Virtual gadget effects
cha05e90
Post by cha05e90 »
Hello,
this is a re-post of a virtual.gadget quirk form os4coding.net (http://www.os4coding.net/forum/virtual-gadget-quirks) , so I'll give only a short summary here:
While doing an overhaul of AISSview I found that the current public version of virtual.gadget (53.5, Update 1) shows some strange effects, especially when switching from "full view" to "view with scroll bars" due to different sized contents:
v-gadget-1 53.5
v-gadget-1 53.5
v-gadget-2 53.5
v-gadget-2 53.5
Switching back to the original virtual.gadget (52.2) from vanilla OS4.1 everything shows up nicely:
v-gadget 52.2
(74.77 KiB) Downloaded 1096 times
This can be reproduced with AISSview (http://www.os4depot.net/index.php?funct ... viewer.lha) from os4depot - the source code for this application can be found there http://www.os4depot.net/index.php?funct ... er-src.lha, too.
Rigo
Re: Virtual gadget effects
Post by Rigo »
Checking the release notes for virtual.gadget, I see a bug has been fixed which relates to the window backfill, and as such the problem you show here is solved with virtual.gadget 53.6.
Simon
cha05e90
Post by cha05e90 »
Rigo wrote:virtual.gadget 53.6.
Ah, ok. Thanks for that information, Simon - so I'll sit down and wait patiently. :-)
Tested with virtual.gadget V53.6 and it's still faulty, so I'll raise a BZ for it.
Bug #7142 opened.
