AmigaInput crash with Playstation controller to USB adapter
ddni
Post by ddni »
Hi all, when I run AmigaInput with my Playstation controller to USB adapter, the GR visits.
Is there anything I can do to fix it?
Crash log attached.
Hidden Text - Click to Show :
Crash log for task "AmigaInput_usb_task"
Generated by GrimReaper 53.2
Crash occured in module Generic_usb.driver at address 0x7F556304
Register dump:
0: 7F553864 5F051E60 00000000 00000000 60229E40 60229D3C 02A75914 00000000
8: 1347D3B0 601EB690 00000000 5F0661B4 48442042 41820014 6FF8F000 603A5E08
16: 5F066474 5F249510 00000000 00FF00FF 6FFC0000 62D98F00 11DEAD11 601EB690
24: 60229D3C 60229CD8 00000000 60229E40 0201B3FC 02953588 60229E40 7FFB350C
0: -6.31247e-213 4.03805e+293 1856.34 1.25837e+08
4: 5.87747e-39 1.39565e-34 -4.65768e-193 2.40743e-35
8: 1.95743e+291 -6.05724e-267 7.34519e+306 3.51312e+307
12: 8.43375e-80 -1.39178e-309 -8.51796e-292 2.92533e+289
16: -5.45155e-290 1.38039e+70 2.6888e+115 1856.11
20: 2.66572e+115 1856.06 2.84915e+154 5.03296e+08
24: 2.64263e+115 3.60465e+157 3.04715e+289 8.43375e-80
28: 2.66596e+115 -4.17263e-308 7.34519e+306 1.38174e+70
FPSCR (Floating Point Status and Control Register): 0x57E5D6BE
Machine State (msr) : 0x0000D030
Condition (cr) : 0x48442042
Instruction Pointer (ip) : 0x7F556304
Xtended Exception (xer) : 0x40000078
Count (ctr) : 0x02018C60
Link (lr) : 0x7F5548DC
DSI Status (dsisr) : 0x40000000
Data Address (dar) : 0x00000000
680x0 emulated registers:
FPU0: 0 0 0 0
FPU4: 0 0 0 0
Symbol info:
Instruction pointer 0x7F556304 belongs to module "Generic_usb.driver" (HUNK/Kickstart)
Stack trace:
module CURRDIR:Generic_usb.driver at 0x7F556304 (section 5 @ 0x42E4)
module CURRDIR:Generic_usb.driver at 0x7F553864 (section 5 @ 0x1844)
module CURRDIR:Generic_usb.driver at 0x7F555DA0 (section 5 @ 0x3D80)
native kernel module dos.library.kmod+0x00022a0c
native kernel module kernel+0x000413a4
native kernel module kernel+0x00041424
PPC disassembly:
7f5562fc: 409effec bne+ cr7,0x7F5562E8
7f556300: 4e800020 blr
*7f556304: 88030000 lbz r0,0(r3)
7f556308: 7c691b78 mr r9,r3
7f55630c: 38600000 li r3,0
System information:
CPU
Model: P.A. Semi PWRficient PA6T-1682M VB1
CPU speed: 1800 MHz
FSB speed: 900 MHz
Extensions: altivec
Machine
Machine name: AmigaOne X1000
Memory: 2097152 KB
Extensions: bus.pci bus.pcie
Expansion buses
PCI/AGP
00:1D.0 Vendor 0x1959 Device 0xA004
Range 0: 007F03F8 - 007F0400 (IO)
00:1D.1 Vendor 0x1959 Device 0xA004
Range 0: 007F02F8 - 007F0300 (IO)
00:1A.0 Vendor 0x1959 Device 0xA007
00:00.0 Vendor 0x1959 Device 0xA001
00:01.0 Vendor 0x1959 Device 0xA009
00:14.3 Vendor 0x1959 Device 0xA005
00:1C.0 Vendor 0x1959 Device 0xA003
Range 0: 007F0200 - 007F0240 (IO)
