Memory pooling
trixie
Memory pooling
Post by trixie »
My program does a lot of on-the-fly memory allocations: small amounts of memory (< 128 bytes) constantly get allocated and freed. I was wondering if using a memory pool would be more considerate of the memory system, especially as regards fragmentation.
The Rear Window blog
LyleHaze
Re: Memory pooling
Post by LyleHaze »
Yes.
It also provides a simple way to free the entire pool if desired.
If your "small amounts of memory" are all the same size, you might also consider an ItemPool (ASOT_ITEMPOOL) instead of MemoryPool(ASOT_MEMPOOL), which can optimize for many same-sized allocations.
Hans
Re: Memory pooling
Post by Hans »
trixie wrote:My program does a lot of on-the-fly memory allocations: small amounts of memory (< 128 bytes) constantly get allocated and freed. I was wondering if using a memory pool would be more considerate of the memory system, especially as regards fragmentation.
Are these items all of the same size? If so, please use item pools instead. They're designed especially for the frequent allocation and deallocation of small blocks that are all the same size.
Look up ASOT_ITEMPOOL, ItemPoolAlloc()/ItemPoolFree() in the Exec autodocs.
Hans
trixie
Re: Memory pooling
Post by trixie »
Thank you both!
