Hello,
in SDK53.20 ,the return type of OpenDevice(...) is declared:
1) 'BYTE' in clib/exec_protos.h
2) 'LONG' in interfaces/exec.h
Should they be equal?
OpenDevice() return type discrepancies
- AlfredOne
Amiga500 Kickstart1.3
AmigaONE X1000 - 2GB RAM - Radeon R9-280X 3GB + Radeon HIS4670 1GB DDR3 - AmigaOS4.1
My site: http://project4a.webs.com
- salass00
Re: OpenDevice() return type discrepancies
Not really. <clib/xxx_protos.h> includes are only for legacy M68k programs. <interfaces/xxx.h> files define the new PPC interfaces used by AmigaOS 4.x native programs.Should they be equal?
- AlfredOne
Ok!salass00 wrote:Not really. <clib/xxx_protos.h> includes are only for legacy M68k programs. <interfaces/xxx.h> files define the new PPC interfaces used by AmigaOS 4.x native programs.Should they be equal?
Thank you for clarification.
