Icon.library ?
JosDuchIt
Icon.library ?
Post by JosDuchIt »
I would like to program 2 Cli commands to be used in scripts
a) one giving the type of an icon (tool, project ..)
b) one permitting to change the type of an icon to an other one you specify in the command line
I guess it's ion.library that i should use, but the autodoc is not that easy to grasp.
I would be bery gratefull for some help: what functions should i use ?
tboeckel
Re: Icon.library ?
Post by tboeckel »
JosDuchIt wrote:I would like to program 2 Cli commands to be used in scripts
Basically it is something like this to change the icon type of "disk.info" from whatever to a tool icon:
icon = GetDiskObject("disk");
icon->do_Type = WBTOOL;
PutDiskObject("disk", icon);
FreeDiskObject(icon);
Getting the icon type is left to you as an excercise ;)
If you need to do more complex operations on the icon then perhaps GetIconTags() and PutIconTags() are more suitable functions.
Re: Icon.library ?
Post by thomasrapp »
Turning a disk.info into a tool will hide the partition...
JosDuchIt
Re: Icon.library ?
Post by JosDuchIt »
Thanks, also for the warning.
as i had to hunt for the other do_type values
WBDISK The root of a disk
WBDRAWER A directory on the disk
WBTOOL An executable program
WBPROJECT A data file
WBGARBAGE The Trashcan directory
WBKICK A Kickstart disk
WBAPPICON Any object not directly associated
with a filing system object, such as
a print spooler (new in Release 2).
Table 14-2: Workbench Object Types
Re: Icon.library ?
Here is a "MakeTrash" command I wrote some time ago:
#include <proto/dos.h>
#include <proto/icon.h>
int main (void)
struct RDArgs *rdargs;
struct {
	char *path;
	} args = {0};
int rc = RETURN_FAIL;
BPTR lock;
struct DiskObject *dob;
rdargs = ReadArgs ("PATH/A",(LONG *)&args,NULL);
if (!rdargs)
	PrintFault (IoErr(),"error in arguments");
	return (RETURN_ERROR);
if (lock = CreateDir (args.path))
	UnLock (lock);
	if (dob = GetDefDiskObject (WBGARBAGE))
		if (PutDiskObject (args.path,dob))
			rc = RETURN_OK;
		else
			PrintFault (IoErr(),"cannot save icon");
		FreeDiskObject (dob);
	else
		PrintFault (IoErr(),"cannot obtain default icon");
else
	PrintFault (IoErr(),"cannot create directory");
return (rc);
JosDuchIt
Re: Icon.library ?
Post by JosDuchIt »
OK i have a working CLI command that transforms some icontype in a WBTOOL type.
In fact i can define the type as a string argument in the commands template
 /* The icon to change should be in the current directory
#define __USE_INLINE__ //always befor includes
#include <exec/types.h>
// #include <proto/intuition.h>
// #include <intuition/intuition.h>
#include <workbench/workbench.h>
#include <proto/dos.h> //PrintFault
//#include <stdio.h>
#include <string.h>
#define TEMPLATE  "Icon/A,Type/A"
int main(int argc, char *argv[]) {
	char iconname[31];
	char icontype[10];
	struct DiskObject *icon;
	LONG	args[] = { 0, 0};
	rdargs = ReadArgs(TEMPLATE,args, NULL);
	if (rdargs == NULL){
    	PrintFault(IoErr(), NULL);
    	goto endprog;
   if (args[0]) strncpy (iconname, (char *)args[0] , 30);
	if (args[1]) strncpy (icontype, (char *)args[1], 10);
	if ( icon = GetDiskObject(iconname)) {
		Printf("iconname %s\n", iconname);
		icon->do_Type = WBTOOL ; //icontype;
		if ( PutDiskObject(iconname, icon))
        rc = RETURN_OK;
      else
	else
endprog:
return rc;
Idid spot the following defines
<workbench/workbenvh.h>
#define WBDISK 1
#define WBDRAWER 2
#define WBTOOL 3
#define WBPROJECT 4
#define WBGARBAGE 5
#define WBDEVICE 6
#define WBKICK 7
#define WBAPPICON 8
How do i transform easily the icontype string to something
icon->do_Type = ???icontype??? ; accepts as well
as
tboeckel
Re: Icon.library ?
Post by tboeckel »
JosDuchIt wrote:How do i transform easily the icontype string to something
as
How about a simple string comparison?
JosDuchIt
Re: Icon.library ?
Post by JosDuchIt »
@tboeckel
something like this below works OK, but i was wondering if there was nothing more elegant (for long list of #definded values) eg make an array of #defined string & its value.
As it must not be an uncommon situation I just hoped for this kind of solution, but OK it works.
if      (!(strcmp("WBDISK",     icontype)))
				icon->do_Type = WBDISK   ;
		else if (!(strcmp("WBDRAWER",   icontype)))
				icon->do_Type = WBDRAWER ;
		else if (!(strcmp("WBTOOL",     icontype)))
		else if (!(strcmp("WBPROJECT",  icontype)))
				icon->do_Type = WBPROJECT;
		else if (!(strcmp("WBDEVICE",   icontype)))
				icon->do_Type = WBDEVICE ;
		else if (!(strcmp("WBKICK",     icontype)))
		else if (!(strcmp("APPICON",    icontype)))
				icon->do_Type = WBAPPICON;
salass00
Re: Icon.library ?
Post by salass00 »
Since the numbers are ordered 1 to 8 you could do it simply like this:
STATIC CONST CONST_STRPTR icontype_strings[] = {
	"WBDISK",
	"WBDRAWER",
	"WBTOOL",
	"WBPROJECT",
	"WBGARBAGE",
	"WBDEVICE",
	"WBKICK",
	"WBAPPICON",
	NULL
int i;
for (i = 0; icontype_strings[i]; i++) {
	if (!strcmp(icontype_strings[i], icontype)) {
		icon->do_Type = i+1;
		break;
Alternately a version that doesn't rely on the values of the constants being 1 to 8 would look like so:
	"WBDISK",
	"WBDRAWER",
	"WBTOOL",
	"WBPROJECT",
	"WBGARBAGE",
	"WBDEVICE",
	"WBKICK",
	"WBAPPICON",
	NULL
STATIC CONST UBYTE icontype_values[] = {
	WBDISK,
	WBDRAWER,
	WBTOOL,
	WBPROJECT,
	WBGARBAGE,
	WBDEVICE,
	WBKICK,
	WBAPPICON
int i;
		icon->do_Type = icontype_values[i];
		break;
Note that strcmp() does case-sensitive string comparison (i.e. "WBDISK", "wbdisk" and "WbDisk" are not equal). If you want case-insensitive comparison (might make more sense if icontype string comes from user input) then you should use stricmp() or Stricmp() (utility.library function) instead.
