ppp-ethernet.device issue
kas1e
Post by kas1e »
Hi all os4 developers ! Dunno if my issues related to pegasos2 only, or its general problem, but just in case i put it in general forum.
So, In the last 2 years with 4.1 / update1 / update2 i have an always-reproducable issue with ppp-ethernet.device when i use D-Link 2500U modem directly (i.e. via Dialers and co) on my peg2. For any users who will want to answer in that topic, like "use router" - yes, my current workoround its just i use static ips + some route + winxp as main machine for connect to internet (via the same D-Link 2500U), but as bug is still here, i still it worth to report. I also report that on Aw.net few times, and one time directly to Olsen , but i do not know if it was approved, and if it already in the bug-report base, and if Olsen read it at all.
To reproduce:
That, how looks like my internet connection script:
# PROGDIR:Connections/inet.conn
# File generated by Dialer 53.2 (3.10.2009)
# On Среда, 24-Мар-10 at 14:08:28
interface="PPPoE"
device="via-rhine.device"
pppoe=yes
service="inet"
sendid=off
login="szt"
password="A23C067503ED3DA12880A427914F0FD7"
provider="inet"
It called "inet.conn", and have "inet.conn.info", in which:
Default tool: System:Internet/Dialer
Stack size: 32.768
Tool types: MODE=OPEN
Nextly, i click on that icon, it connects, spawn me information window (how many bytes are transfered, activity and so on). All looks fine at that stage, so, i trying to use internet. Run OWB, go to some site - all is fine. Press on some topic, all is fine. Then go to some other site and have crash in the ppp-ethernet.device. Crash always the same, with the same DSI and crashlog, and happens always after 2-5 minuts of internet usage after connection is happens.
I tryed to save all the possible info from. For first i show you screenshot of how looks dialer-info window, GR and memguard/shashimi output at one time: here is that screenshot.
For second, i show you information about that DSL modem (d-link 2500u) which i grab as screenshot when point browser on DSL and get main statistic about (maybe it will helps too): here is that screenshot.
And the last, and the most important, classic GR log:
Hidden Text - Click to Show :
Crash log for task "ppp-ethernet.device"
Generated by GrimReaper 53.2
Crash occured in module kernel at address 0x01819F4C
Register dump:
0: 64B8E968 63289EA0 00000000 632C4A14 632C4A14 00008000 021A376C 021A3790
8: 00000002 00000000 00000001 633E1A54 000F4240 00000000 CCCCCCCD 64E94A48
16: FBFFFFFF 667B78FC 00008864 00000000 08000000 80000000 10000000 04000000
