Network-Startup Script
A new way of launching the network has appeared with Update 5.
This script is now included in Startup-Sequence :
If EXISTS S:Network-Startup
Run >NIL: <NIL: *>NIL: Execute S:Network-Startup
EndIf
Problem is it is situated just after the User-Startup launch script. And if you have commands using the Network in your User Startup, it will hang the system since the network has not been activated.
As I have 2 commands (one for activating my Samba shared hard drive and another one to set the time from a NTP server), the systems hangs at bootup.
Solution : in Startup-Sequence copy the command launching the network BEFORE the one launching the User-Startup. All is working ok now.
EndIf
- javierdlr
Re: Network-Startup Script
Have you tried to add such lines/commands in Network-Startup?
NETWORK-STARTUP file:
; $VER: Network-Startup 53.2 (01.06.2011)
AddNetInterface QUIET DEVS:NetInterfaces/~(#?.info)
; Add below this line applications that need a running network
I have to agree with javierdlr: This is not a good solution. Always, if at all possible, avoid completely changing your Startup-Sequence.K-L wrote:Solution : in Startup-Sequence copy the command launching the network BEFORE the one launching the User-Startup. All is working ok now.
The idea of the Network-Startup script being launched asynchronously from the rest of the startup is that everything needing a running network should be placed in the Network-Startup, after it has brought up the network (as the comment in there says). That way it:
a) won't delay the rest of your system startup
b) won't fail because of a missing network
Interesting. I did not know I could add anything in this script.
Thanks for sharing
Thanks for sharing
You're welcomeK-L wrote:Interesting. I did not know I could add anything in this script.
Thanks for sharing
BTW, as you mentioned Samba: What I have done with Samba is that I set up my assign and path for Samba as the very first thing in the Network-Startup script instead of in User-Startup (to make sure it is done synchronously before using it later in the same script). Then comes the actual network start (AddNetInterface), which of course as part of what it does, sets up the Samba server(s) configured on the Servers page (and in Devs:Internet/servers). And even later in the script, I mount an SMB share (with SMBMounter), because at this time everything it needs (locally) should be available.
So always think in dependencies; if anything needs anything else, make sure it runs after the thing it needs. (Making sure means putting it in the same process, later on. Putting them in separate, partly parallel processes is gambling.)
How do you correctly configure this? I started getting 'no netork/internet' errors with update 5, so I moved AmiUpdate, SimpleMail and Jabberwocky from WBStartup to the network startup. The problem is only the first program loads, no matter what order I put them in? Here's how it looks:javierdlr wrote:Have you tried to add such lines/commands in Network-Startup?
SYS:Utilities/AmiUpdate/AmiUpdate
APPLICATIONS:SimpleMail/SimpleMail
APPLICATIONS:Jabberwocky/Jabberwocky
The no network errors were probably due to a "run" before addnetinterface back then...your machine wasn't hooked to the net when programs kicked in to use itdan.hutch wrote: How do you correctly configure this? I started getting 'no netork/internet' errors with update 5, so I moved AmiUpdate, SimpleMail and Jabberwocky from WBStartup to the network startup. The problem is only the first program loads, no matter what order I put them in? Here's how it looks:
The APPLICATIONS: assign is set in user startup. Any help or a working example appreciated, thanks!Code: Select all
NETWORK-STARTUP file: +++++++++++++++++++++++ ; $VER: Network-Startup 53.2 (01.06.2011) AddNetInterface QUIET DEVS:NetInterfaces/~(#?.info) ; Add below this line applications that need a running network +++++++++++++++++++++++ SYS:Utilities/AmiUpdate/AmiUpdate APPLICATIONS:SimpleMail/SimpleMail APPLICATIONS:Jabberwocky/Jabberwocky
This is my network-startup and it's not much
AddNetInterface DEVS:NetInterfaces/~(#?.info) QUIET
date server prefs save
Of course only AmiUpdate is started, because you don't detach it from your script. So nothing will happen, until you manually quit AmiUpdate (and Simplemail afterwards). It should read:dan.hutch wrote: The problem is only the first program loads, no matter what order I put them in? Here's how it looks:
Run >NIL: SYS:Utilities/AmiUpdate/AmiUpdate
Run >NIL: APPLICATIONS:SimpleMail/SimpleMail
Run >NIL: PPLICATIONS:Jabberwocky/Jabberwocky
@Raziel
Take it this checks system time against the network time server specified in Time Prefs?
I've always done the same in the past but the network never seems to be ready soon enough for WBStartup now.I leave all the other application to WBStartup...because running it so early may lead to more problems because of not yet loaded dependencies
Yes, it does.dan.hutch wrote:@Raziel
Take it this checks system time against the network time server specified in Time Prefs?Code: Select all
It actually sets the time from the net (given there is net access)
I still get an assertion every time i boot from AddNetInterfaces...why is beyond me, probably because on the first start it can't access anything or doesn't get useable data back from the router.
Funny enough, because after the network has been established AmigaOS4 boots in and i can use the net...that puzzles me really
Maybe it isn't AddNetInterfaces but some other program kicking in from the kernel?