00:1C.1 Vendor 0x1959 Device 0xA003
Range 0: 007F0240 - 007F0280 (IO)
00:1C.2 Vendor 0x1959 Device 0xA003
Range 0: 007F0280 - 007F02C0 (IO)
00:11.3 Vendor 0x1959 Device 0xA002
00:11.2 Vendor 0x1959 Device 0xA002
00:11.1 Vendor 0x1959 Device 0xA002
00:11.0 Vendor 0x1959 Device 0xA002
00:10.0 Vendor 0x1959 Device 0xA002
00:03.0 Vendor 0x1959 Device 0xA00C
00:04.0 Vendor 0x1959 Device 0xA00A
00:05.0 Vendor 0x1959 Device 0xA00A
00:08.0 Vendor 0x1959 Device 0xA000
00:09.0 Vendor 0x1959 Device 0xA000
00:15.0 Vendor 0x1959 Device 0xA006
00:1B.0 Vendor 0x1959 Device 0xA00B
00:1E.0 Vendor 0x1959 Device 0xA008
Range 0: 007F0400 - 007F0500 (IO)
Range 1: 007F0500 - 007F0600 (IO)
0A:12.0 Vendor 0x1002 Device 0x4380
Range 0: 00001040 - 00001048 (IO)
Range 1: 00001058 - 0000105C (IO)
Range 2: 00001048 - 00001050 (IO)
Range 3: 00001058 - 0000105C (IO)
Range 4: 00001010 - 00001020 (IO)
0A:13.0 Vendor 0x1002 Device 0x4387
Range 0: A0207000 - A0208000 (MEM)
0A:13.1 Vendor 0x1002 Device 0x4388
Range 0: A0208000 - A0209000 (MEM)
0A:13.2 Vendor 0x1002 Device 0x4389
Range 0: A0206000 - A0207000 (MEM)
0A:13.3 Vendor 0x1002 Device 0x438A
Range 0: A0204000 - A0205000 (MEM)
0A:13.4 Vendor 0x1002 Device 0x438B
Range 0: A0205000 - A0206000 (MEM)
0A:13.5 Vendor 0x1002 Device 0x4386
Range 0: A0209800 - A0209900 (MEM)
0A:14.0 Vendor 0x1002 Device 0x4385
Range 0: 00001020 - 00001030 (IO)
Range 1: A0209400 - A0209800 (MEM)
0A:14.1 Vendor 0x1002 Device 0x438C
Range 0: 00001030 - 00001038 (IO)
Range 1: 00001050 - 00001054 (IO)
Range 2: 00001038 - 00001040 (IO)
Range 3: 00001050 - 00001054 (IO)
Range 4: 00001000 - 00001010 (IO)
0A:14.2 Vendor 0x1002 Device 0x4383
Range 0: A0200000 - A0204000 (MEM)
0A:14.3 Vendor 0x1002 Device 0x438D
Range 0: 00000000 - 00100000 (MEM)
0A:14.4 Vendor 0x1002 Device 0x4384
0C:05.0 Vendor 0x13F6 Device 0x0111
Range 0: 00003100 - 00003200 (IO)
0C:06.0 Vendor 0x10EC Device 0x8139
Range 0: 00003000 - 00003100 (IO)
Range 1: A0300000 - A0300100 (MEM)
02:00.0 Vendor 0x1002 Device 0x944A
Range 0: 90000000 - A0000000 (PREF.MEM)
Range 2: A0020000 - A0030000 (MEM)
Range 4: 00002000 - 00002100 (IO)
02:00.1 Vendor 0x1002 Device 0xAA30
Range 0: A0030000 - A0034000 (MEM)
Libraries
0x02a6b386: exec.library V53.26
0x6ff668f4: vilintuisup.library V0.9
0x6ff667c8: cgxvideo.library V42.1
0x6ff430e0: cybergraphics.library V43.0
0x60229cd8: Generic_usb.driver V53.3
0x60229c18: PCI_GamePort.driver V53.1
0x60229a98: PCI_GamePortHornet.driver V52.2
0x60229918: PCI_Soundcard.driver V52.2
0x60229858: PCI_sblive.pci V52.1
0x60229798: PCI_SoundCardHornet.driver V52.2
0x62bc9018: AmigaInput.library V53.1
0x603bfd18: center.gadget V53.3
0x603a5e08: usbhidgate.library V53.2
