | Error -11 reading DevDsc
E: [21:36:52] USB Fkt Init | Init Fkt | Init failed.
E: [21:36:52] USB Fkt Init | SysFkt_Detach | Not called from USB Task - please notify graff@amigausb.dk
E: [21:36:54] USB Fkt Init | Init Fkt Setup | Fkt attachment failed
I: [21:37:03] hub.usbfd | HUB | Device found on port 2 of hub "Rear Roothub (ehci.usbhcd/0)".
I: [21:37:03] hub.usbfd | Hub port | Device at port 2 of hub "Rear Roothub (ehci.usbhcd/0)" is high-speed.
I: [21:37:03] USB stack | New Fkt | Fkt 0x687753c0 at level 1
I: [21:37:06] hub.usbfd | HUB | Device on hub port 2 successfully added.
I: [21:37:06] EHCI Controller Task Unit 0 | EHCI | Port 1 is not in reset state.
E: [21:37:36] USB Fkt Init | Init Fkt | Error -35 querying DevDsc three times
E: [21:37:36] USB Fkt Init | Init Fkt | Init failed.
E: [21:37:36] USB Fkt Init | SysFkt_Detach | Not called from USB Task - please notify graff@amigausb.dk
E: [21:37:38] USB Fkt Init | Init Fkt Setup | Fkt attachment failed
I: [21:38:11] hub.usbfd | HUB | Device found on port 3 of hub "Rear Roothub (ehci.usbhcd/0)".
I: [21:38:12] EHCI Controller Task Unit 0 | EHCI | Device at port 2 is a fullspeed device. Giving up ownership.
I: [21:38:12] hub.usbfd | HUB | Port 3 of hub "Rear Roothub (ehci.usbhcd/0)" reset timed out
W: [21:38:12] hub.usbfd | HUB | Resetting hub port 3 and trying again
I: [21:38:12] hub.usbfd | HUB | Reset request for port 3 failed (error -23)
E: [21:38:12] hub.usbfd | HUB | Resetting port 3 of hub "Rear Roothub (ehci.usbhcd/0)" failed. Device adding aborted
I: [21:38:12] hub.usbfd | HUB | Device found on port 1 of hub "Front Roothub (uhci.usbhcd/1)".
I: [21:38:12] hub.usbfd | Hub port | Device at port 1 of hub "Front Roothub (uhci.usbhcd/1)" is full-speed.
I: [21:38:12] USB stack | New Fkt | Fkt 0x68775460 at level 1
I: [21:38:12] hub.usbfd | HUB | Device on hub port 1 successfully added.
I: [21:38:12] USB Fkt Init | Init Fkt | Fkt 0x68775460 is {Vendor: 0x067B, Product: 0x2303, Class: 00.00}
I: [21:38:12] USB Fkt Init | Init Fkt | Fkt 0x68775460 initialized
W: [21:38:12] USB FD fkt start | BindInterfaceDriver | No interface driver of fkt 0x68775460/ifc 0x68778d10 {Class 255.00} has been found
W: [21:38:12] USB FD fkt start | FD launcher | Could not bind any suitable interface driver for fkt 0x68775460
I: [21:40:14] hub.usbfd | HUB | Device found on port 1 of hub "Rear Roothub (ehci.usbhcd/0)".
I: [21:40:15] EHCI Controller Task Unit 0 | EHCI | Device at port 0 is a fullspeed device. Giving up ownership.
I: [21:40:15] hub.usbfd | HUB | Port 1 of hub "Rear Roothub (ehci.usbhcd/0)" reset timed out
W: [21:40:15] hub.usbfd | HUB | Resetting hub port 1 and trying again
I: [21:40:15] hub.usbfd | HUB | Reset request for port 1 failed (error -23)
E: [21:40:15] hub.usbfd | HUB | Resetting port 1 of hub "Rear Roothub (ehci.usbhcd/0)" failed. Device adding aborted
I: [21:40:15] hub.usbfd | HUB | Device found on port 1 of hub "Rear Roothub (uhci.usbhcd/0)".
I: [21:40:15] hub.usbfd | Hub port | Device at port 1 of hub "Rear Roothub (uhci.usbhcd/0)" is full-speed.
I: [21:40:15] USB stack | New Fkt | Fkt 0x68775960 at level 1
I: [21:40:15] hub.usbfd | HUB | Device on hub port 1 successfully added.
