For the life of me I can't find the preference to change my main bootup Workbench background.
Where would that be?
I have found where I could change it for my separate OWB Window Screen I have open but not the main Workbench screen.
tj
What preference to change Workbench background?
- amigasociety
AmigaOne X5000
Amiga A1222 Tabor
AmigaOne X5000
Amiga A1222 Tabor
Re: What preference to change Workbench background?
Prefs/WBPattern.amigasociety wrote:For the life of me I can't find the preference to change my main bootup Workbench background.
- amigasociety
Thank you. I did not see the picture box in that window and kept going right in one eye out the other.nbache wrote:Prefs/WBPattern.amigasociety wrote:For the life of me I can't find the preference to change my main bootup Workbench background.
tj
AmigaOne X5000
Amiga A1222 Tabor
AmigaOne X5000
Amiga A1222 Tabor
Better get your eyes checked, then. They are supposed to be Write-Only
- amigasociety
?tonyw wrote:Better get your eyes checked, then. They are supposed to be Write-Only
tj
AmigaOne X5000
Amiga A1222 Tabor
AmigaOne X5000
Amiga A1222 Tabor
Eyes - write-only: Normal function is for visual stimuli to enter the eyes from the outside, and for nothing to exit from the eyes to the outside. Although of course lyricists have for ages claimed the opposite, i.e. that it is possible to read stuff in a person's eyes. And then there is the matter of tears ...amigasociety wrote:?tonyw wrote:Better get your eyes checked, then. They are supposed to be Write-Only
tj
- amigasociety
Wow, too deep for me.nbache wrote:Eyes - write-only: Normal function is for visual stimuli to enter the eyes from the outside, and for nothing to exit from the eyes to the outside. Although of course lyricists have for ages claimed the opposite, i.e. that it is possible to read stuff in a person's eyes. And then there is the matter of tears ...amigasociety wrote:?tonyw wrote:Better get your eyes checked, then. They are supposed to be Write-Only
tj
Reminds me of what one would talk about like in the pot scene in Animal House.
TJ
AmigaOne X5000
Amiga A1222 Tabor
AmigaOne X5000
Amiga A1222 Tabor
Well, you were the one opening the ball withamigasociety wrote:Wow, too deep for me.
So you had it coming, didn't you?kept going right in one eye out the other.