0x603bfb18: SubDock.docky V53.1
0x5fb035c8: Separator.docky V53.2
0x5fb04230: slider.gadget V53.12
0x5fb040f0: getfont.gadget V53.9
0x6202cf40: getfile.gadget V53.11
0x6202ce00: arexx.class V53.3
0x60353dc8: clicktab.gadget V53.39
0x5fb92190: requester.class V53.18
0x6202c400: space.gadget V53.6
0x6202c2c0: bitmap.image V53.9
0x6202cae0: integer.gadget V53.10
0x62bd5d58: chooser.gadget V53.18
0x6202c7c0: penmap.image V53.5
0x5fb80838: screenblanker.library V53.3
0x6202c900: checkbox.gadget V53.9
0x6fc3d808: listbrowser.gadget V53.52
0x62d95c50: string.gadget V53.16
0x6202c540: scroller.gadget V53.13
0x627d5e88: emulation.library V41.446
0x627275d4: usergroup.library V4.30
0x627a8ec0: bsdsocket.library V4.302
0x625a3960: mathieeedoubbas.library V52.1
0x624393fc: textclip.library V52.2
0x62b2663c: hid.usbfd V53.8
0x62b26444: xpkmaster.library V5.2
0x62b183fc: xadmaster.library V13.1
0x62b42340: button.gadget V53.15
0x62b42480: glyph.image V53.3
0x62a59ca0: window.class V53.48
0x62896348: popupmenu.class V53.2
0x62b467e8: popupmenu.library V53.8
0x62b42200: label.image V53.12
0x6fee6e68: layout.gadget V53.19
0x62896250: bevel.image V53.6
0x62a83f50: drawlist.image V53.3
0x62a83e10: png.datatype V53.6
0x62bcb254: picture.datatype V53.6
0x62bd525c: ft2.library V53.1
0x62a2508c: workbench.library V53.42
0x62b46288: timezone.library V53.6
0x62b0f8a8: application.library V53.12
0x62b4a3dc: commodities.library V53.1
0x62bd6da0: Picasso96API.library V2.359
0x62d98798: cmi8738.audio V5.17
0x6fee6da4: device.audio V6.2
0x6fd1e084: filesave.audio V6.3
0x62c0f140: datatypes.library V53.4
0x62bde814: asl.library V53.45
0x62d000cc: icon.library V53.13
0x62bde6f0: gadtools.library V53.4
0x62d978d8: version.library V53.10
0x62bde150: iffparse.library V53.1
0x6ffb9ccc: locale.library V53.4
0x6ff3d7ac: diskfont.library V53.4
0x6fee0f28: petunia.library V53.3
0x6fee0e68: diskcache.library V3.30
0x6fc5966c: dos.library V53.90
0x6fee6274: usbprivate.library V53.12
0x6fe7d6bc: massstorage.usbfd V53.13
0x6fee612c: hub.usbfd V53.8
0x6fe7d628: bootkeyboard.usbfd V52.3
0x6fe7d5a8: bootmouse.usbfd V53.1
0x6fee607c: usbresource.library V53.12
0x6ff3c5b8: hunk.library V53.4
0x6ffa9c54: elf.library V53.17
0x6ff6a4d0: intuition.library V53.35
0x6ff20150: rtg.library V41.4355
0x6ff78ca0: RadeonHD.chip V0.49
0x6ff78c24: PCIGraphics.card V53.4
0x6ffab530: keymap.library V53.5
0x6ff62e40: layers.library V53.7
0x6ffb8420: graphics.library V53.4
0x6ff3c044: nonvolatile.library V53.5
0x6ff8c258: newlib.library V53.19
0x6ff8e1ac: utility.library V53.3
0x6ffab0a8: expansion.library V53.1
0x6272bcae: rexxsyslib.library V45.7 (Legacy)
Devices
0x620d2ac8: rtl8139.device V53.3
0x627d3714: diskimage.device V52.67