24: DC000000 667B78B8 40000000 40000000 632C4A00 020A2BC8 667B7840 67E64E4C
0: 0 0 0 0
4: 0 0 0 0
8: 0 0 0 0
12: 0 0 0 0
16: 0 0 0 0
20: 0 0 0 0
24: 0 0 0 0
28: 0 0 0 0
FPSCR (Floating Point Status and Control Register): 0x00000000
Machine State (msr) : 0x02005030
Condition (cr) : 0x48004024
Instruction Pointer (ip) : 0x01819F4C
Xtended Exception (xer) : 0x20000000
Count (ctr) : 0x01819F58
Link (lr) : 0x0181F2F8
DSI Status (dsisr) : 0x42000000
Data Address (dar) : 0x00000004
680x0 emulated registers:
FPU0: 0 0 0 0
FPU4: 0 0 0 0
Symbol info:
Instruction pointer 0x01819F4C belongs to module "kernel" (HUNK/Kickstart)
Stack trace:
native kernel module kernel+0x00019f4c
module DEVS:Networks/ppp-ethernet.device at 0x7F9F85C0 (section 5 @ 0x165A0)
module DEVS:Networks/ppp-ethernet.device at 0x7F9E3E10 (section 5 @ 0x1DF0)
native kernel module dos.library.kmod+0x0001b524
native kernel module kernel+0x0003ef08
native kernel module kernel+0x0003ef88
PPC disassembly:
01819f44: 812b0000 lwz r9,0(r11)
01819f48: 800b0004 lwz r0,4(r11)
*01819f4c: 90090004 stw r0,4(r9)
01819f50: 7d635b78 mr r3,r11
01819f54: 4e800020 blr
System information:
CPU
Model: Motorola MPC 7447/7457 Apollo V1.1
CPU speed: 999 MHz
FSB speed: 133 MHz
Extensions: performancemonitor altivec
Machine
Machine name: Pegasos II
Memory: 1048576 KB
Extensions: bus.pci bus.agp
Expansion buses
PCI/AGP
00:00.0 Vendor 0x11AB Device 0x6460
00:01.0 Vendor 0x1106 Device 0x3044
Range 0: 80000000 - 80000800 (MEM)
Range 1: 00001080 - 00001100 (IO)
00:0C.0 Vendor 0x1106 Device 0x8231
00:0C.1 Vendor 0x1106 Device 0x0571
Range 0: 00001000 - 00001008 (IO)
Range 1: 00001008 - 0000100C (IO)
Range 2: 00001010 - 00001018 (IO)
Range 3: 00001018 - 0000101C (IO)
Range 4: 00001020 - 00001030 (IO)
00:0C.2 Vendor 0x1106 Device 0x3038
Range 4: 00001040 - 00001060 (IO)
00:0C.3 Vendor 0x1106 Device 0x3038
Range 4: 00001060 - 00001080 (IO)
00:0C.4 Vendor 0x1106 Device 0x8235
00:0C.5 Vendor 0x1106 Device 0x3058
Range 0: 00001100 - 00001200 (IO)
Range 1: 00001030 - 00001034 (IO)
Range 2: 00001030 - 00001034 (IO)
00:0C.6 Vendor 0x1106 Device 0x3068
Range 0: 00001200 - 00001300 (IO)
00:0D.0 Vendor 0x1106 Device 0x3065
Range 0: 00001300 - 00001400 (IO)
Range 1: 80000800 - 80000900 (MEM)
01:00.0 Vendor 0x11AB Device 0x6460
01:08.0 Vendor 0x1002 Device 0x5960
Range 0: C0000000 - C8000000 (PREF.MEM)
Range 1: 00001000 - 00001100 (IO)
Range 2: C8000000 - C8010000 (MEM)
01:08.1 Vendor 0x1002 Device 0x5940
Range 0: D0000000 - D8000000 (PREF.MEM)
Range 1: C8010000 - C8020000 (MEM)
Libraries
0x68c03dc8: Amiga-1251.charset V52.1
0x68c03ec8: russian_Amiga-1251.language V52.1