I: [21:40:15] USB Fkt Init | Init Fkt | Fkt 0x68775960 is {Vendor: 0x03F0, Product: 0x0604, Class: 00.00}
I: [21:40:15] USB Fkt Init | Init Fkt | Fkt 0x68775960 initialized
W: [21:40:15] USB FD fkt start | BindInterfaceDriver | No interface driver of fkt 0x68775960/ifc 0x685800c0 {Class 07.01} has been found
W: [21:40:15] USB FD fkt start | FD launcher | Could not bind any suitable interface driver for fkt 0x68775960
I: [21:42:54] hub.usbfd | HUB | Detaching Function removed from hub port 1
I: [21:42:54] hub.usbfd | HUB | Port 1 of hub "Rear Roothub (uhci.usbhcd/0)" disabled - port is empty.
I: [21:42:59] hub.usbfd | HUB | Detaching Function removed from hub port 2
I: [21:43:06] hub.usbfd | HUB | Device found on port 1 of hub "Rear Roothub (ehci.usbhcd/0)".
I: [21:43:06] hub.usbfd | Hub port | Device at port 1 of hub "Rear Roothub (ehci.usbhcd/0)" is high-speed.
I: [21:43:06] USB stack | New Fkt | Fkt 0x687753c0 at level 1
I: [21:43:09] hub.usbfd | HUB | Device on hub port 1 successfully added.
I: [21:43:09] EHCI Controller Task Unit 0 | EHCI | Port 0 is not in reset state.
E: [21:43:39] USB Fkt Init | Init Fkt | Error -35 querying DevDsc three times
E: [21:43:39] USB Fkt Init | Init Fkt | Init failed.
E: [21:43:39] USB Fkt Init | SysFkt_Detach | Not called from USB Task - please notify graff@(removed)
E: [21:43:41] USB Fkt Init | Init Fkt Setup | Fkt attachment failed
#3 Sometimes I see the flash device on the workbench, after about a minute, showing
usb0:NDOS - (or similar). the device is mounted but not recognized.
If I plug in an Aluratek USB DVD/rw device, which uses 2 USB ports, I get similar
results as with the USB flash card. Sometimes it is seen properly and works VERY
slowly, sometimes it is not seen at all.
Usbctrl RESTART does not help. If I do a usbctrl restart, nothing happens.
If I unplug the USB flash or USB DVD, usbctrl restart still does not fix any issues.
Whether or not any USB devices are plugged into the multicard, when I execute the
network-startup and invoke the eth3com.device, the Amigaone locks up. The
pointer no longer moves, but CTRL-AMIGA-AMIGA still works. Programs running such
as AmigaAMP lock up and the music just stays at whatever tone was playing.
Once in a great while I can run network-startup and it works just fine as long as no USB
devices are plugged into the multicard - not sure why it works one in 10 times or so.
I have tried adding to uboot the environment variable usb_ohci_orphan_checking 1
and this does not seem to help in any way. Is this an implemented function for the microA1?
The USB controller chip, the VIA VT6214L is the 4 port version of the VIA VT6212L that others
on this forum report has been found to work in some cards (in the 2 port version VT6212L).
If I comment out the kickstartlayout line:
;MODULE Kickstart/ehci.usbhcd
and reboot, then I can run the network AND the USB (as 1.1 of course) without any lockups.
If there is any way I can help debug this problem...please let me know! I would love to get this cards
USB2 ports working...and it is soooooo close! If anyone wnats me to test a new ehci kernel module with
this card, please let me know. I'm willing to sign an NDA or whatever to help out.
I have many more log files I can provide....
Thanks!
amigaonefan
Re: SYBA SD-VIA-1A5E1IR USB2 in MicroA1
....continued
Here is a listing of the pci bus scan on my micro A1 with this card plugged in:
Device #1:
Vendor: 0x10CC (Mai Logic Incorporated)
Device: 0x0660 (Articia S Host Bridge)
Class code: 0x060000
RevisionID: 0x01
Interrupt: Line 0x00, Pin 0x01
Subsystem Vendor: 0x0000
Subsystem ID: 0x0000
Resource range #0 (MEMORY, PREFETCH)
Base address: 0x00000000
Physical address: 0x00000000
Device #2:
Device: 0x0661 (Articia S PCI Bridge)
Class code: 0x060400
RevisionID: 0x00
Interrupt: Line 0xFF, Pin 0x00
Device #3:
Vendor: 0x13F6 (C-Media Electronics Inc)
Device: 0x0111 (CM8738)
Class code: 0x040100
RevisionID: 0x10
Interrupt: Line 0x0A, Pin 0x01
Subsystem Vendor: 0x13F6
Subsystem ID: 0x0111
Resource range #0 (IO)
Base address: 0x0000FF00
Physical address: 0x0000FF00
Device #4:
Vendor: 0x10B7 (3Com Corporation)
Device: 0x9200 (3c905C-TX/TX-M [Tornado])
Class code: 0x020000
RevisionID: 0x78
Interrupt: Line 0x07, Pin 0x01
Subsystem Vendor: 0x10B7
Subsystem ID: 0x1000
Base address: 0x00802000
Physical address: 0x00802000
Resource range #1 (MEMORY)
Base address: 0x88100000
Physical address: 0x88100000
Device #5:
Vendor: 0x1106 (VIA Technologies, Inc.)
