Picasso IV - Overlay
Hi, use a Picasso IV GFX Card. the AOS 4.1 FAQ said that Overlay is possible but DvPlayer doesn´t work? please advise,…. Thanx Godfather
- Hans-Joerg Frieden
Re: Picasso IV - Overlay
Please,as a general rule of thumb... "doesn't work" is not an error description.Godfather wrote: doesn´t work?
Please state at the very least what happens ("doesn't open", "crashes on startup with DSI", etc). Only bug reports with a precise error description can be fixed.
Thank you.
- DarrenHD
Yes, please provide more description. I believe DV Player has an issue with Overlay, but that is DV Player and not the Picasso IV.Godfather wrote:Hi, use a Picasso IV GFX Card. the AOS 4.1 FAQ said that Overlay is possible but DvPlayer doesn´t work? please advise,…. Thanx Godfather
Try with MPlayer the overlay should work.
Dear, doesn´t work means the DvPalyer starts and the picture is black! if you drag the window sites you can see a little flickering of some colors nothing more. the effect appear in 640x480 / 800x600 / 1024x768 in Hi and True Color. Kind Regards Godfather
- DarrenHD
Please try with MPlayer from OS4Depot. I believe the problem is DVPlayer and not the Picasso IV overlay support itself.Godfather wrote:Dear, doesn´t work means the DvPalyer starts and the picture is black! if you drag the window sites you can see a little flickering of some colors nothing more. the effect appear in 640x480 / 800x600 / 1024x768 in Hi and True Color. Kind Regards Godfather
Darren
