I am having an issue with a Sam460ex freezing at 44% when copying a 4,113,508,352 byte file between JXF partitions on the same harddrive using workbench copy .
I am Running update 5 and it happens with both a Sii31512 and sii3112 PCI SATA cards.
On a Sam440ep-Flex 800mhz running update 5 the same file is copied ok using the same size JXF partitions and onboard sii3114 SATA . The SAM460ex harddrive was configured as an exact RDB copy of the Sam440ep hardrive
The original file was copied from the Sam440ep-flex to a USB harddrive then from the USB harddrive to the Sam460ex without any problem .
Sam460ex Freezes when copy large files between partitions
Re: Sam460ex Freezes when copy large files between partition
@spectre660
Welcome to the club
Have you tried the internal sata-port? I get better result with it. Doing some testing now but hopefulle in 3-4 hours i can give you more information how it went.
Welcome to the club
Thank you for that warm welcome.
I have not tried the internal port will do so when next I have to connect it for some video card tampering while freeing up or using the PCI slot .
So far I have only found the problem partition to partition on the same harddrive.
have to try some Amiga formatted USB removable storage .
Joeled wrote:@spectre660
Welcome to the clubHave you tried the internal sata-port? I get better result with it. Doing some testing now but hopefulle in 3-4 hours i can give you more information how it went.
AmigaOne 500 AOS4.1.5 with RadeonHD 6750 and latest driver.
Test1 using only internal sata with one harddisk and 2.2gb gb unpacked files.
Moving 2.2gb between two different jfx partitions worked without any problem.
Moving 2.2gb from jfx to usb worked without any problem. Moving 2.2gb from usb to jfx worked without any problem
Moving 2.2gb from jfxto nsa210(smbfs 1.74 )worked without any problem
Moving 2.2gb from nsa210(smbfs 1.74 )to jfx worked without any problem
Dvplayer with fullscreen http://os4depot.net/share/video/misc/avcodec_lib.lha
Tested two different 350mb avi files. One of them ran out of ram(crashlog)but workbench was still working. The other one freezed after a couple of hours.
Dvplayer with fullscreen(Avcodec beta) http://os4depot.net/index.php?function= ... vcodec.lha
Tested two different 350mb avi files. Both froze after a couple of hours.
Crash log for task "ramlib.support"
Hidden Text - Click to Show :
Generated by GrimReaper 53.5
Crash occured in module avcodec.library at address 0x6F92D8EC
Register dump:
0: 6F92D9C0 52E40E60 00000000 52B41750 52D5E8FE 00000072 018177B0 52D5E95C
8: 80000017 6F92D99C 8000000F 52D5E910 3F4C2EE6 00000000 0203BD28 0203BCD4
16: 0227E0B4 0227E0D0 0203BD5C 80005000 0227DF56 0203BCE8 0203BD08 00004000
24: 5FD94740 5FD65460 5FD653D0 5FD653D0 52B41750 504B0000 02169824 302E3030
0: nan 0 -2.19269e-293 4.08268e-202
4: 7.73001e-231 -1.49204e-154 28 46
8: 520 40 4.5036e+15 0.0575495
12: 2.14748e+09 4.5036e+15 1.63711e-33 2.10204e-286
16: 5.78385e-275 -3.53279e-279 1.205e-181 1.78438e-192
