Is/are there any dual monitor solutions for the X1000. I would not be adverse to getting an additional graphics card if that would be needed.
Thank you,
Dual Monitors? -solved
Zenzizenzizenzic
Last edited by Zenzizenzizenzic on Sat Oct 20, 2012 8:46 pm, edited 1 time in total.
Re: Dual Monitors?
Please check out the official guide @
http://www.a-eon.com/?page=download&os=amigaos
If you haven't already please register before proceeding
It's the very last download option and you might need to hit the right scroll bar to see it
Falloutboy
Re: Dual Monitors?
Hey sorry to hijack this a little bit, but nice to see another Kiwi still hanging with the Miggy crowd,
only had my X1000 for about a week.
Re: Dual Monitors?
There's still a few of us yes
Congratulations on your purchase, she's a beauty don't you think
Zenzizenzizenzic
Re: Dual Monitors?
I've got the other monitor running, but I know have some questions:
SInce I no longer had room for the PCI sound card, is there another sound card solution I can use?
The pre-boot screen is distorted. Is there a way to get that to default back to the original card rather than the PCI? ( Iassume this may be a firmware issue, if so, where can I get the firmware update?)
When I tested a 3d mode by running Quake, it worked fine, but after exiting the machine crashed and the display on the main monitor was shifted halfway through the screen. Is there a way to prevent this?
Thank you,
Thank you,
- trevordick
- A-Eon Technology
Re: Dual Monitors?
Yes, it has been discussed somewhere on this forum if you perform a search you should be able to find the details. Otherwsise check out this item in my Amiga BlogZenzizenzizenzic wrote:I've got the other monitor running, but I know have some questions: SInce I no longer had room for the PCI sound card, is there another sound card solution I can use?
http://blog.a-eon.biz/blog/?m=20120806
Trevor
I'm just Breezin'
