Sam440ep Linux
Sam440ep Linux
vox
Re: Debian Squeeze on Sam440ep-Flex
Post by vox »
That is just great, can you please make some step by step manual?
Future MOS user pon SAM460ex
I can host the CD iso. :)
Spectre660 wrote:Thanks.
PM sent.
xeno74 wrote:I can host the CD iso. :)
Thank you!
Here you are: Debian-Linux_Sam440ep_Bussiness_Card_Install.iso
My custom Debian Squeeze Net install CD for Sam440ep-Flex
Have a look at the Acube install file that I have added to the CD about hard disk partitions .
This setup assumes that you are using Acube's parthenepe as the bootloader.
Also after installation and before you start the Linux Gui you need to manually create the following file
and add the following to it or things will be unstable. The fresh installation will boot into Linux
so the edit can be done from the command line before the gui is started.
The install script fails to add it for some reason so you must do it manually.
/etc/modprobe.d/drm-disable
install drm /bin/true
install radeon /bin/true
install agpgart /bin/true
after this is done then the gui can be started by typing startx
Belxjander
Post by Belxjander »
@Spectre660: Well I hope to get a working system bootstrap working from my own Sam440ep-Flex,
maybe after that I can work up an updated PPC kernel build for the 440
But I am not hopefull of getting a working Linux installed first