0x62bde564: ahi.device V6.6
0x6ff8ed10: usbsys.device V53.12
0x6ff3c7d0: ehci.usbhcd V53.18
0x6ff3c730: ohci.usbhcd V53.19
0x6fe7d2b4: sb600sata.device V53.15
0x6ffa8338: console.device V53.1
0x6ff8f3f0: ramdrive.device V52.6
0x6ffab77c: input.device V53.4
0x6ff3d3b4: keyboard.device V53.10
0x6ff8f2d0: timer.device V53.1
Tasks
ClickToFront (Waiting)
Stack: 0x5faf0004 - 0x5faffffc, pointer @ 0x5faffa80 (Cookie OK)
State: Process (Waiting)
input.device (Waiting)
Stack: 0x6ff28000 - 0x6ff38000, pointer @ 0x6ff37f00 (Cookie OK)
State: Task (Waiting)
SFS DosList handler (Waiting)
Stack: 0x6fc23004 - 0x6fc24ffc, pointer @ 0x6fc24f20 (Cookie OK)
USB stack (Waiting)
Stack: 0x6fe6e000 - 0x6fe72000, pointer @ 0x6fe71f20 (Cookie OK)
OHCI Controller Task Unit 4 (Waiting)
Stack: 0x6fd75000 - 0x6fd7d000, pointer @ 0x6fd7cf20 (Cookie OK)
Signals: SigRec 0xbc009000, SigWait 0x00000000
EHCI Controller Task Unit 0 (Waiting)
Stack: 0x6fd59000 - 0x6fd61000, pointer @ 0x6fd60f20 (Cookie OK)
Signals: SigRec 0xbe009000, SigWait 0x00000000
OHCI Controller Task Unit 2 (Waiting)
Stack: 0x6fdc1000 - 0x6fdc9000, pointer @ 0x6fdc8f20 (Cookie OK)
OHCI Controller Task Unit 0 (Waiting)
Stack: 0x6fe05000 - 0x6fe0d000, pointer @ 0x6fe0cf20 (Cookie OK)
OHCI Controller Task Unit 3 (Waiting)
Stack: 0x6fda5000 - 0x6fdad000, pointer @ 0x6fdacf20 (Cookie OK)
OHCI Controller Task Unit 1 (Waiting)
Stack: 0x6fde9000 - 0x6fdf1000, pointer @ 0x6fdf0f20 (Cookie OK)
page_sweep (Waiting)
Stack: 0x6fe11004 - 0x6fe18ffc, pointer @ 0x6fe18e70 (Cookie OK)
sb600sata.device - chip 0 port 0 (Waiting)
Stack: 0x6fe41000 - 0x6fe49000, pointer @ 0x6fe48f20 (Cookie OK)
hid.usbfd (Ready)
Stack: 0x62b9c004 - 0x62ba3ffc, pointer @ 0x62ba3e90 (Cookie OK)
Signals: SigRec 0xe0000000, SigWait 0x80000100
State: Process (Ready)
reaper.task (Waiting)
Stack: 0x62c95004 - 0x62c9cffc, pointer @ 0x62c9cea0 (Cookie OK)
HID Joystick (Waiting)
Stack: 0x62b88004 - 0x62b97ffc, pointer @ 0x62b97f20 (Cookie OK)
DH0 (Waiting)
Stack: 0x6fc1d004 - 0x6fc1effc, pointer @ 0x6fc1eeb0 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x625cd004 - 0x625d4ffc, pointer @ 0x625d4e90 (Cookie OK)
Signals: SigRec 0xe0000000, SigWait 0x00000100
HID Mouse (Waiting)
Stack: 0x62441004 - 0x62450ffc, pointer @ 0x62450f20 (Cookie OK)
ICD0 (Waiting)
Stack: 0x6248c004 - 0x6249bffc, pointer @ 0x6249bf20 (Cookie OK)
Signals: SigRec 0x00000100, SigWait 0x28000000
ICD1 (Waiting)
Stack: 0x6250c004 - 0x6251bffc, pointer @ 0x6251bf20 (Cookie OK)
RAM (Waiting)
Stack: 0x62d65004 - 0x62d6cffc, pointer @ 0x62d6cc90 (Cookie OK)
CD0 (Waiting)
Stack: 0x6fc29004 - 0x6fc2affc, pointer @ 0x6fc2af20 (Cookie OK)
dos_filedir_notify (Waiting)
