Different network issue - FIXED
Zenzizenzizenzic
Post by Zenzizenzizenzic »
I just purchased a wireless router, and switched it out on my network. However, I could not get the X1000 to go online. I then replaced the original router, and even copied the old netinterface from my backup partition, still cannot get online. I'm getting a "network is not available" error. Other machines on the same switch can get online. I moved the cord from one of these machines to the X1000, same issue. I checked the network card and it was seated. Any ideas what happened?
Thank you!
ChrisH
Re: Different network issue
Post by ChrisH »
If you start Sys:Prefs/Internet, what settings does it show in the following tabs: Interfaces, Routes (inc Default Gateway Address), and Name Resolution. (Hosts might also be relevant.)
Zenzizenzizenzic
Under Interfaces:
Device: rtl8139.device
Unit/Port : 0
Type: unknown
Config: DHCP
Routes :
Default Gateway : 255.255.255.0
Name Resolution is empty
Hosts:
IP addr: 127.1
Alias : localhost.my.domain
I also checked my Backup Boot partition which could still go online. The Default Gateway there was blank. I removed that, and it seems to work.
Thank you much!!!
ChrisH
Post by ChrisH »
Yes, the 255.255.255.0 part was completely wrong. By leaving it blank it should automatically find the correct setting using DHCP.
trevordick
A-Eon Technology
A-Eon Technology
Re: Different network issue - FIXED
Post by trevordick »
Edited to say fixed. :-)
Trevor
I'm just Breezin'
