Hi all,
Well, after not being able to install Linux Mint 11 on my X1000, I have decided to install Debian DVD iso Wheezy testing, the installation was done successfully. Previously I installed Debian Squeeze, also with success, and wanted to test the effects of Compiz in Squeeze, but I could not make them work. now, I could install Debian Wheezy and run Compiz, you can see it work in this video that I uploaded to Youtube.
http://www.youtube.com/watch?v=LZxJ9If5 ... e=youtu.be
It's just a test, I have yet to investigate the effects confuguracion. Greetings to all.
P.D. - I apologize for the misspelling which can be seen in the video, when I write the word Weezy, Wheezy to be.
regards.
Compiz work with Debian Wheezy
Amiga 1200 / Blizzard 1260 / Mediator 1200 / Voodoo 3000 / 64 Mb / AmigaOS 3.9
Sam Flex 440ep 733 Mhz / AmigaOS 4.1 u 4
AmigaONE X1000
AmigaONE X1000
Re: Compiz work with Debian Wheezy
Good news.Fernecho wrote:Hi all,
regards.
I can confirm Compiz working under Linux Mint 11 as well.
- trevordick
- A-Eon Technology
Good to hear. Well done.
Although, I'm not really a fan of compiz it would be good to add the installation method to the official user guide for others to try out.
I would be grateful if you could provide some simple instructions which I can add to the guide.
Trevor
Trevor
I'm just Breezin'
- tommysammy
How? I can`t get it workthawk wrote:Good news.Fernecho wrote:Hi all,
regards.
I will be back to my X1k by tomorrow and will write up a little installation guide for Linux Mint using LXDE and XFCE window managers.trevordick wrote:Good to hear. Well done.
Trevor
- trevordick
- A-Eon Technology
Thanks.thawk wrote:I will be back to my X1k by tomorrow and will write up a little installation guide for Linux Mint using LXDE and XFCE window managers.
Trevor
I'm just Breezin'
Very nice video.Fernecho wrote: you can see it work in this video that I uploaded to Youtube.
regards.
Simple compositing in LXDE:
1) Install Linux Mint PPC as described in the X1k-Linux manual
2) Install the compositing manager (as SU)
> apt-get install xcompmgr
3) Configure your xsession to use xcompmgr instead of openbox (as SU)
> gedit /etc/xdg/lxsession/Mint-LXDE/autostart
Add the following line:
@xcompmgr -n
4) Restart gdm (as SU)
> /etc/init.d/gdm stop
> /etc/init.d/gdm start
Login again.
5) You should now have transparency effects etc. on your desktop when using tools like screenlets.
@xcompmgr -n
Login again.
Regarding compiz in wheezy
Compiz has been removed recently from the debian wheezy repositories, maybe due to bugs (its marked unstable now).
See the status here http://packages.qa.debian.org/c/compiz.html .
Atm there is no simple procedure to install compiz in wheezy (I do not advice to install experimental or old versions).
As soon as they release a new version in debian testing I will revisit this topic again.
I uploaded a video (http://youtu.be/jZZwWjrVct4) from my Mint PPC system from some weeks ago.
- trevordick
- A-Eon Technology
1. Mint already installedthawk wrote:Simple compositing in LXDE:
@xcompmgr -n
Login again.
2. xcompmgr installs OK
3. Opening a regular terminal and typing SU to enter root then typing> gedit /etc/xdg/lxsession/Mint-LXDE/autostart fails to open the file for edit. However if i open a root terminal I am able to gedit the file and save the changes.
Questions.
When adding @xcompmgr -n to autostart do you have to deactivate any other lines.
Which desktop should I select to start (Mint LXFE, Gnome, etc?)
I would still like to try the Compix effect in MintPPC11 if possible.
Trevor
I'm just Breezin'