Device: 0x0686 (VT82C686 [Apollo Super South])
Class code: 0x060100
RevisionID: 0x40
Interrupt: Line 0x00, Pin 0x00
Device #6:
Device: 0x0571 (VT82C586A/B/VT82C686/A/B/VT823x/A/C PIPC Bus Master IDE)
Class code: 0x01018A
RevisionID: 0x06
Resource range #4 (IO)
Base address: 0x0000CC00
Physical address: 0x0000CC00
Device #7:
Device: 0x3038 (VT82xxxxx UHCI USB 1.1 Controller)
Class code: 0x0C0300
RevisionID: 0x1A
Interrupt: Line 0x05, Pin 0x04
Subsystem Vendor: 0x0925
Subsystem ID: 0x1234
Base address: 0x00802080
Physical address: 0x00802080
Device #8:
RevisionID: 0x1A
Interrupt: Line 0x00, Pin 0x04
Base address: 0x008020A0
Physical address: 0x008020A0
Device #9:
Device: 0x3057 (VT82C686 [Apollo Super ACPI])
Class code: 0x000000
RevisionID: 0x40
Device #10:
Device: 0x3058 (VT82C686 AC97 Audio Controller)
RevisionID: 0x50
Interrupt: Line 0x0B, Pin 0x03
Base address: 0x0000DC00
Physical address: 0x0000DC00
Resource range #1 (IO)
Base address: 0x0000E000
Physical address: 0x0000E000
Resource range #2 (IO)
Base address: 0x0000E400
Physical address: 0x0000E400
Device #11:
Device: 0x3068 (AC'97 Modem Controller)
Class code: 0x078000
RevisionID: 0x30
Base address: 0x00802300
Physical address: 0x00802300
Device #12:
RevisionID: 0x61
Interrupt: Line 0x09, Pin 0x01
Subsystem Vendor: 0x1106
Subsystem ID: 0x3038
Base address: 0x00802400
Physical address: 0x00802400
Device #13:
RevisionID: 0x61
Interrupt: Line 0x0A, Pin 0x02
Base address: 0x00802420
Physical address: 0x00802420
Device #14:
Device: 0x3104 (USB 2.0)
Class code: 0x0C0320
RevisionID: 0x63
Subsystem ID: 0x3104
Resource range #0 (MEMORY)
Base address: 0x88100100
Physical address: 0x88100100
Device #15:
Device: 0x3249 (VT6421 IDE/SATA Controller)
Class code: 0x010400
RevisionID: 0x50
Subsystem ID: 0x3249
Base address: 0x00802440
Physical address: 0x00802440
Base address: 0x00802450
Physical address: 0x00802450
Base address: 0x00802460
Physical address: 0x00802460
Resource range #3 (IO)
Base address: 0x00802470
Physical address: 0x00802470
Base address: 0x00802480
Physical address: 0x00802480
Device #16:
Vendor: 0x1002 (Advanced Micro Devices )
Device: 0x5159 (RV100 QY [Radeon 7000/VE])
Class code: 0x030000
RevisionID: 0x00
Interrupt: Line 0x0B, Pin 0x01
Subsystem Vendor: 0x1002
Subsystem ID: 0x5159
Base address: 0x80000000
Physical address: 0x80000000
Base address: 0x00002000
Physical address: 0x00002000
Resource range #2 (MEMORY)
Base address: 0x88000000
Physical address: 0x88000000
Here is the detailed PCI info from OpenPCI:
OpenPciInfo v1.5 12.03.2005 by Titan
openpci.library v2.1 opened
Bus Prometheus detected
Internal Configuration Space infos
VendorID : $1002
DeviceID : $5159
ClassRevision : $03000000
PCI_REVISION_ID $00
Header Type : $00 (0=Normal/1=Bridge/2=Cardbus)
PCI_SUBSYSTEM_ID $5159
Command : $0087
I/O space PCI_COMMAND_IO
Memory space PCI_COMMAND_MEMORY
Bus mastering PCI_COMMAND_MASTER
Address/data stepping PCI_COMMAND_WAIT
PCI_LATENCY_TIMER : $00
Pci Device Slot Num : 16, Func Num : 0
Vendor : ATI 3D RAGE IIC APG
Device : RV100 Radeon 7000 / Radeon VE
VendorID : $1002
DeviceID : $5159
ClassCode: 0x030000
IRQNumber: 11
MemAddr0 : $80000000 - $8800000f 131072 kbytes
IOAddr1 : $00002000 - $00002103 260 bytes
MemAddr2 : $88000000 - $8801000f 64 kbytes
Bus Master Capable
Card PCI_STATUS
Support 66 Mhz PCI 2.1 bus
Accept fast-back to back
What's Enabled in the Card ?
