Radeon from elbox
tommysammy
Radeon from elbox
Post by tommysammy »
Is there any support from Hyperion planned?
Hans-Joerg Frieden
Re: Radeon from elbox
Post by Hans-Joerg Frieden »
tommysammy wrote:Is there any support from Hyperion planned?
Please elaborate...?
kas1e
Post by kas1e »
@tommysammy
Elbox and Amikit its just companys which sold standard radeons, without any "amiga-changes". As aos4 have support of radeon9000/9250, then any radeon9000/9250 will works, and does not matter where you will buy it. Amikit and Elbox there not play any major role, they just give you easy way to found those cards (as they already hard to find in standart PC shops).
In reality your 2 topics about elbox/amikit radeons should be just one : "which model of radeon cards support amigaos4 currently". And answer will be full list of supported cards, and you will just check if elbox and amikit give you those cards (and they of course give you supported ones, because it will make no sense to sold cards in amiga shops, which not supported by drivers).
tommysammy
I have bought a Radeon 9200 with 256 MB from elbox like some friends from a1k.
Now we have installed Os4.1 Classic
All the cards from elbox doesn`t work.
There are big gfx errors.
Now elbox had send us a new pci.library 10.0 and a new radeon.card driver.
I have now a picture under Os4.1 Classic but:
Warp3D doesn`t work
Compostion Engine doesn`t work
I can see only 8MB from my Radeon 256MB
So question again.
Will Hyperion make a native Radeon driver for the Radeon Cards from elbox?
@Kas1e i cannot build in a radeon from amigakit,because there is only support for the Mediator SX and TX.I have a LT4 That is the problem
I want use Os4.1 Classic with Warp 3D and Composition Engine,because my Voodoo 3000 is to slow for that
Hans-Joerg Frieden
tommysammy wrote:Warp3D doesn`t work
No surprise. Part of the Compositing and Warp3D has been moved into ATIRadeon.chip. Trying to use a 68k pci.library driver on top of AmigaOS 4's own PCI support is a sure way to shoot yourself in the foot. The best thing you can expect from this is crashes.
You probably only see 8 MB so that the card avoids bank switching.
Elbox doesn't make Radeon cards. The initialization of the card depends on the BIOS of the card. Some cards do not work, and it appears that this is one of them. We might re-visit this issue before the next update, but it is difficult to support some of the Radeons out there. Before anyone remarks that they work under AmigaOS 3.x, the problem is (in part) related to the PowerPC, or rather, to the way that the BlizzardPPC connects to the system. Some cards have timing issues that make them work under 68k due to the slower access, but fail to work on the PowerPC. On the Amiga 4000, you can mostly work around this problem by setting the Waitstate jumper. Unfortunately, this doesn't exist on the A1200 Mediator.
It *might* be an issue with the reset of the cards. Does it show up in ShowConfig?
tommysammy
My Radeon works fine under Os3.9
Ok ,there is no Warp3D
My Mediator PCI1200 have also "Wait".There is a Jumper.I use this
This show me Showconfig
PROCESSOR: CPU 68060/68060fpu/68060mmu
CUSTOM CHIPS: AA NTSC Alice (id=$0033), AA Lisa (id=$00F8)
VERS: Kickstart version 40.68, Exec version 40.99, Disk version 45.3
RAM: Node type $A, Attributes $505 (FAST), at $70000000-$7FF7FFFF (255.5 meg)
Node type $A, Attributes $2005 (FAST), at $82000000-$8FEFFFFF (223.0 meg)
Node type $A, Attributes $703 (CHIP), at $1000-$1FFFFF (~2.0 meg)
BOARDS:
Board (Index Information Ltd): Prod=2206/32($89E/$20) (@$EA0000 128K)
Board (Index Information Ltd): Prod=2206/160($89E/$A0) (@$200000 8meg)
Board + ROM (HD?) (phase 5): Prod=8512/110($2140/$6E) (@$F00C34 128K)
Hans-Joerg Frieden
This is a 68k ShowConfig. I meant an AmigaOS 4 ShowConfig.
tommysammy
No problem will give you this tomorrow
tommysammy
PROCESSOR: 603e
EMULATED: CPU 68020/68881fpu
VERSION: Kickstart version 53.16, Exec version 53.16, Disk version 53.2
LEGACY RAM: Node type $A, Attributes $703 (CHIP), at $3000-$1FFFFF (~2.0 meg)
ZORRO BOARDS:
Board (ELBOX): Prod=2206/32($89E/$20) (@$EA0000 128K)
Board (ELBOX): Prod=2206/160($89E/$A0) (@$200000 8meg)
PCI BOARDS:
Bus Device Funct. Manuf. Product Status
0x00 0x00 0x00 0x121A 0x0005 working
0x00 0x01 0x00 0x1002 0x5960 working
0x00 0x02 0x00 0x10EC 0x8029 working
0x00 0x03 0x00 0x1274 0x5880 working
Hans-Joerg Frieden
tommysammy wrote:0x00 0x01 0x00 0x1002 0x5960 workingg
Hm, so the card is recognized, that's weird.
Can you make a serial log at debug level 7 from the boot process? Thank you.