20: 1.05405e-285 3.38775e+271 1.09166e+208 -1.22326e-296
24: 1.91171e-298 -2.52467e-29 3.71204e-179 0.0416667
28: 0.170717 0.0833333 -0.0792832 0.25
FPSCR (Floating Point Status and Control Register): 0xA2020100
Machine State (msr) : 0x0002F030
Condition (cr) : 0x44822024
Instruction Pointer (ip) : 0x6F92D8EC
Xtended Exception (xer) : 0x20000000
Count (ctr) : 0x6F92D99C
Link (lr) : 0x6F92D9C0
DSI Status (dsisr) : 0x00000000
Data Address (dar) : 0x302E3030
680x0 emulated registers:
ADDR: 5FFB8700 A2239800 00000000 00000000 00000000 00000000 00000000 52E40CF0
FPU0: 0 0 0 0
FPU4: 0 0 0 0
Symbol info:
Instruction pointer 0x6F92D8EC belongs to module "avcodec.library" (HUNK/Kickstart)
Stack trace:
module LIBS:avcodec.library at 0x6F92D8EC (section 5 @ 0x8D0)
module LIBS:avcodec.library at 0x6F92D9C0 (section 5 @ 0x9A4)
native kernel module kernel+0x0001bfe0
native kernel module ramlib.kmod+0x00001490
native kernel module ramlib.kmod+0x00002358
native kernel module dos.library.kmod+0x0002295c
native kernel module kernel+0x0003cb78
native kernel module kernel+0x0003cbf8
PPC disassembly:
6f92d8e4: 83fc0000 lwz r31,0(r28)
6f92d8e8: 3fa0504b lis r29,20555
*6f92d8ec: 83df0000 lwz r30,0(r31)
6f92d8f0: 2f9e0000 cmpwi cr7,r30,0
6f92d8f4: 419e0070 beq- cr7,0x6F92D964
System information:
CPU
Model: AMCC PPC460EX V1.2
CPU speed: 1155 MHz
FSB speed: 231 MHz
Extensions:
Machine
Machine name: Sam460ex
Memory: 2097152 KB
Extensions: bus.pci bus.pcie
Expansion buses
PCI/AGP
00:06.0 Vendor 0x126F Device 0x0501
Range 0: 80000000 - 84000000 (MEM)
Range 1: 84000000 - 84200000 (MEM)
05:00.0 Vendor 0xACBE Device 0x0001
06:00.0 Vendor 0x1002 Device 0x6759
Range 0: A0000000 - B0000000 (PREF.MEM)
Range 2: B0000000 - B0020000 (MEM)
Range 4: 00002000 - 00002100 (IO)
06:00.1 Vendor 0x1002 Device 0xAA90
Range 0: 00000000 - 00004000 (MEM)
Libraries
0x52dd7ee8: swedish.language V52.1
0x0227df56: exec.library V53.34
0x5ff5d174: vilintuisup.library V0.9
0x5ff5d048: cgxvideo.library V42.1
0x5ff670e0: cybergraphics.library V43.0
0x4d3f1ac8: version.library V53.10
0x505c589c: codesets.library V6.14
0x5040b9e4: asyncio.library V50.3
0x52bb9eb8: dvdvcd.plugin V51.2
0x52d5e910: avcodec.library V51.52
0x5093cd50: palette.gadget V53.6
0x5057b270: texteditor.gadget V53.20
0x5093cad0: getfont.gadget V53.9
0x5093c990: getfile.gadget V53.11
0x5093c850: slider.gadget V53.12
0x509c8ac8: clicktab.gadget V53.39
0x5093c670: arexx.class V53.3
0x509c8948: radiobutton.gadget V53.9
0x5093c530: checkbox.gadget V53.9
0x50899020: requester.class V53.18
0x5093c210: space.gadget V53.6
0x52cb4458: chooser.gadget V53.18
0x5093c0d0: penmap.image V53.5
0x5093c030: bitmap.image V53.9
0x52cf4e10: integer.gadget V53.10
0x509147e4: asl.library V53.46
0x52b50268: listbrowser.gadget V53.52
0x530d19e0: string.gadget V53.16
0x52985c00: scroller.gadget V53.13
0x530b05d4: usergroup.library V4.30
0x52985700: jpeg.datatype V53.5
0x5299c368: emulation.library V53.1
0x52781ec0: bsdsocket.library V4.307
0x52be1970: mathieeedoubbas.library V52.1
