After the onboard Radeon M9 of my SAM440ep was broken (stripes all over the screen) i put a radeon 9250 into my pci slot. There were issues with update5 so i decided to install it again from the scratch.
My problem now is if i install Update4 USB isn't working after Kickstart-Files loaded and Bootpicture showing.
The workbench is responding on insertig/removing CD showing icon on desktop, so my guess is theres something wrong with the usb stack?
Thats things i have already tried and did not help:
- install update5 over it with boot cd
- comment EHCI-Kickstart-Module out in Kicklayout
Stuck with Update3 (SOLVED)
Re: Stuck with Update3
Grr, i found the bug! I download all updates at work on my pc and decrunch it with 7zip and 7zip don't set all file-attributes right!
After downloading all updates on my SAMiga it works perfectly!
Please delete this, shame on me!!!!!
My dear friendfingus wrote:Grr, i found the bug! I download all updates at work on my pc and decrunch it with 7zip and 7zip don't set all file-attributes right!
Helge Kvalheim, Norway
