c-3020 camera recognized but no icon
ggw
Post by ggw »
On the AmigaOne it worked. On the X1000 is doesn't. Why?
I plugged my camera cable into lower left USB port (facing the rear of the X1000) and I get the usual window recognizing the device which goes away after about 5 seconds, but no icon ever appears. And the INFO command shows no device.
Below is the USB log.
I: [15:54:10] hub.usbfd | HUB | Device found on port 5 of hub "Rear Roothub (ehci.usbhcd/0)".
I: [15:54:10] EHCI Controller Task Unit 0 | EHCI | Device at port 4 is a fullspeed device. Giving up ownership.
I: [15:54:10] hub.usbfd | HUB | Port 5 of hub "Rear Roothub (ehci.usbhcd/0)" reset timed out
W: [15:54:10] hub.usbfd | HUB | Resetting hub port 5 and trying again
I: [15:54:10] hub.usbfd | HUB | Reset request for port 5 failed (error -23)
E: [15:54:10] hub.usbfd | HUB | Resetting port 5 of hub "Rear Roothub (ehci.usbhcd/0)" failed. Device adding aborted
I: [15:54:10] hub.usbfd | HUB | Device found on port 1 of hub "Additional Roothub (ohci.usbhcd".
I: [15:54:10] hub.usbfd | Hub port | Device at port 1 of hub "Additional Roothub (ohci.usbhcd" is full-speed.
I: [15:54:10] USB stack | New Fkt | Fkt 0x659b6dd0 at level 1
I: [15:54:10] hub.usbfd | HUB | Device on hub port 1 successfully added.
I: [15:54:10] USB Fkt Init | Init Fkt | Fkt 0x659b6dd0 is {Vendor: 0x07B4, Product: 0x0105, Class: 00.00}
I: [15:54:10] USB Fkt Init | Init Fkt | Fkt 0x659b6dd0 initialized
W: [15:54:10] USB FD fkt start | BindInterfaceDriver | No interface driver of fkt 0x659b6dd0/ifc 0x62f6ab50 {Class 08.06} has been found
W: [15:54:10] USB FD fkt start | FD launcher | Could not bind any suitable interface driver for fkt 0x659b6dd
George Wyche