0x52d5fae8: usbhidgate.library V52.2
0x52d6ecdc: textclip.library V52.2
0x52be163c: hid.usbfd V53.8
0x52cf4af0: button.gadget V53.15
0x52cf4c30: glyph.image V53.3
0x52be03a0: window.class V53.48
0x52be9ab8: popupmenu.class V53.2
0x52d74cc8: popupmenu.library V53.8
0x52cf4870: label.image V53.12
0x5fd655f8: layout.gadget V53.19
0x52be99c0: bevel.image V53.6
0x52cf45f0: drawlist.image V53.3
0x52cf4050: png.datatype V53.6
0x52be2674: picture.datatype V53.6
0x52d5008c: workbench.library V53.45
0x52d74768: timezone.library V53.6
0x52d79308: application.library V53.12
0x5ffa86cc: commodities.library V53.1
0x52dda140: datatypes.library V53.4
0x52d75390: Picasso96API.library V53.4
0x52d769f0: gadtools.library V53.4
0x52df78cc: icon.library V53.13
0x52ddb8c0: iffparse.library V53.1
0x5ffb9ccc: locale.library V53.4
0x5ff877ac: diskfont.library V53.4
0x5ff06928: petunia.library V53.4
0x5ff06868: diskcache.library V3.30
0x5fd4166c: dos.library V53.112
0x5ff5de94: usbprivate.library V53.12
0x5ff0953c: massstorage.usbfd V53.13
0x5ff5dd4c: hub.usbfd V53.8
0x5ff5dc9c: usbresource.library V53.12
0x5ff86658: hunk.library V53.4
0x5ff9ddd4: elf.library V53.18
0x5ff8a4d0: intuition.library V53.35
0x5ff44150: rtg.library V53.28
0x5ff98920: RadeonHD.chip V0.49
0x5ff988a4: PCIGraphics.card V53.4
0x5ffaa7a0: keymap.library V53.3
0x5ff9ca60: layers.library V53.7
0x5ffb8420: graphics.library V53.4
0x5ff86184: nonvolatile.library V53.5
0x5ffab2b8: newlib.library V53.19
0x5ff9e1ac: utility.library V53.3
0x5ffaa0a8: expansion.library V53.1
0x52b401fe: rexxsyslib.library V45.7 (Legacy)
Devices
0x52c1b4e8: ppc460ex_eth.device V53.3
0x5fd99538: usbdisk.device V53.13
0x5ff9ed10: usbsys.device V53.12
0x5ff86cd0: ehci.usbhcd V53.17
0x5ff86c30: ohci.usbhcd V53.19
0x5ff09034: sam460sata.device V53.15
0x5ffa8338: console.device V53.1
0x5ff9f3f0: ramdrive.device V52.6
0x5ffaa9ec: input.device V53.4
0x5ff873b4: keyboard.device V53.10
0x5ff9f2d0: timer.device V53.1
Tasks
ClickToFront (Waiting)
Stack: 0x508fb004 - 0x5090affc, pointer @ 0x5090a9f0 (Cookie OK)
State: Process (Waiting)
input.device (Waiting)
Stack: 0x5ff4c000 - 0x5ff5c000, pointer @ 0x5ff5bf00 (Cookie OK)
State: Task (Waiting)
SFS DosList handler (Waiting)
Stack: 0x5fce0004 - 0x5fce2ffc, pointer @ 0x5fce2f20 (Cookie OK)
USB stack (Waiting)
Stack: 0x5fe92000 - 0x5fe96000, pointer @ 0x5fe95f20 (Cookie OK)
EHCI Controller Task Unit 0 (Waiting)
Stack: 0x5fe29000 - 0x5fe31000, pointer @ 0x5fe30f20 (Cookie OK)
Signals: SigRec 0xbe009000, SigWait 0x00000000
OHCI Controller Task Unit 0 (Waiting)
Stack: 0x5fe49000 - 0x5fe51000, pointer @ 0x5fe50f20 (Cookie OK)
sam460sata.device - chip 0 port 0 (Waiting)
Stack: 0x5fe5d000 - 0x5fe65000, pointer @ 0x5fe64f30 (Cookie OK)
page_sweep (Waiting)
Stack: 0x5fe55004 - 0x5fe5cffc, pointer @ 0x5fe5ce80 (Cookie OK)
ppc460ex_eth Unit 0 (Waiting)
Stack: 0x50a75004 - 0x50a84ffc, pointer @ 0x50a84e20 (Cookie OK)
Signals: SigRec 0xf6003000, SigWait 0x00000000
hid.usbfd (Waiting)
Stack: 0x5285a004 - 0x52861ffc, pointer @ 0x52861e90 (Cookie OK)
