PCI to PCIe adn GFX card
javierdlr
Post by javierdlr »
Hi, just to know if is possible to use latest HD gfx cards (ATI HD4xxx 5xxx 6xxx) with AmigaONE XE, or just if there existe such gfx cards in PCI version.
Has anyone tried?
TIA
Re: PCI to PCIe adn GFX card
I have not heard of anyone trying anthing above the Radeon HD 4350 yet.
There are PCI versions of the Radeon HD4350 and 5450.
Check the motherboard compatability .
http://hdrlab.org.nz/projects/amiga-os- ... therboards
The speed may not be too good.
http://hdrlab.org.nz/benchmark/gfxbench ... Result/670
Comapre to my Sam 440ep-Flex with a PCI to PCIe Adaper when using a PCIE version of the Radeon HD4350.
http://hdrlab.org.nz/benchmark/gfxbench ... Result/533
Evillord68
Post by Evillord68 »
Yes it works. But only in a 33MHZ PCI Slot. Your Aone does not have a USB and DMA Fix. Works only without the fixes.
But, it is very very slow as compare as AGP.
javierdlr
Post by javierdlr »
THX will try to get one of those old PCI gfx or the PCI PCIe bridge and test it. Thx again