VendorID : $1106
DeviceID : $3249
ClassRevision : $01040050
PCI_REVISION_ID $50
PCI_SUBSYSTEM_ID $3249
Command : $0005
PCI_LATENCY_TIMER : $80
Pci Device Slot Num : 8, Func Num : 3
Vendor : VIA Technologies Inc
Device :
VendorID : $1106
DeviceID : $3249
ClassCode: 0x010400
IRQNumber: 9
IOAddr0 : $00802440 - $00802453 20 bytes
IOAddr1 : $00802450 - $00802463 20 bytes
IOAddr2 : $00802460 - $00802473 20 bytes
IOAddr3 : $00802470 - $00802483 20 bytes
IOAddr4 : $00802480 - $008024a3 36 bytes
IOAddr5 : $00802500 - $00802603 260 bytes
Bus Master Capable
Card PCI_STATUS
Doesn't support 66 Mhz PCI 2.1 bus
VendorID : $1106
DeviceID : $3104
ClassRevision : $0c032063
PCI_REVISION_ID $63
Header Type : $80 (0=Normal/1=Bridge/2=Cardbus)
Command : $0006
Pci Device Slot Num : 8, Func Num : 2
Device : VT6202 USB 2.0 Enhanced Host Controller
VendorID : $1106
DeviceID : $3104
ClassCode: 0x0c0320
IRQNumber: 11
MemAddr0 : $88100100 - $8810020f 272 bytes
Bus Master Capable
Card PCI_STATUS
Doesn't accept fast-back to back
VendorID : $1106
DeviceID : $3038
ClassRevision : $0c030061
PCI_REVISION_ID $61
Command : $0005
Pci Device Slot Num : 8, Func Num : 1
Device : VT83C572, VT6202 USB 1.0 Controller
VendorID : $1106
DeviceID : $3038
ClassCode: 0x0c0300
IRQNumber: 10
IOAddr4 : $00802420 - $00802443 36 bytes
Bus Master Capable
Card PCI_STATUS
VendorID : $1106
DeviceID : $3038
PCI_REVISION_ID $61
Command : $0005
Pci Device Slot Num : 8, Func Num : 0
VendorID : $1106
DeviceID : $3038
ClassCode: 0x0c0300
IRQNumber: 9
IOAddr4 : $00802400 - $00802423 36 bytes
Bus Master Capable
Card PCI_STATUS
VendorID : $1106
DeviceID : $3068
ClassRevision : $07800030
PCI_REVISION_ID $30
PCI_SUBSYSTEM_ID $0000
Command : $0001
Pci Device Slot Num : 7, Func Num : 6
Device : VT82C686/686A/686B AC97 Modem controller
VendorID : $1106
DeviceID : $3068
ClassCode: 0x078000
IRQNumber: 11
IOAddr0 : $00802300 - $00802403 260 bytes
No Bus Master Capable
Card PCI_STATUS
VendorID : $1106
DeviceID : $3058
ClassRevision : $04010050
PCI_REVISION_ID $50
Command : $0001
Pci Device Slot Num : 7, Func Num : 5
Device : VT82xxxxx AC97 Audio Codec (All VIA Chipsets)
VendorID : $1106
DeviceID : $3058
ClassCode: 0x040100
IRQNumber: 11
IOAddr0 : $0000dc00 - $0000dd03 260 bytes
IOAddr1 : $0000e000 - $0000e00b 12 bytes
IOAddr2 : $0000e400 - $0000e40b 12 bytes
Card PCI_STATUS
VendorID : $1106
DeviceID : $3057
ClassRevision : $00000040
PCI_REVISION_ID $40
Command : $0000
Pci Device Slot Num : 7, Func Num : 4
Device : VT82C686A ACPI Power Management Controller
VendorID : $1106
DeviceID : $3057
ClassCode: 0x000000
IRQNumber: 0
Card PCI_STATUS
VendorID : $1106
DeviceID : $3038
ClassRevision : $0c03001a
PCI_REVISION_ID $1a
PCI_SUBSYSTEM_ID $1234
Command : $0305
SERR PCI_COMMAND_SERR
Fast-back to back writes PCI_COMMAND_FAST_BACK
PCI_LATENCY_TIMER : $1f
Pci Device Slot Num : 7, Func Num : 3
VendorID : $1106
DeviceID : $3038
ClassCode: 0x0c0300
IRQNumber: 0
IOAddr4 : $008020a0 - $008020c3 36 bytes
Bus Master Capable
Card PCI_STATUS
VendorID : $1106
DeviceID : $3038
PCI_REVISION_ID $1a
Command : $0305
