it is possible to make attaching of .lha and .txt ?
This is the place to ask if you have any issues with our forum system. These include questions about your account, PM's, login trouble, etc.
kas1e
Post by kas1e »
Just notice myself few days ago when want to attach some stuff from os4 : i can't attach .lha files, and code of forum say "can't attach .lha". Also as i notice today in some other topic, MickJt also can't attach .txt. It is possible to add ability to attach them ? .lha are pretty handy when you works on os4 to attach, and .txt are good to attach crashlogs.
Re: it is possible to make attaching of .lha and .txt ?
Attaching images appears to work as the following random test shows
Txt can be added with the hidden tag as described http://forum.hyperion-entertainment.biz ... p?f=9&t=72
It wouldn't be my deceision on lha ofcourse but I would say attaching archives might make reading threads more difficult.
kas1e
Post by kas1e »
@broadblues
Dunno, but i already attached few archives in SDK sub-forum, and its not make topic difficult to read after that :) Forum already support zip, so why not add lha , it will be at least logical, because on aos we offten use lha archives.
Deniil
Post by Deniil »
kas1e wrote:Just notice myself few days ago when want to attach some stuff from os4 : i can't attach .lha files, and code of forum say "can't attach .lha". Also as i notice today in some other topic, MickJt also can't attach .txt. It is possible to add ability to attach them ? .lha are pretty handy when you works on os4 to attach, and .txt are good to attach crashlogs.
I just noticed this my and I pretty much exploded with anger how #¢%& stupid a support forum can get. I bit myself in the lip and settled with :evil: "smiley". "Extension txt not supported" when you know crashlogs come as txt. Come on!
Rigo
Post by Rigo »
@Deniil
To save you eating your face, have a look here, and all will become apparent.
So you can paste crashlogs without cluttering up the forums.
Simon
Deniil
Post by Deniil »
@Rigo
Thanks. That also works. But why not adjust the attachment procedure to allow at least txt? And since it allows zip, why not lha?
