In AmigaOS 4.1 Update 4, YAM 2.7 always let Ringhio notisfy the user when new emails appeared. This doesn't seem to be the case under Update 5, despite the Settings for New Mail has this checkbox for AmigaOS4 Notificaton System TICKED. But having this active doesn't cause any effect. As for me, new emails should be checked for every 10 minutes, but Ringhio never got the message to notisfy me of new emails. Same for this friend of mine.
Instead the user has to click the Get button to check for new mails. Is it possible that YAM yet again has to be updated to be more "compatible" with Update 5? I have also thought about putting the RUN command for YAM in the Network-Startup script, if the situation is that it has problem to allocate the net during startup. I immerdiately thought of that since it has a problem to give Ringhio the message to check for new emails and notisfy the user.
This is most curious. Could the author of YAM look into this problem along with the AmigaOS4 Team? I think we all would be very grateful if this issue was solved. Other than that, YAM works as normal.
EDIT: The situation is solved, in a funny way! I just deleted old mails so it was empty, listening to music for 10 minutes, then Ringhio actually DID notisfy me of a new email! I clicked it, and VOILA! Yes, a new mail!