Pci Device Slot Num : 7, Func Num : 2
VendorID : $1106
DeviceID : $3038
ClassCode: 0x0c0300
IRQNumber: 5
IOAddr4 : $00802080 - $008020a3 36 bytes
Bus Master Capable
Card PCI_STATUS
VendorID : $1106
DeviceID : $571
ClassRevision : $01018a06
PCI_REVISION_ID $06
Command : $0007
Pci Device Slot Num : 7, Func Num : 1
Device : VT82C596 PCI IDE Controller
VendorID : $1106
DeviceID : $571
ClassCode: 0x01018a
IRQNumber: 255
IOAddr4 : $0000cc00 - $0000cc13 20 bytes
Bus Master Capable
Card PCI_STATUS
VendorID : $1106
DeviceID : $686
ClassRevision : $06010040
PCI_REVISION_ID $40
Command : $0087
Pci Device Slot Num : 7, Func Num : 0
Device : VT82C686/686A/686B PCI-to-ISA bridge
VendorID : $1106
DeviceID : $686
ClassCode: 0x060100
IRQNumber: 0
Bus Master Capable
Card PCI_STATUS
VendorID : $10b7
DeviceID : $9200
ClassRevision : $02000078
PCI_REVISION_ID $78
PCI_SUBSYSTEM_ID $1000
Command : $0015
Use memory write and invalidate PCI_COMMAND_INVALIDATE
PCI_LATENCY_TIMER : $f8
Pci Device Slot Num : 6, Func Num : 0
Vendor : 3Com Corporation
Device : 3C905C-TX Fast EtherLink for PC Management NIC
VendorID : $10b7
DeviceID : $9200
ClassCode: 0x020000
IRQNumber: 7
IOAddr0 : $00802000 - $00802083 132 bytes
MemAddr1 : $88100000 - $8810008f 144 bytes
Bus Master Capable
Card PCI_STATUS
VendorID : $13f6
DeviceID : $111
ClassRevision : $04010010
PCI_REVISION_ID $10
PCI_SUBSYSTEM_ID $0111
Command : $0085
Pci Device Slot Num : 5, Func Num : 0
Vendor : C-Media Electronics Inc.
Device : CMI8738/PCI C3DX PCI Audio Chip&#20013;&#22269;
VendorID : $13f6
DeviceID : $111
ClassCode: 0x040100
IRQNumber: 10
IOAddr0 : $0000ff00 - $00000003 4194240 kbytes
Bus Master Capable
Card PCI_STATUS
VendorID : $10cc
DeviceID : $661
ClassRevision : $06040000
PCI_REVISION_ID $00
Header Type : $01 (0=Normal/1=Bridge/2=Cardbus)
Command : $0007
PCI_LATENCY_TIMER : $20
Pci Device Slot Num : 1, Func Num : 0
Vendor :
Device :
VendorID : $10cc
DeviceID : $661
ClassCode: 0x060400
IRQNumber: 255
Bus Master Capable
Card PCI_STATUS
VendorID : $10cc
DeviceID : $660
ClassRevision : $06000001
PCI_REVISION_ID $01
Command : $0006
Pci Device Slot Num : 0, Func Num : 0
Vendor :
Device :
VendorID : $10cc
DeviceID : $660
ClassCode: 0x060000
IRQNumber: 0
Bus Master Capable
Card PCI_STATUS
2048bytes MEM_PCI DMA Mem Allocated : 67794000
16384bytes MEM_PCI DMA Mem Allocated : 67f60000
Free Mem 2048
2040bytes MEM_NONCACHEABLE DMA Mem Allocated : 67794000
Free Mem 2040
4096bytes MEM_NONCACHEABLE DMA Mem Allocated : 67e75680
Free Mem 4096
Free Mem 16384
300000 bytes MEM_NONCACHEABLE DMA Mem Allocated : 67320000
Free Mem 300000
amigaonefan
...continued
Here is a usb.log of when the DVD player is plugged in and works, but is slow...far slower than even
USB1.1 speeds.
I: [10:35:35] USB stack | | ==========
I: [10:35:35] USB stack | | USB System Software Task started
I: [10:35:35] USB stack | | Starting HCDs...
W: [10:35:35] UHCI Controller Task Unit 0 | UHCI | Rear USB ports are disabled in UBoot prefs.
W: [10:35:35] UHCI Controller Task Unit 0 | UHCI | Front USB ports are disabled in UBoot prefs.