0x021b69a6: exec.library V53.12
0x6ff85624: vilintuisup.library V0.9
0x6ff854f8: cgxvideo.library V42.1
0x6ff660e0: cybergraphics.library V43.0
0x668387f4: amigaguide.datatype V53.2
0x633635e4: amigaguide.library V53.2
0x633e87e8: dopus.library V22.40
0x6526de10: expat.library V53.3
0x652645a8: pthreads.library V53.7
0x668546c0: fuelgauge.gadget V53.7
0x6526d2d0: texteditor.gadget V53.15
0x6685d5a8: radiobutton.gadget V53.8
0x66854e40: slider.gadget V53.11
0x66854800: getfont.gadget V53.6
0x66854580: getfile.gadget V53.7
0x66854080: arexx.class V53.3
0x6fdb76c8: clicktab.gadget V53.34
0x663cdcf0: checkbox.gadget V53.8
0x6635b1d0: requester.class V53.16
0x663cda70: space.gadget V53.4
0x663ce508: chooser.gadget V53.14
0x663cd7f0: penmap.image V53.5
0x663cd570: bitmap.image V53.6
0x67bdc630: integer.gadget V53.9
0x663ea384: asl.library V53.38
0x66a13878: listbrowser.gadget V53.38
0x665cf640: string.gadget V53.15
0x66a172c8: popupmenu.class V53.2
0x665d03c8: popupmenu.library V53.5
0x67bdcc70: scroller.gadget V53.10
0x67bdc130: jpeg.datatype V53.5
0x681b0a30: mathieeedoubbas.library V52.1
0x682f3104: usergroup.library V4.30
0x67f3c320: bsdsocket.library V4.292
0x681b20bc: textclip.library V52.2
0x683f53fc: xadmaster.library V13.1
0x68658134: xpkmaster.library V5.2
0x68b61a50: button.gadget V53.12
0x68b61b90: glyph.image V53.3
0x683e51e0: window.class V53.34
0x68b61910: label.image V53.11
0x689467e8: layout.gadget V53.17
0x689469b0: bevel.image V53.6
0x68b61690: drawlist.image V53.3
0x68b615f0: ilbm.datatype V53.1
0x68b61190: png.datatype V53.4
0x68bcd864: picture.datatype V53.3
0x68c5d9d8: timezone.library V53.6
0x68c28e38: application.library V53.10
0x68bcf24c: ft2.library V53.1
0x6ff0708c: workbench.library V53.25
0x68cfdc58: emulation.library V41.446
0x68c27260: Picasso96API.library V2.356
0x68b75b80: gadtools.library V53.4
0x6ffa8cac: commodities.library V53.1
0x68cfc940: datatypes.library V53.4
0x6ff91e44: png.iconmodule V53.1
0x68c220cc: icon.library V53.12
0x68c036c8: version.library V53.3
0x68c68a40: iffparse.library V53.1
0x6fde98cc: locale.library V53.3
0x6ff6041c: diskfont.library V53.4
0x6ff94c18: petunia.library V53.3
0x6ff94a98: diskcache.library V3.30
0x6fdd6614: dos.library V53.58
0x6ff858f4: usbprivate.library V53.6
0x6fe8233c: massstorage.usbfd V53.6
0x6fe822a8: bootkeyboard.usbfd V52.3
0x6fe82228: bootmouse.usbfd V53.1
0x6ff857ac: hub.usbfd V53.6
0x6ff856fc: usbresource.library V53.6
0x6ff95658: hunk.library V53.3
0x6ff94354: elf.library V53.12
0x6ff894d0: intuition.library V53.30
0x6ff43150: rtg.library V41.4340
0x6ff908a0: ATIRadeon.chip V53.19
