Hi all,
Getting some shadows and window glitches when copying files with DirOpus.
The video captures it better than I can explain it.
http://www.youtube.com/watch?v=ViMGSIdb2oE
Update5 Shadows and window glitches
Re: Update5 Shadows and window glitches
It look like a driver bug, what gfx are you using and what is your Amiga model ?
@dlni
It wouldn't hurt to tell what version of DIrOpus too.
- AlfredOne
This should be a problem of rtg.library before version 53.21.ddni wrote:Hi all,
What version of rtg.library are you using?
Amiga500 Kickstart1.3
AmigaONE X1000 - 2GB RAM
- Radeon R9-280X 3GB
- Radeon HIS4670 1GB DDR3
- Radeon RX550
Hi, it is a 4850 card. The x1000 is a new system from amigakit which should be fully up to date. I am not at home to check the library versions. DOpus is also the version shipped by amigakit.
- AlfredOne
I checked my Update 5 installation and the rtg.library version is 53.28.ddni wrote:Hi, it is a 4850 card. The x1000 is a new system from amigakit which should be fully up to date. I am not at home to check the library versions. DOpus is also the version shipped by amigakit.
I don't have any kind of problem with shadows, with or without copying with DOpus.
Please, could you tell me the version of your rtg.library?
Can you check if the problem exists without running DOpus, but just resizing windows on the workbench?
- Radeon RX550
@Alfredone
Back at my X1000.
I looked for rtg.library and found it in System:Kickstart/rtg.library the version is 41.4355 (14/07/2011)
Is this the correct library or is another copy hiding in OS4 somewhere?
Back at my X1000.
No, that's the one. The X1000 version of Update 5 is not yet at the same level as the recently released version for the other (non-beta) platforms. The rtg.library is one of the differences.ddni wrote:@Alfredone
Back at my X1000.
But don't be alarmed by the apparently huge difference in version numbers; it got bumped from 41.x to 53.x quite recently to conform with the versioning of the rest of the system modules.
Thanks Niels. Does this rule out rtg.library as the source of the shadow errors?
With some more testing, I notice that the shadows are corrupted whenever I resize any Workbench windows.
- AlfredOne
Yes, the new rtg.library fixes the shadow error, and ( as Niels said previously) will be provided in the next OS4.1 update for X1000.ddni wrote:Thanks Niels. Does this rule out rtg.library as the source of the shadow errors?
- Radeon RX550