I: [10:35:35] USB stack | New Fkt | Fkt 0x6FF5FDC0 at level -1
I: [10:35:35] USB stack | New Fkt | Fkt 0x6FF5FE60 at level 0
I: [10:35:36] USB stack | New Fkt | Fkt 0x6FF5FF00 at level -1
I: [10:35:36] USB stack | New Fkt | Fkt 0x6FE1F010 at level 0
I: [10:35:36] USB stack | New Fkt | Fkt 0x6FE1F0B0 at level -1
I: [10:35:36] USB stack | New Fkt | Fkt 0x6FE1F150 at level 0
I: [10:35:36] USB stack | | ...HCDs started.
I: [10:35:36] USB Fkt Init | Init Fkt | Fkt 0x6FF5FE60 is {Vendor: 0x0000, Product: 0x0000, Class: 09.00}
I: [10:35:36] USB Fkt Init | Init Fkt | Fkt 0x6FE1F010 is {Vendor: 0x0000, Product: 0x0000, Class: 09.00}
I: [10:35:36] USB Fkt Init | Init Fkt | Fkt 0x6FE1F150 is {Vendor: 0x0000, Product: 0x0000, Class: 09.00}
I: [10:35:36] USB Fkt Init | Init Fkt | Fkt 0x6FF5FE60 initialized
I: [10:35:36] USB Fkt Init | Init Fkt | Fkt 0x6FE1F010 initialized
I: [10:35:36] USB Fkt Init | Init Fkt | Fkt 0x6FE1F150 initialized
I: [10:35:36] hub.usbfd | HUB | Hub "Rear Roothub (uhci.usbhcd/0)" has TT thinktime of 8 full speed bittimes and protocol 0
I: [10:35:36] hub.usbfd | HUB | Hub "Front Roothub (uhci.usbhcd/1)" has TT thinktime of 8 full speed bittimes and protocol 0
I: [10:35:36] hub.usbfd | HUB | Hub "Rear Roothub (ehci.usbhcd/0)" has TT thinktime of 8 full speed bittimes and protocol 0
I: [10:35:36] hub.usbfd | HUB | All ports are empty
I: [10:35:36] EHCI Controller Task Unit 0 | EHCI | Device at port 0 is a lowspeed device. Giving up ownership.
I: [10:35:36] hub.usbfd | HUB | Device found on port 1 of hub "Rear Roothub (uhci.usbhcd/0)".
I: [10:35:36] hub.usbfd | HUB | Port 1 of hub "Front Roothub (uhci.usbhcd/1)" disabled - port is empty.
I: [10:35:36] hub.usbfd | HUB | Port 2 of hub "Front Roothub (uhci.usbhcd/1)" disabled - port is empty.
I: [10:35:36] hub.usbfd | HUB | Device found on port 2 of hub "Rear Roothub (ehci.usbhcd/0)".
I: [10:35:36] hub.usbfd | Hub port | Device at port 1 of hub "Rear Roothub (uhci.usbhcd/0)" is low-speed.
I: [10:35:36] USB stack | New Fkt | Fkt 0x6FE1F3D0 at level 1
I: [10:35:36] hub.usbfd | HUB | Device on hub port 1 successfully added.
I: [10:35:36] hub.usbfd | HUB | Port 2 of hub "Rear Roothub (uhci.usbhcd/0)" disabled - port is empty.
I: [10:35:36] USB Fkt Init | Init Fkt | Fkt 0x6FE1F3D0 is {Vendor: 0x413C, Product: 0x3200, Class: 00.00}
I: [10:35:36] USB Fkt Init | Init Fkt | Fkt 0x6FE1F3D0 initialized
I: [10:35:36] EHCI Controller Task Unit 0 | EHCI | Device at port 1 is a fullspeed device. Giving up ownership.
I: [10:35:36] hub.usbfd | HUB | Port 2 of hub "Rear Roothub (ehci.usbhcd/0)" reset timed out
W: [10:35:36] hub.usbfd | HUB | Resetting hub port 2 and trying again
I: [10:35:36] hub.usbfd | HUB | Reset request for port 2 failed (error -23)
E: [10:35:36] hub.usbfd | HUB | Resetting port 2 of hub "Rear Roothub (ehci.usbhcd/0)" failed. Device adding aborted
I: [10:35:36] hub.usbfd | HUB | Device found on port 4 of hub "Rear Roothub (ehci.usbhcd/0)".
I: [10:35:36] hub.usbfd | HUB | Device found on port 2 of hub "Rear Roothub (uhci.usbhcd/0)".
I: [10:35:37] hub.usbfd | Hub port | Device at port 4 of hub "Rear Roothub (ehci.usbhcd/0)" is high-speed.