Signals: SigRec 0xe0000000, SigWait 0x00000100
HID Mouse (Waiting)
Stack: 0x527de004 - 0x527edffc, pointer @ 0x527edf20 (Cookie OK)
reaper.task (Waiting)
Stack: 0x52e79004 - 0x52e80ffc, pointer @ 0x52e80ea0 (Cookie OK)
JXF:DH1/JXFileSystem 4.34 (Waiting)
Stack: 0x5fce7004 - 0x5fce9ffc, pointer @ 0x5fce9de0 (Cookie OK)
Signals: SigRec 0xc0000100, SigWait 0x20000000
RAM/ram-handler 53.3 (Waiting)
Stack: 0x52f25004 - 0x52f2cffc, pointer @ 0x52f2cc90 (Cookie OK)
JXF:DH2/JXFileSystem 4.34 (Waiting)
Stack: 0x53005004 - 0x53007ffc, pointer @ 0x53007de0 (Cookie OK)
DH0/SmartFilesystem 1.290 (Waiting)
Stack: 0x5fcd9004 - 0x5fcdbffc, pointer @ 0x5fcdbeb0 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x52866004 - 0x5286dffc, pointer @ 0x5286de90 (Cookie OK)
HID Keyboard (Waiting)
Stack: 0x5289a004 - 0x528a9ffc, pointer @ 0x528a9f00 (Cookie OK)
Signals: SigRec 0x90001000, SigWait 0x00000000
HID Consumer (Waiting)
Stack: 0x527c2004 - 0x527d1ffc, pointer @ 0x527d1f20 (Cookie OK)
dos_filedir_notify (Waiting)
Stack: 0x5fd61004 - 0x5fd64ffc, pointer @ 0x5fd64ad0 (Cookie OK)
Signals: SigRec 0x40001000, SigWait 0x80000000
hid.usbfd (Waiting)
Stack: 0x5fd81004 - 0x5fd88ffc, pointer @ 0x5fd88e90 (Cookie OK)
HID Joystick (Waiting)
Stack: 0x527fa004 - 0x52809ffc, pointer @ 0x52809f20 (Cookie OK)
Stack: 0x5280e004 - 0x5281dffc, pointer @ 0x5281df20 (Cookie OK)
pager (Waiting)
Stack: 0x52e55004 - 0x52e74ffc, pointer @ 0x52e74f00 (Cookie OK)
ENV/env-handler 53.2 (Ready)
Stack: 0x53013004 - 0x53015ffc, pointer @ 0x53015d70 (Cookie OK)
Signals: SigRec 0x80000000, SigWait 0x80000100
State: Process (Ready)
console.device (Ready)
Stack: 0x5fe6d000 - 0x5fe75000, pointer @ 0x5fe74f70 (Cookie OK)
Signals: SigRec 0xf0000000, SigWait 0x80000000
State: Task (Ready)
MassStorage Device Task (Waiting)
Stack: 0x5fd51000 - 0x5fd59000, pointer @ 0x5fd58e70 (Cookie OK)
Signals: SigRec 0xf3009000, SigWait 0x00000000
CON/con-handler 53.1 (Waiting)
Stack: 0x504cf004 - 0x504deffc, pointer @ 0x504dede0 (Cookie OK)
Signals: SigRec 0xa0000100, SigWait 0x00000000
URL/launch-handler 53.32 (Waiting)
Stack: 0x528fa004 - 0x52974ffc, pointer @ 0x5296fac0 (Cookie OK)
RANDOM/Random-Handler 52.1 (Waiting)
Stack: 0x5298a004 - 0x52999ffc, pointer @ 0x52999ef0 (Cookie OK)
Stack: 0x5083f004 - 0x5084effc, pointer @ 0x5084ede0 (Cookie OK)
Stack: 0x508cb004 - 0x508daffc, pointer @ 0x508dade0 (Cookie OK)
Stack: 0x5096c004 - 0x5097bffc, pointer @ 0x5097bde0 (Cookie OK)
Stack: 0x509ee004 - 0x509fdffc, pointer @ 0x509fdde0 (Cookie OK)
AUDIO/AHI-Handler 6.2 (Waiting)
Stack: 0x527ab004 - 0x527baffc, pointer @ 0x527baec0 (Cookie OK)
Stack: 0x52ed9004 - 0x52ee0ffc, pointer @ 0x52ee0de0 (Cookie OK)
RAW/con-handler 53.1 (Waiting)
Stack: 0x52f41004 - 0x52f48ffc, pointer @ 0x52f48de0 (Cookie OK)
Stack: 0x52f5d004 - 0x52f64ffc, pointer @ 0x52f64de0 (Cookie OK)
dos_nbmd_process (Waiting)
Stack: 0x5fd1c004 - 0x5fd1effc, pointer @ 0x5fd1ef30 (Cookie OK)
dos_lock_handler (Waiting)
Stack: 0x5fd15004 - 0x5fd17ffc, pointer @ 0x5fd17f10 (Cookie OK)
