small update to SDK (posix's glob/globfree, attached)
kas1e
Post by kas1e »
As we have many posix functions in the SDK already, i think it will worth to add some more functions which already tested and works. There i mean Glob() and GlobFree() functions, which generate pathnames matching a pattern.
Full description of glob() function are here
Full sescription of globfree() function are here
Functions uses from time to time in the unix games/apps (for example in the ports which do i, it was used in the Pentagram, Warzone2100, SuperTuxKart, AssaultCube , Epiar and some others). So having it in SDK will help as plain developers who want linux-unix kind functions, and the same for porters who just want to port one-two games to os4.
The source of the functions done by Frank Wille in 2005 for his posix-compilant library for VBCC, and which with very small changes i adapt for our SDK Changes are related to just adding of:
#ifdef __cplusplus
extern "C" {
#endif
#ifdef __cplusplus
#endif
To include file (to make plain C and C++ works fine with it), as well as some changes in includes and have added at top define __USE_INLINE__. No real source changes here, just some adaptation.
In attach you can found: all the source for those functions (for including it to any .a where most posix functions is stored) , main glob.h include (for put to SDK's includes) , and just as an example libglob.a , which can be used just for tests to see that all of this works. If any real-live examples will necessary, i will upload some small example as well.
glob.zip
glob() and globfree() for SDK
(7.76 KiB) Downloaded 817 times
Slayer
Re: small update to SDK (posix's glob/globfree, attached)
Post by Slayer »
I'm all for this kind of thing!
Now if we can only convince you to release your secret fork() implementation that would be absolutely awesome! ;)
Thanks for the resource kas1e
please excuse the attempt at humor :lol:
salass00
Post by salass00 »
There is a more advanced implementation of glob()/globfree() in libaos4util in amicygnix SDK. This one is BSD licensed and supports also GNU extensions.
kas1e
Post by kas1e »
@salas00
The better version we will have in newlib, the better :) Its just sometime some apps from unix world want it, and will be nice to have them by default, especially if they implemented right.
