AmigaInput
Joeled
AmigaInput
Post by Joeled »
Now when we have Runinuae & EUAE integrated with update 4 it would be really good if there was a way to get whdload games to work with joystick to USB-Adaptor so we can use our old joysticks like Tac2. I bought this one but cant manage to get it to work in amigainput and whdload.
Retrousb
When i try to configure it using amigainput and push the controller top left two buttons get lighted. Would be nice to be able to play whdload games with my Tac2. Its working when i m using Vice64.
Spektro
Re: AmigaInput
Post by Spektro »
I don't have an USB Atari RetroPort adapter so I can't verify if it should work or not. However, I have a Competition Pro USB joystick. I think it has a similar adapter built-in.
Have you tried calibrating it with Windows or Mac OS X? I suspect that the adapter or your joystick is not working correctly.
- Janne Peräaho
zappa2009
Re: AmigaInput
Post by zappa2009 »
Try this -> USB joystick adapter for Atari, Commodore 64, Amiga and CD32 (ob E-bay)
I use it with the CD32 Firmware-File (Yes its flashable !) on my X1000 amd AmigaONE-XE and Linux and Windows-XP
Very nice