Stack: 0x6fc09004 - 0x6fc0cffc, pointer @ 0x6fc0caf0 (Cookie OK)
Signals: SigRec 0x40001000, SigWait 0x00000000
DH1 (Waiting)
Stack: 0x62f01004 - 0x62f02ffc, pointer @ 0x62f02eb0 (Cookie OK)
MainIPC0 (Waiting)
Stack: 0x62766004 - 0x62775ffc, pointer @ 0x62775eb0 (Cookie OK)
Signals: SigRec 0x40000100, SigWait 0x00000000
pager (Waiting)
Stack: 0x62c37004 - 0x62c56ffc, pointer @ 0x62c56f00 (Cookie OK)
IDF3 (Ready)
Stack: 0x62663004 - 0x62672ffc, pointer @ 0x62672ed0 (Cookie OK)
Signals: SigRec 0xa8000100, SigWait 0x20000000
ENV (Waiting)
Stack: 0x62f0d004 - 0x62f0effc, pointer @ 0x62f0ee00 (Cookie OK)
IDF0 (Waiting)
Stack: 0x62569004 - 0x62578ffc, pointer @ 0x62578ed0 (Cookie OK)
Signals: SigRec 0xa8000100, SigWait 0x00000000
IDF1 (Waiting)
Stack: 0x625a9004 - 0x625b8ffc, pointer @ 0x625b8ed0 (Cookie OK)
IDF2 (Waiting)
Stack: 0x6260e004 - 0x6261dffc, pointer @ 0x6261ded0 (Cookie OK)
IPC0 (Waiting)
Stack: 0x6277a004 - 0x62789ffc, pointer @ 0x62789ee0 (Cookie OK)
Signals: SigRec 0x00010100, SigWait 0x00000000
URL (Waiting)
Stack: 0x621cb004 - 0x62245ffc, pointer @ 0x62240ad0 (Cookie OK)
CON (Waiting)
Stack: 0x5f06b004 - 0x5f07affc, pointer @ 0x5f07ade0 (Cookie OK)
rtl8139.device.0 (Waiting)
Stack: 0x62000004 - 0x6200fffc, pointer @ 0x6200ff20 (Cookie OK)
Signals: SigRec 0xf0008000, SigWait 0x00000100
CON (Waiting)
Stack: 0x6048a004 - 0x60499ffc, pointer @ 0x60499de0 (Cookie OK)
CON (Waiting)
Stack: 0x5fab8004 - 0x5fac7ffc, pointer @ 0x5fac7de0 (Cookie OK)
CON (Waiting)
Stack: 0x5fb3e004 - 0x5fb4dffc, pointer @ 0x5fb4dde0 (Cookie OK)
CON (Waiting)
Stack: 0x5fbe8004 - 0x5fbf7ffc, pointer @ 0x5fbf7de0 (Cookie OK)
CON (Waiting)
Stack: 0x5fc38004 - 0x5fc47ffc, pointer @ 0x5fc47de0 (Cookie OK)
AUDIO (Waiting)
Stack: 0x6218d004 - 0x6219cffc, pointer @ 0x6219cec0 (Cookie OK)
CON (Waiting)
Stack: 0x62d19004 - 0x62d20ffc, pointer @ 0x62d20de0 (Cookie OK)
RAW (Waiting)
Stack: 0x62d71004 - 0x62d78ffc, pointer @ 0x62d78de0 (Cookie OK)
CON (Waiting)
Stack: 0x62d8d004 - 0x62d94ffc, pointer @ 0x62d94de0 (Cookie OK)
dos_nbmd_process (Waiting)
Stack: 0x6ff0c004 - 0x6ff0dffc, pointer @ 0x6ff0df30 (Cookie OK)
dos_lock_handler (Waiting)
Stack: 0x6ff06004 - 0x6ff07ffc, pointer @ 0x6ff07f10 (Cookie OK)
bootkeyboard.usbfd (Waiting)
Stack: 0x6fc69004 - 0x6fc70ffc, pointer @ 0x6fc70dd0 (Cookie OK)
Signals: SigRec 0x10000000, SigWait 0x60000000
console.device (Waiting)
Stack: 0x6fe49000 - 0x6fe51000, pointer @ 0x6fe50f70 (Cookie OK)
Signals: SigRec 0xf0000000, SigWait 0x00000000
Stack: 0x6245d004 - 0x62470ffc, pointer @ 0x62470c30 (Cookie OK)
RexxMaster [] (Waiting)
Stack: 0x620dd004 - 0x620ecffc, pointer @ 0x620ecf50 (Cookie OK)
Stack: 0x624dd004 - 0x624f0ffc, pointer @ 0x624f0c30 (Cookie OK)