0x6ff90824: PCIGraphics.card V53.1
0x6ffaaa10: keymap.library V53.1
0x6ff86c40: layers.library V53.5
0x6ffb8420: graphics.library V53.4
0x6ff95184: nonvolatile.library V52.1
0x6ffab498: newlib.library V53.10
0x6ff961ac: utility.library V53.1
0x6ffaa0a8: expansion.library V53.1
0x6838f58e: rexxsyslib.library V45.7 (Legacy)
Devices
0x632c2b14: ppp-ethernet.device V52.2
0x67fae988: via-rhine.device V53.4
0x68bcf960: diskimage.device V52.65
0x6ff86dd0: usbsys.device V53.6
0x6ff95b90: uhci.usbhcd V53.7
0x6ff90ba4: peg2ide.device V53.3
0x6ffa8628: console.device V53.1
0x6ff8f3f0: ramdrive.device V52.6
0x6ffaac5c: input.device V53.3
0x6ffa8314: keyboard.device V53.2
0x6ffaa774: gameport.device V52.1
0x6ff8f2d0: timer.device V53.1
Tasks
ClickToFront (Waiting)
Stack: 0x663ac004 - 0x663bbffc, pointer @ 0x663bba80 (Cookie OK)
State: Process (Waiting)
input.device (Waiting)
Stack: 0x6ff4b000 - 0x6ff5b000, pointer @ 0x6ff5af00 (Cookie OK)
State: Task (Waiting)
SFS DosList handler (Waiting)
Stack: 0x6fd80004 - 0x6fd81ffc, pointer @ 0x6fd81f20 (Cookie OK)
USB stack (Waiting)
Stack: 0x6fec3000 - 0x6fec7000, pointer @ 0x6fec6f20 (Cookie OK)
UHCI Controller Task Unit 0 (Waiting)
Stack: 0x6fe6e000 - 0x6fe76000, pointer @ 0x6fe75f00 (Cookie OK)
Signals: SigRec 0xbe001000, SigWait 0x00000000
UHCI Controller Task Unit 1 (Waiting)
Stack: 0x6fe1e000 - 0x6fe26000, pointer @ 0x6fe25f00 (Cookie OK)
via-rhine.device [0 (Waiting)
Stack: 0x67e6b004 - 0x67e7affc, pointer @ 0x67e7af10 (Cookie OK)
Signals: SigRec 0xf0008000, SigWait 0x00000000
page_sweep (Waiting)
Stack: 0x6fe7a004 - 0x6fe81ffc, pointer @ 0x6fe81e70 (Cookie OK)
peg2ide.device - chip 0 port 0 (Waiting)
Stack: 0x6fe9e000 - 0x6fea6000, pointer @ 0x6fea5f30 (Cookie OK)
MainIPC0 (Waiting)
Stack: 0x6835f004 - 0x6836effc, pointer @ 0x6836ef00 (Cookie OK)
Signals: SigRec 0x40000100, SigWait 0x00000000
DH3 (Waiting)
Stack: 0x6953e004 - 0x6953fffc, pointer @ 0x6953feb0 (Cookie OK)
DH4 (Waiting)
Stack: 0x69544004 - 0x69545ffc, pointer @ 0x69545eb0 (Cookie OK)
JXF:DH2 (Waiting)
Stack: 0x6fd86004 - 0x6fd87ffc, pointer @ 0x6fd87de0 (Cookie OK)
Signals: SigRec 0xc0000100, SigWait 0x20000000
DH1 (Waiting)
Stack: 0x6fd7a004 - 0x6fd7bffc, pointer @ 0x6fd7beb0 (Cookie OK)
reaper.task (Waiting)
Stack: 0x68f9e004 - 0x68fa5ffc, pointer @ 0x68fa5ea0 (Cookie OK)
RAM (Waiting)
Stack: 0x694c6004 - 0x694cdffc, pointer @ 0x694cdca0 (Cookie OK)
ICD1 (Waiting)
Stack: 0x68182004 - 0x68191ffc, pointer @ 0x68191f20 (Cookie OK)
ICD0 (Waiting)
Stack: 0x68107004 - 0x68116ffc, pointer @ 0x68116f20 (Cookie OK)
DH0 (Waiting)
Stack: 0x6fd6e004 - 0x6fd6fffc, pointer @ 0x6fd6fed0 (Cookie OK)