I: [10:35:37] USB stack | New Fkt | Fkt 0x6FE1F470 at level 1
I: [10:35:37] hub.usbfd | HUB | Device on hub port 4 successfully added.
I: [10:35:37] EHCI Controller Task Unit 0 | EHCI | Port 3 is not in reset state.
I: [10:35:37] hub.usbfd | HUB | Driver Running
I: [10:35:37] hub.usbfd | Hub port | Device at port 2 of hub "Rear Roothub (uhci.usbhcd/0)" is full-speed.
I: [10:35:37] USB stack | New Fkt | Fkt 0x6FE1F510 at level 1
I: [10:35:37] hub.usbfd | HUB | Device on hub port 2 successfully added.
I: [10:35:37] USB Fkt Init | Init Fkt | Fkt 0x6FE1F510 is {Vendor: 0x03F0, Product: 0x0604, Class: 00.00}
I: [10:35:37] USB Fkt Init | Init Fkt | Fkt 0x6FE1F510 initialized
W: [10:35:37] USB FD fkt start | BindInterfaceDriver | No interface driver of fkt 0x6FE1F510/ifc 0x6FE85E10 {Class 07.01} has been found
W: [10:35:37] USB FD fkt start | FD launcher | Could not bind any suitable interface driver for fkt 0x6FE1F510
E: [10:35:38] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
I: [10:35:38] USB Fkt Init | Init Fkt | Fkt 0x6FE1F470 is {Vendor: 0x1BCF, Product: 0x0C31, Class: 00.00}
E: [10:35:39] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:35:40] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:35:41] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
I: [10:35:41] USB Fkt Init | Init Fkt | Fkt 0x6FE1F470 initialized
E: [10:35:42] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:35:43] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:35:44] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:35:45] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
W: [10:35:45] exec.task | USB Boot point delay | Boot delay timed out before USB bus was enumerated
I: [10:35:45] exec.task | Sys_EndInitialAttachmentPhase | Forcing Initial Attachment Phase End with 1 pending FD Launches:
I: [10:35:45] exec.task | Sys_EndInitialAttachmentPhase | - Ifc 0x6FD75040
I: [10:35:45] exec.task | Sys_EndInitialAttachmentPhase | Initial USB Attachment Phase terminated
E: [10:35:46] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
I: [10:35:46] MassStorage Device Task | Massstorage | Lun 0 has device type 0x05 (CDROM) and is removable
E: [10:35:47] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:35:48] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:35:49] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:35:50] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
I: [10:35:50] USB stack Process | | USB System Software Process started.
I: [10:35:50] USB stack Process | | Reading FD descriptors...
I: [10:35:51] USB stack Process | | ...FD infos read
I: [10:35:51] USB stack Process | Rebind FD | Weak FD "bootmouse.usbfd" for Ifc 0x6FE85B50 is being preempted.
W: [10:35:51] USB FD fkt start | BindInterfaceDriver | No interface driver of fkt 0x6fe1f510/ifc 0x6fe85e10 {Class 07.01} has been found
W: [10:35:51] USB FD fkt start | FD launcher | Could not bind any suitable interface driver for fkt 0x6fe1f510
E: [10:35:51] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
I: [10:35:51] USB stack Process | | Starting HCDs...
I: [10:35:51] USB stack Process | | ...HCDs started.
I: [10:35:51] USB stack Process | Sys_EndInitialAttachmentPhase | Initial USB Attachment Phase terminated
I: [10:35:51] USB stack Process | | USB stack fullbooted
I: [10:35:51] hid.usbfd | HID driver | USB Interface bound
E: [10:35:52] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:35:53] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:35:54] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:35:56] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:35:57] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:35:58] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:35:59] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:00] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:01] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:03] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:04] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:05] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:06] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:07] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:08] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:10] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:11] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:12] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:13] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:14] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:15] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:17] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:18] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:19] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:20] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:21] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:22] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:24] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:25] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:26] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:27] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:28] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:29] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:31] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:32] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:33] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:34] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:35] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:36] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:37] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:38] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:39] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:40] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:41] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:43] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:44] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:45] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:46] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:47] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:48] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:49] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:50] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:51] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:52] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:53] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:54] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:55] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:56] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:57] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:58] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:36:59] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:00] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:01] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:02] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:03] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:04] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:05] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:06] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:07] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:08] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:09] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:10] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:11] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:12] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:13] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:14] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:15] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:16] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:17] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:18] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:19] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:20] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:21] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:22] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:23] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:24] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:25] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:26] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:27] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:28] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:29] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:30] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:31] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:32] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:33] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:34] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:35] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:36] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:37] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:38] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:39] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:40] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:41] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:42] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:43] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:44] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:45] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:46] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:47] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:48] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:49] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:50] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:51] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:52] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:53] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:54] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:55] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:56] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:57] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:58] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:37:59] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:00] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:01] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:02] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:03] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:04] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:05] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:06] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:07] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:08] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:09] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:10] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:11] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:12] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:13] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:14] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:15] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:16] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:17] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:18] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:19] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:20] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:21] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:22] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:23] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:24] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:25] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:26] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:27] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:28] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:29] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:30] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:31] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:32] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:33] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:34] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:35] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:36] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:37] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:38] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:39] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:40] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:41] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:42] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:43] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:44] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:45] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:46] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:47] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:48] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:49] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:50] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:51] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:52] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:56] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:57] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:58] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:38:59] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:39:00] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:39:01] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:39:02] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:39:04] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:39:05] EHCI Controller Task Unit 0 | EHCI | Missed interrupt for controller 0!
