I'm trying to get a MUI screen to have a different res. than my workbench screen. However, even though MUI prefs shows the desired screen mode, it always copies the WB screen settings. Has anyone else had this issue?
Thank you
MUI Screen mode
Re: MUI Screen mode
Do you have the "Like Workbench" option active? This will MUI generate a screen with exactly the same attributes like the Workbench screen, no matter which screenmode and dimension you select.Zenzizenzizenzic wrote:I'm trying to get a MUI screen to have a different res. than my workbench screen. However, even though MUI prefs shows the desired screen mode, it always copies the WB screen settings.
Zenzizenzizenzic
Re: MUI Screen mode
That was it, thank you. Forgot about that button.