Signals: SigRec 0xa8000100, SigWait 0x00000000
BOOT (Waiting)
Stack: 0x6fd74004 - 0x6fd75ffc, pointer @ 0x6fd75ed0 (Cookie OK)
pager (Waiting)
Stack: 0x68f7a004 - 0x68f99ffc, pointer @ 0x68f99f00 (Cookie OK)
ENV (Ready)
Stack: 0x69550004 - 0x69551ffc, pointer @ 0x69551da0 (Cookie OK)
Signals: SigRec 0x80000000, SigWait 0x80000100
State: Process (Ready)
IDF2 (Ready)
Stack: 0x6826c004 - 0x6827bffc, pointer @ 0x6827bed0 (Cookie OK)
Signals: SigRec 0xa8000100, SigWait 0x20000000
IDF3 (Ready)
Stack: 0x682b9004 - 0x682c8ffc, pointer @ 0x682c8ed0 (Cookie OK)
IDF0 (Ready)
Stack: 0x681df004 - 0x681eeffc, pointer @ 0x681eeed0 (Cookie OK)
IDF1 (Ready)
Stack: 0x68230004 - 0x6823fffc, pointer @ 0x6823fed0 (Cookie OK)
dos_lock_handler (Waiting)
Stack: 0x6ff19004 - 0x6ff1affc, pointer @ 0x6ff1af10 (Cookie OK)
dos_nbmd_process (Waiting)
Stack: 0x6ff1f004 - 0x6ff20ffc, pointer @ 0x6ff20f20 (Cookie OK)
CON (Waiting)
Stack: 0x694f6004 - 0x694fdffc, pointer @ 0x694fdde0 (Cookie OK)
RAW (Waiting)
Stack: 0x694e2004 - 0x694e9ffc, pointer @ 0x694e9de0 (Cookie OK)
CON (Waiting)
Stack: 0x68fba004 - 0x68fc1ffc, pointer @ 0x68fc1de0 (Cookie OK)
AUDIO (Waiting)
Stack: 0x67fd5004 - 0x67fe4ffc, pointer @ 0x67fe4ec0 (Cookie OK)
CON (Waiting)
Stack: 0x68c30004 - 0x68c3fffc, pointer @ 0x68c3fde0 (Cookie OK)
KingCON DOS-process (Waiting)
Stack: 0x66557004 - 0x66566ffc, pointer @ 0x66566ec0 (Cookie OK)
CON (Waiting)
Stack: 0x6656d004 - 0x6657cffc, pointer @ 0x6657ced0 (Cookie OK)
Stack: 0x66460004 - 0x6646fffc, pointer @ 0x6646fec0 (Cookie OK)
CON (Waiting)
Stack: 0x66497004 - 0x664a6ffc, pointer @ 0x664a6ed0 (Cookie OK)
Stack: 0x66320004 - 0x6632fffc, pointer @ 0x6632fec0 (Cookie OK)
CON (Waiting)
Stack: 0x6633f004 - 0x6634effc, pointer @ 0x6634eed0 (Cookie OK)
Stack: 0x6688f004 - 0x6689effc, pointer @ 0x6689eec0 (Cookie OK)
Stack: 0x65c0b004 - 0x65c1affc, pointer @ 0x65c1aec0 (Cookie OK)
CON (Waiting)
Stack: 0x668be004 - 0x668cdffc, pointer @ 0x668cded0 (Cookie OK)
CON (Waiting)
Stack: 0x65c4c004 - 0x65c5bffc, pointer @ 0x65c5bed0 (Cookie OK)
Signals: SigRec 0x60000100, SigWait 0x00000000
Stack: 0x63411004 - 0x63420ffc, pointer @ 0x63420ec0 (Cookie OK)
CON (Waiting)
Stack: 0x63368004 - 0x63377ffc, pointer @ 0x63377ed0 (Cookie OK)
Stack: 0x67c05004 - 0x67c14ffc, pointer @ 0x67c14ec0 (Cookie OK)
Stack: 0x62a04004 - 0x62a13ffc, pointer @ 0x62a13ec0 (Cookie OK)
CON (Waiting)
Stack: 0x62a23004 - 0x62a32ffc, pointer @ 0x62a32ed0 (Cookie OK)
Stack: 0x6514a004 - 0x65159ffc, pointer @ 0x65159ec0 (Cookie OK)
CON (Waiting)
Stack: 0x659cd004 - 0x659dcffc, pointer @ 0x659dced0 (Cookie OK)