Stack: 0x62549004 - 0x6255cffc, pointer @ 0x6255cc30 (Cookie OK)
diskimage.device unit 1 (Waiting)
Stack: 0x62585004 - 0x62598ffc, pointer @ 0x62598c30 (Cookie OK)
diskimage.device unit 2 (Waiting)
Stack: 0x625ee004 - 0x62601ffc, pointer @ 0x62601c30 (Cookie OK)
diskimage.device unit 3 (Waiting)
Stack: 0x62643004 - 0x62656ffc, pointer @ 0x62656c30 (Cookie OK)
diskimage.device unit 6 (Waiting)
Stack: 0x62687004 - 0x6269affc, pointer @ 0x6269ac30 (Cookie OK)
TEXTCLIP (Waiting)
Stack: 0x621ab004 - 0x621baffc, pointer @ 0x621baeb0 (Cookie OK)
compose.task (Ready)
Stack: 0x60eba000 - 0x60ec2000, pointer @ 0x60ec1f30 (Cookie OK)
Signals: SigRec 0x00000021, SigWait 0x00000020
State: Task (Ready)
Workbench [Workbench] (Waiting)
Stack: 0x6213d004 - 0x6214cffc, pointer @ 0x6214cea0 (Cookie OK)
Stack: 0x5fccf004 - 0x5fcdeffc, pointer @ 0x5fcdef40 (Cookie OK)
ramlib (Waiting)
Stack: 0x62c5b004 - 0x62c73ffc, pointer @ 0x62c73f20 (Cookie OK)
ContextMenus Command Dispatcher [ContextMenus Command Dispatcher] (Waiting)
Stack: 0x603cf004 - 0x603deffc, pointer @ 0x603def40 (Cookie OK)
Stack: 0x5fcbb004 - 0x5fccaffc, pointer @ 0x5fccadb0 (Cookie OK)
Stack: 0x605eb004 - 0x605faffc, pointer @ 0x605faf00 (Cookie OK)
datatypes.library (Waiting)
Stack: 0x62b4f004 - 0x62b67ffc, pointer @ 0x62b67f10 (Cookie OK)
AmiDock (Ready)
Stack: 0x5fc65004 - 0x5fc74ffc, pointer @ 0x5fc73e50 (Cookie OK)
Signals: SigRec 0x00000010, SigWait 0x00000000
hub.usbfd (Ready)
Stack: 0x6fcc9004 - 0x6fcd0ffc, pointer @ 0x6fcd0f00 (Cookie OK)
Signals: SigRec 0x30000000, SigWait 0x10000000
State: Task (Ready)
RinghioServer (Ready)
Stack: 0x6049e004 - 0x604bdffc, pointer @ 0x604bd370 (Cookie OK)
Signals: SigRec 0xd8001000, SigWait 0x10000100
TCP/IP Control (Ready)
Stack: 0x6204c004 - 0x6205bffc, pointer @ 0x6205bdc0 (Cookie OK)
Signals: SigRec 0xf8009080, SigWait 0x40000000
screenblanker.library timing dispatcher (Waiting)
Stack: 0x60540004 - 0x6054fffc, pointer @ 0x6054fea0 (Cookie OK)
AmigaInput (Waiting)
Stack: 0x5f0b6004 - 0x5f0c5ffc, pointer @ 0x5f0c4840 (Cookie OK)
AmigaInput Dispatcher (Waiting)
Stack: 0x5f235000 - 0x5f239000, pointer @ 0x5f238f20 (Cookie OK)
ScreenBlankerEngine (Waiting)
Stack: 0x5fb5a004 - 0x5fb69ffc, pointer @ 0x5fb69be0 (Cookie OK)
Signals: SigRec 0xd8001000, SigWait 0x00000100
hub.usbfd (Waiting)
Stack: 0x6fcd5004 - 0x6fcdcffc, pointer @ 0x6fcdcf00 (Cookie OK)
TCP/IP Superserver [TCP/IP Superserver] (Waiting)
Stack: 0x62068004 - 0x62077ffc, pointer @ 0x62077a00 (Cookie OK)
Signals: SigRec 0xd0000080, SigWait 0x00000000
Stack: 0x62084004 - 0x62093ffc, pointer @ 0x62093de0 (Cookie OK)
Signals: SigRec 0xf8003000, SigWait 0x00000000
ContextMenus [] (Waiting)
