Searching for files with specific protection flags? (Solved)
Has anybody ever found a way to find files with specific protection flags set/reset? Either using AmigaOS commands or 3rd party tools?
Right now I need to find any read-protected files on a partition, but I could imagine other situations where you'd want to find files with other flags or combinations of flags set or reset.
Any suggestions - other than writing my own? I guess I could, but I'd rather not if some solution is out there already. :-)
Slayer
Re: Searching for files with specific protection flags?
Post by Slayer »
I think the answer could lie with the List Command but whether or not the pattern matching can be directed to protection flags is beyond my general trivia 8-) since it already covers subdirectories with its ALL flag
Perhaps List could be altered to provide this function for you :geek:
For a work around just to give you a listing you could go
List ALL > Ram:List.txt
then cd to Ram:
grep -e -----wed List.txt > Ram:List2.txt
Of course this isn't perfect since some files will be missing the e flag and others might have one or more of hspa flags set but perhaps the following grep command line can be modified to just pass the line to output if the 5th character = a -
grep -e ^....-... List.txt > Ram:List2.txt
Something like this the files you want will endup at the to of the list in the file TO.txt
list sys: lformat %A-%S%S ALL > RAM:FOO.TXT
SORT FROM RAM:FOO.TXT COLSTART 5 TO RAM:TO.TXT
Yep, thanks, both of you. I had forgotten about grep and regexps. That does help to interpret List's LFORMAT %A output.
And sorting would surely work as well.
In both cases, however, it would involve a rather large temporary file, but maybe I can get away with a pipe such as:
List ALL LFORMAT "%A %P%N" | grep -e ^....-
(Note: Not yet tested.) EDIT: Now tested, works fine (with or without the "-e").
