Partition Wizard Crash on "Check" [Solved]
I get a crash when using Partition Wizard`s "Check" function on a SFS/0 partition.
Size 512 MB size and blocksize 1024 bytes, formatted with SFS 1.286
Hidden Text - Click to Show :
Dump of context at 0x020D91B0
Trap type: DSI exception
Machine State (raw): 0x0200F030
Machine State (verbose): [ExtInt on] [User] [FPU on] [IAT on] [DAT on]
Temporary stack trace:
#0: in module Kickstart/kernel+0x0003B328 (0x0183B328)
#1: in module Kickstart/kernel+0x0003B464 (0x0183B464)
#2: in module Kickstart/kernel+0x0003B718 (0x0183B718)
#3: in module Kickstart/kernel+0x0001A150 (0x0181A150)
#4: 0x7F70DE58
#5: 0x7F70FD34
#6: 0x7F700380
#7: 0x7F6FF528
#8: 0x7F6FF5E4
#9: 0x7F71FF84
#10: in module Kickstart/dos.library.kmod+0x00022A0C (0x0192878C)
#11: in module Kickstart/kernel+0x000416EC (0x018416EC)
#12: in module Kickstart/kernel+0x0004176C (0x0184176C)
#13: 0x00000000
Crashed process: (0x65E6FC00)
DSI verbose error description: Access not found in hash or BAT (page fault)
Access was a load operation
0: 66A3DDF0 66165A70 7C0903A6 66A45800 66A4DE08 00008010 00008001 CD48BBF8
8: 66A4DE00 66A3DDF2 66A4DE08 66A45DF8 66A3DDF0 66708020 66C75198 66C751E0
16: 66C751C8 66C751B0 0194CBA4 00000078 0000006B 00000065 00000072 66703978
24: 6670AEFC 66704584 66704590 00000000 00000000 66A4DE00 00008003 66A45E00
CR: 53935155 XER: 80000128 CTR: 01818C50 LR: 0183B464
DSISR: 40000000 DAR: CD48BBFC
FP0 : 40F0000000000000 0000000000000000 FF01000400000F00 0000000000000000
FP4 : 0000000000000000 4047666660000000 4033CCCCC0000000 0000000068ADF396
FP8 : 000000100008000B 5001FFFF00CF00EB EA2AEAEA2A2A2A2A 406FE00000000000
FP12: FFF8000000010000 40F0000000000000 0000000000000000 0000000000000000
FP16: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
FP20: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
FP24: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
FP28: 0000000000000000 0000000000000000 0000000000000000 0000000000000000
FPSCR: 82004000
V0 : 00000000000000000000000000000000 00000000000000000000000000000000
V2 : 00000000000000000000000000000000 00000000000000000000000000000000
V4 : 00000000000000000000000000000000 00000000000000000000000000000000
V6 : 00000000000000000000000000000000 00000000000000000000000000000000
V8 : 00000000000000000000000000000000 00000000000000000000000000000000
V10: 00000000000000000000000000000000 00000000000000000000000000000000
V12: 00000000000000000000000000000000 00000000000000000000000000000000
V14: 00000000000000000000000000000000 00000000000000000000000000000000
V16: 00000000000000000000000000000000 00000000000000000000000000000000
V18: 00000000000000000000000000000000 00000000000000000000000000000000
V20: 00000000000000000000000000000000 00000000000000000000000000000000
V22: 00000000000000000000000000000000 00000000000000000000000000000000
V24: 00000000000000000000000000000000 00000000000000000000000000000000
V26: 00000000000000000000000000000000 00000000000000000000000000000000
V28: 00000000000000000000000000000000 00000000000000000000000000000000
V30: 00000000000000000000000000000000 00000000000000000000000000000000
VSCR: 00000000 VRSAVE: 00000000
Dump of context at 0xEFCEE7C0
#4: 0x7F70DE58
#5: 0x7F70FD34
#6: 0x7F700380
#7: 0x7F6FF528
#8: 0x7F6FF5E4
#9: 0x7F71FF84
