NotePad PubScreen issue (fixed)
While I was responding to a problem at Amigans.net, I noticed that NotePad does not bring the screen to the front when it is opened on a Public Screen with the "PUBSCREEN=screen_name" TOOLTYPE. It's a little disconcerting when you double-click a program icon and the WorkBench window it appears in deactivates but no program window appears. I don't think this qualifies as a bug but it should be fixed. If others don't think that the screen should be popped to the front when NotePad opens on a Public Screen, then add a TOOLTYPE for such an option (i.e. SCREENTOFRONT).
Re: NotePad PubScreen issue
Thanks for the rreport, this issue has been fixed.
Simon
Simon