RexxMaster [] (Waiting)
Stack: 0x5273d004 - 0x5274cffc, pointer @ 0x5274cf50 (Cookie OK)
TEXTCLIP/textclip-handler 52.2 (Waiting)
Stack: 0x52832004 - 0x52841ffc, pointer @ 0x52841eb0 (Cookie OK)
compose.task (Ready)
Stack: 0x4d605000 - 0x4d60d000, pointer @ 0x4d60cf30 (Cookie OK)
Signals: SigRec 0x00000021, SigWait 0x00000020
State: Task (Ready)
Stack: 0x51538000 - 0x51540000, pointer @ 0x5153ff30 (Cookie OK)
State: Task (Ready)
Workbench [Workbench] (Ready)
Stack: 0x526d0004 - 0x526dfffc, pointer @ 0x526dfea0 (Cookie OK)
Signals: SigRec 0x80000000, SigWait 0x80000000
LimpidClock (Ready)
Stack: 0x507d1004 - 0x50801ffc, pointer @ 0x508015c0 (Cookie OK)
Signals: SigRec 0xf0001000, SigWait 0x60000000
ramlib (Waiting)
Stack: 0x52e0b004 - 0x52e23ffc, pointer @ 0x52e23f20 (Cookie OK)
Stack: 0x50706004 - 0x50715ffc, pointer @ 0x50715f40 (Cookie OK)
texteditor.gadget Clipboard Server (Waiting)
Stack: 0x5050b004 - 0x5053bffc, pointer @ 0x5053bf00 (Cookie OK)
ContextMenus Command Dispatcher [ContextMenus Command Dispatcher] (Waiting)
Stack: 0x505d1004 - 0x505e0ffc, pointer @ 0x505e0f40 (Cookie OK)
Stack: 0x50be4004 - 0x50bf3ffc, pointer @ 0x50bf3db0 (Cookie OK)
Stack: 0x50c71004 - 0x50c80ffc, pointer @ 0x50c80f00 (Cookie OK)
DvPlayer (Ready)
Stack: 0x4e66b004 - 0x4e6e5ffc, pointer @ 0x4e6e59a0 (Cookie OK)
Signals: SigRec 0x00000010, SigWait 0x10000100
RinghioServer (Ready)
Stack: 0x5085b004 - 0x5087affc, pointer @ 0x5087a370 (Cookie OK)
Signals: SigRec 0xd8001000, SigWait 0x10000100
TCP/IP Control (Ready)
Stack: 0x50722004 - 0x50731ffc, pointer @ 0x50731dc0 (Cookie OK)
Signals: SigRec 0xf8009080, SigWait 0x50000000
windowfade.task (Ready)
Stack: 0x4bdea000 - 0x4bdf2000, pointer @ 0x4bdf1fd0 (Cookie OK)
Signals: SigRec 0x00000000, SigWait 0x00000020
State: Task (Ready)
hub.usbfd (Waiting)
Stack: 0x5fdcd004 - 0x5fdd4ffc, pointer @ 0x5fdd4f00 (Cookie OK)
DVPlayer GUI (Waiting)
Stack: 0x52701004 - 0x52710ffc, pointer @ 0x52710a50 (Cookie OK)
Signals: SigRec 0xb0000000, SigWait 0x00000100
DvPlayer AsyncIO Task (Waiting)
Stack: 0x4e3c2004 - 0x4e3d1ffc, pointer @ 0x4e3d1ee0 (Cookie OK)
TCP/IP Superserver [TCP/IP Superserver] (Waiting)
Stack: 0x50736004 - 0x50745ffc, pointer @ 0x507459f0 (Cookie OK)
Signals: SigRec 0xd0000080, SigWait 0x00000000
Stack: 0x5077a004 - 0x50789ffc, pointer @ 0x50789e10 (Cookie OK)
Signals: SigRec 0xf8003000, SigWait 0x00000000
ContextMenus [] (Waiting)
Stack: 0x508e7004 - 0x508f6ffc, pointer @ 0x508f6c50 (Cookie OK)
Signals: SigRec 0xe0001000, SigWait 0x00000100
Stack: 0x52cf3000 - 0x52cf3fa0, pointer @ 0x52cf3f10 (Cookie OK)
AmiDock (Waiting)
Stack: 0x50a02004 - 0x50a11ffc, pointer @ 0x50a119b0 (Cookie OK)
Signals: SigRec 0x7f40d000, SigWait 0x00000000
ASYNCWB (Waiting)
Stack: 0x509ad004 - 0x509bcffc, pointer @ 0x509bce80 (Cookie OK)
« IPrefs » (Waiting)
Stack: 0x52d07004 - 0x52d16ffc, pointer @ 0x52d16a30 (Cookie OK)
Signals: SigRec 0x0000f000, SigWait 0x20000100
DefIcons (Waiting)
Stack: 0x50988004 - 0x50997ffc, pointer @ 0x50997dc0 (Cookie OK)