Stack: 0x5fad4004 - 0x5fae3ffc, pointer @ 0x5fae3c50 (Cookie OK)
Signals: SigRec 0xe0001000, SigWait 0x00000100
ASYNCWB (Waiting)
Stack: 0x5fc1c004 - 0x5fc2bffc, pointer @ 0x5fc2be70 (Cookie OK)
« IPrefs » (Waiting)
Stack: 0x62a72004 - 0x62a81ffc, pointer @ 0x62a81530 (Cookie OK)
Signals: SigRec 0x0000f000, SigWait 0x20000100
RAWBInfo (Waiting)
Stack: 0x5fb9b004 - 0x5fbaaffc, pointer @ 0x5fbaaec0 (Cookie OK)
DefIcons (Waiting)
Stack: 0x5fc04004 - 0x5fc13ffc, pointer @ 0x5fc13dc0 (Cookie OK)
TCP/IP Log (Waiting)
Stack: 0x620a0004 - 0x620afffc, pointer @ 0x620aff00 (Cookie OK)
ConClip (Waiting)
Stack: 0x62151004 - 0x62160ffc, pointer @ 0x62160eb0 (Cookie OK)
hid.usbfd (Waiting)
Stack: 0x625e2004 - 0x625e9ffc, pointer @ 0x625e9e40 (Cookie OK)
USB stack Process (Waiting)
Stack: 0x627bb004 - 0x627caffc, pointer @ 0x627caee0 (Cookie OK)
DST watcher (Waiting)
Stack: 0x62a49004 - 0x62a58ffc, pointer @ 0x62a58f20 (Cookie OK)
Stack: 0x62b25000 - 0x62b25fa0, pointer @ 0x62b25f10 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fd05004 - 0x6fd0cffc, pointer @ 0x6fd0cf00 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fce1004 - 0x6fce8ffc, pointer @ 0x6fce8f00 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fced004 - 0x6fcf4ffc, pointer @ 0x6fcf4f00 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fcf9004 - 0x6fd00ffc, pointer @ 0x6fd00f00 (Cookie OK)
AmigaInput_usb_task (Crashed)
Stack: 0x5f042004 - 0x5f051ffc, pointer @ 0x5f051e60 (Cookie OK)
State: Process (Crashed)
ramlib.support (Waiting)
Stack: 0x62c78004 - 0x62c90ffc, pointer @ 0x62c90f00 (Cookie OK)
Signals: SigRec 0x80005000, SigWait 0x00000000
dos_signal_server (Waiting)
Stack: 0x6fc11004 - 0x6fc12ffc, pointer @ 0x6fc12f10 (Cookie OK)
Signals: SigRec 0x0000f000, SigWait 0x00000000
Picasso96 (Waiting)
Stack: 0x62aca004 - 0x62ad9ffc, pointer @ 0x62ad9da0 (Cookie OK)
dos_appdir_server (Waiting)
Stack: 0x6fc17004 - 0x6fc18ffc, pointer @ 0x6fc18d50 (Cookie OK)
idle.task (Ready)
Stack: 0x6ff63000 - 0x6ff64000, pointer @ 0x6ff63fd0 (Cookie OK)
State: Task (Ready)
ChrisH
Re: AmigaInput crash with Playstation controller to USB adap
Post by ChrisH »
In the Grim Reaper, does clicking the More button, and then the "Continue Program" button solve the problem? But if you get another DSI, then you could try click on More then the "Ignore DSI errors" button, but please beware that may cause OS4 to lock-up in some cases.
You shouldn't have to do this, but maybe it will allow you to work-around the problem until it is fixed.
ddni
Post by ddni »
Hi Chris, I can do as you suggested, but it doesn't help. OS4 does not lock up, but the CPU goes to 100% and AmigaInput can no longer be accessed. The gamepad doesn't work either ;)
