Hi just want to know where can I get/buy a new cpu heatsink+fan, 'cos the one I have is not wotking fine and thus A1-XE freezes (bad cooling I suspect)
Can someone say me some brands/models for such heatsink+fan for A1-XE mb/cpu?
My cpu is 7455X933 (clocked @800)
TIA
A1-XE cpu heatsink+fan
Re: A1-XE cpu heatsink+fan
I seem to recall a few ppl installed a Zalman heatsink/fan unit on their A1's.
The Zalman CNPS7000B-ALCU 92mm 2 Ball Cooling Fan isn't expensive & should do the job, I would think.
- javierdlr
sundown wrote:I seem to recall a few ppl installed a Zalman heatsink/fan unit on their A1's.
The Zalman CNPS7000B-ALCU..
THX will look onto this heatsink/cooler.