E: [10:39:05] hid.usbfd | HID Server | Failed to destall EndPoint 129 (Ifc 0x6FE85B50) - error -35
E: [10:39:05] hid.usbfd | HID Server | More than 20 successive errors - abandoning device.
You suffer from the same problems my "hardware fixed" XE does.
I cannot use USB2 (no matter what chip i use) unless i turn off Ethernet, onboard USB and NOT use a HD gfx card.
Sorry to be of so little help, but i have given up trying to ever be able to use USB2 on this machine
btw: The crash logs and USB logs have already been posted to similar threads...as far as i can remember it's a hardware limitation which can't be worked around (That goes for my XE)
People are dying.
How dare you!
– Greta Thunberg
amigaonefan
Post by amigaonefan »
@Raziel
Is it true then that nobody has ever gotten ANY USB2 card to work in a micro A1 with USB2 active? If this is a hardware issue, then that will certainly be the case. If not, then I'd really like to know. I may try installing Linux and see what it does with this card. Interestingly, the card came with the IDE/SATA driver modules (.o files) for various versions of linux. So perhaps I can either confirm or disprove the theory that this is an unsolvable hardware issue.
Not sure as i didn't follow the Micro branch of this issue in detail.
I think i'll leave the real Micro users to comment further :-)
People are dying.
How dare you!
– Greta Thunberg
amigaonefan
I just wonder if something as simple as changing the type for interrupt 9 from level to edge triggered might help, since this card seems to be missing interrupts.
Just a thought.....
amigaonefan
interestingly, Geri has helped me get the SATA controller working on my microA1 - in Unix (Debian Lenny), on this SYBA multi card. It is accomplished by setting a uboot variable like this:
setenv VSATA "pci write.l 00.08.03 10 00008000; pci write.l 00.08.03 14 00008020; pci write.l 00.08.03 18 00008040; pci write.l 00.08.03 1c 00008060; pci write.l 00.08.03 20 00008080; pci write.l 00.08.03 24 00008200"
saveenv
and then adding VSATA to my bootcmd to be run so it to "run VSATA; menu; run menuboot_cmd"
saveenv
This causes the SATA portion of the SYBA card to work when the Lenny SATA driver is compiled into the kernel (2.6.18 is the one I was using) and I boot into Lenny.
I have tested reading and writing to a hard drive connected to the SATA controller and it works well.
Can anyone tell me how I might go about implementing a SATA driver for Amiga OS4 to have this SATA controller work in my microA1 under OS4. Are there any working SATA drivers in kickstart for a micro A1 right now?
Is there any sort of SDK or framework for writing a new kickstart SATA driver if I wanted to do so?
The easiest way (and probably that most likely to succeed) is to take an existing driver and modify it for the new hardware. That, of course, means having access to the OS4 source repository as a developer. Without the access to the other devs (for advice) and older SW (for examples), you're pushing rocks uphill.
If you are serious about wanting to write OS4 drivers, contact Steven Solie at first.
amigaonefan
Okay, with Debian kernel 2.6.31-1 made for PPC, I have been able to get the RAID/PATA port of this Syba card working in Debian Squeeze. Unfortunately, something is not right in the SATA driver of this particular Squeeze build, so although the SATA stuff works in Lenny, it does not work in Squeeze.
I am currently changing PCI I/O using UBOOT pci write.b commands to see if I can come up with a combination of USB2 parameters that will allow the full USB2 support to work in Squeeze.
So as of now, I have gotten (although in two different builds) the Syba card SATA and the Syba card PATA I/O to work. If I get USB2 working on this card, I think it will be a great thing to add to OS4 for all micro A1 owners, since it is a single PCI card that has internal/external SATA, internal RAId/IDE and 4 external USB2 ports on one card. The ultimate micro A1 expansion!
I'll let you know if I have any success with USB2. It may be that my revision of the VIA USB chips (63) is too old to work.