#13: 0x00000000
FP0 : FFF8000082004000 0000000000000000 FF01000400000F00 0000000000000000
FPSCR: 82004000
V0 : 00000000000000000000000000000000 FF0A0D14FF0C0F16FF0D1017FF0D1017
V2 : FE0100FFFE0100FFFE0100FFFE0103FC FE0100FFFE0100FFFE0100FFFE0103FC
V4 : FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 0AF614EC0CF416EA0DF317E90DF317E9
V6 : FE010CF3FE010EF1FE010FF0FE010FF0 00000000010101010202020203030303
V8 : 00000000000000000000000000000000 00FF00FF00FF00FF00FF00FF01FE03FC
V10: FF0E1118FF0D1017FF0C0F16FF04070C 00000000010101010202020203030303
V12: FE0110EFFE010FF0FE010EF1FE0106F9 00000000000000000000000000000000
V14: 001002120414061608180A1A0C1C0E1E 01000100010001000100010001000100
V16: FFB3B3B3FFB3B3B3FFB3B3B3FFB3B3B3 FF010101FF010101FF010101FF020404
Registers pointing to code:
Trap type: ISI exception
Machine State (raw): 0x10009030
Machine State (verbose): [ExtInt on] [Super] [IAT on] [DAT on]
#0: 0x020E2AB4
Crashed process: reaper.task (0x690E7AA0)
ISI verbose error description: Instruction fetch in non-execute segment
0: 020E2AB4 68D3B060 FFFFFD7F 020E2AB4 021FE330 66C28000 00010000 021FE358
8: 020E2AB4 00000003 021FE52C 021F6866 2A52D372 FDFDF3F7 02006C2C 6FF894D0
16: 68D42EC0 021F6AF6 021F0000 00000001 00000000 00000005 00000000 00000001
24: 00000000 6A3C998A EFCEA510 020E2AB4 68D3B070 01831C48 00000000 00000001
CR: 59355F55 XER: E000FF6F CTR: 0181C890 LR: 020E2AB4
Dump of context at 0xEFE2E7C0
#0: 0x020E2AB4
As you can see the Reaper is going down as well.
I was only able to catch this output using a serial connection, the OS is completely frozen
right after i click on "Check", leaving me no choice than to cold reboot with the case button.
I get this everytime and am not sure if it is because of the partition is actually damaged
(i sometimes get a BAD IDENTIFIER in UBoot right before the kickstart modules load
and even at two times i got a direct halt in UBoot with an error message along the lines
that it cannot find any useable slb, while it works if i turn the miggy on and off again).
I will backup and reformat that partition, but maybe some of you have had similiar problems.
ADDENUM:
It happens with every SFS partition, even one that has been freshly installed and IS EMPTY!
Thank you very much
Evillord68
Re: Partition Wizard Crash on "Check"
Post by Evillord68 »
I have tested Partition Wizard on my Aone SE, there is a naked, Update4 System installed.
On this machine it works.
Evillord68 wrote:I have tested Partition Wizard on my Aone SE, there is a naked, Update4 System installed.
Yes...i should probably cross-link to my other report as i think the two are related.
It seems it`s not the software that is flawed, but the hardware(?)/interrupt(?)/whatever(?) that cause the crash? :-/
Bahaviour/Crash is gone, see here
Thank you ssolie for putting me on the right track
I hope i'm allowed to change my initial title to [Solved]?
Hypex
Re: Partition Wizard Crash on "Check" [Solved]
Post by Hypex »
This looks exactly like I am getting! My HD was giving trouble so brought it closer to IDE card and replaced cable. Has been fine since but when I check it my last 30GB SFS volume freezes PW! Not resolved yet.
But suspect memory is also playing up as Linux won't boot anymore. Get errors about no /init or Uboot doesn't go into kernel.