RAWBInfo (Waiting)
Stack: 0x5091b004 - 0x5092affc, pointer @ 0x5092aec0 (Cookie OK)
TCP/IP Log (Waiting)
Stack: 0x52dad004 - 0x52dbcffc, pointer @ 0x52dbcf00 (Cookie OK)
ConClip (Waiting)
Stack: 0x528de004 - 0x528edffc, pointer @ 0x528edeb0 (Cookie OK)
USB stack Process (Waiting)
Stack: 0x529b2004 - 0x529c1ffc, pointer @ 0x529c1ee0 (Cookie OK)
datatypes.library (Waiting)
Stack: 0x52b06004 - 0x52b15ffc, pointer @ 0x52b15f10 (Cookie OK)
DST watcher (Waiting)
Stack: 0x52cc3004 - 0x52cd2ffc, pointer @ 0x52cd2f20 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x5fdb1004 - 0x5fdb8ffc, pointer @ 0x5fdb8f00 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x5fdd9004 - 0x5fde0ffc, pointer @ 0x5fde0f00 (Cookie OK)
ramlib.support (Crashed)
Stack: 0x52e28004 - 0x52e40ffc, pointer @ 0x52e40e60 (Cookie OK)
Signals: SigRec 0x80005000, SigWait 0x00000000
State: Process (Crashed)
dos_signal_server (Waiting)
Stack: 0x5fd23004 - 0x5fd25ffc, pointer @ 0x5fd25e70 (Cookie OK)
Signals: SigRec 0x00000100, SigWait 0x00004000
Picasso96 (Waiting)
Stack: 0x52d3b004 - 0x52d4affc, pointer @ 0x52d4ad70 (Cookie OK)
DVPlayer Audio Subtask (Ready)
Stack: 0x4d3a4044 - 0x4d3a7040, pointer @ 0x4d3a6e10 (Cookie OK)
Signals: SigRec 0x00000010, SigWait 0x00000000
dos_appdir_server (Waiting)
Stack: 0x5fd2a004 - 0x5fd2cffc, pointer @ 0x5fd2cd40 (Cookie OK)
idle.task (Ready)
Stack: 0x5ff85000 - 0x5ff86000, pointer @ 0x5ff85fd0 (Cookie OK)
State: Task (Ready)
Register dump:
FPU0: 0 0 0 0
FPU4: 0 0 0 0
Symbol info:
Stack trace:
PPC disassembly:
System information:
CPU
CPU speed: 1155 MHz
FSB speed: 231 MHz
Extensions:
Machine
Memory: 2097152 KB
Expansion buses
PCI/AGP
Libraries
Devices
Tasks
USB stack (Waiting)
hid.usbfd (Waiting)
HID Mouse (Waiting)
hid.usbfd (Waiting)
hid.usbfd (Waiting)
pager (Waiting)
State: Task (Ready)
State: Task (Ready)
State: Task (Ready)
LimpidClock (Ready)
ramlib (Waiting)
DvPlayer (Ready)
State: Task (Ready)
hub.usbfd (Waiting)
AmiDock (Waiting)
ASYNCWB (Waiting)
DefIcons (Waiting)
RAWBInfo (Waiting)
ConClip (Waiting)
hub.usbfd (Waiting)
hub.usbfd (Waiting)
Picasso96 (Waiting)
idle.task (Ready)
State: Task (Ready)
Return to “Platform: AmigaOne 500 and Sam series”
Jump to
- General Forums
- ↳ Announcements
- ↳ Public Announcements
- ↳ Forum Questions
- AmigaOS Support
- ↳ AmigaOS Feature Requests
- ↳ General AmigaOS
- ↳ Platform: AmigaOne X5000
- ↳ Platform: AmigaOne X1000
- ↳ Platform: A1222
- ↳ Platform: Pegasos II
- ↳ Platform: AmigaOne 500 and Sam series
- ↳ Platform: AmigaOne XE and MicroA1-C
- ↳ Platform: Classic
- ↳ Localization
- AmigaOS 3.2 Support
- ↳ AmigaOS 3.1.4
- ↳ AmigaOS 3.2
- Games Support
- ↳ Heretic II
- ↳ Freespace
- ↳ Gorky 17
- ↳ Quake II
- ↳ Shogo
- Developer Support
- ↳ General Developer Support
- ↳ SDK Support
- ↳ AmigaOS Documentation Wiki
- Linux Support
- ↳ Platform: AmigaOne 500 and Sam series - Linux Only
- ↳ Platform: AmigaOne A1222 - Linux Only
- ↳ Platform: AmigaOne X1000 - Linux Only
- ↳ Platform: AmigaOne X5000 - Linux Only