URL (Waiting)
Stack: 0x68020004 - 0x6809affc, pointer @ 0x68097c30 (Cookie OK)
RANDOM (Waiting)
Stack: 0x67f95004 - 0x67fa4ffc, pointer @ 0x67fa4ef0 (Cookie OK)
CON (Waiting)
Stack: 0x67c45004 - 0x67c54ffc, pointer @ 0x67c54ed0 (Cookie OK)
console.device (Waiting)
Stack: 0x6feff000 - 0x6ff07000, pointer @ 0x6ff06f70 (Cookie OK)
Signals: SigRec 0xf0000000, SigWait 0x00000000
IPC0 (Waiting)
Stack: 0x6837b004 - 0x6838affc, pointer @ 0x6838aed0 (Cookie OK)
Signals: SigRec 0x00010100, SigWait 0x00000000
diskimage.device unit 6 (Waiting)
Stack: 0x682dd004 - 0x682f0ffc, pointer @ 0x682f0d10 (Cookie OK)
diskimage.device unit 3 (Waiting)
Stack: 0x68299004 - 0x682acffc, pointer @ 0x682acd10 (Cookie OK)
diskimage.device unit 2 (Waiting)
Stack: 0x6824c004 - 0x6825fffc, pointer @ 0x6825fd10 (Cookie OK)
diskimage.device unit 1 (Waiting)
Stack: 0x6820c004 - 0x6821fffc, pointer @ 0x6821fd10 (Cookie OK)
Stack: 0x681b7004 - 0x681caffc, pointer @ 0x681cad10 (Cookie OK)
Stack: 0x68153004 - 0x68166ffc, pointer @ 0x68166d10 (Cookie OK)
Stack: 0x680d8004 - 0x680ebffc, pointer @ 0x680ebd10 (Cookie OK)
RexxMaster [] (Waiting)
Stack: 0x67db7004 - 0x67dc6ffc, pointer @ 0x67dc6f50 (Cookie OK)
TEXTCLIP (Waiting)
Stack: 0x68004004 - 0x68013ffc, pointer @ 0x68013eb0 (Cookie OK)
compose.task (Ready)
Stack: 0x66fa9000 - 0x66fb1000, pointer @ 0x66fb0f30 (Cookie OK)
Signals: SigRec 0x00000021, SigWait 0x00000020
State: Task (Ready)
Workbench [Workbench] (Ready)
Stack: 0x67be1004 - 0x67bf0ffc, pointer @ 0x67bf0e80 (Cookie OK)
Stack: 0x66a32004 - 0x66a41ffc, pointer @ 0x66a41f00 (Cookie OK)
Stack: 0x6690a004 - 0x66919ffc, pointer @ 0x66919db0 (Cookie OK)
ContextMenus Command Dispatcher [ContextMenus Command Dispatcher] (Waiting)
Stack: 0x6680e004 - 0x6681dffc, pointer @ 0x6681df40 (Cookie OK)
texteditor.gadget Clipboard Server (Waiting)
Stack: 0x65160004 - 0x6516fffc, pointer @ 0x6516ff00 (Cookie OK)
dopus_hotkeez (Waiting)
Stack: 0x629d9000 - 0x629db000, pointer @ 0x629daf20 (Cookie OK)
Stack: 0x66583004 - 0x66592ffc, pointer @ 0x66592f40 (Cookie OK)
dopus_clock (Waiting)
Stack: 0x629dd000 - 0x629df000, pointer @ 0x629ded10 (Cookie OK)
RinghioServer (Ready)
Stack: 0x668dd004 - 0x668fcffc, pointer @ 0x668fc7a0 (Cookie OK)
Signals: SigRec 0xd8001000, SigWait 0x10000000
DirectoryOpus (Ready)
Stack: 0x62a42004 - 0x62ac1ffc, pointer @ 0x62ac12b0 (Cookie OK)
Signals: SigRec 0x5c008000, SigWait 0x06000000
hub.usbfd (Waiting)
Stack: 0x6fdca004 - 0x6fdd1ffc, pointer @ 0x6fdd1f10 (Cookie OK)
hub.usbfd (Waiting)
Stack: 0x6fdbe004 - 0x6fdc5ffc, pointer @ 0x6fdc5f10 (Cookie OK)
SMI Handler Process (Waiting)
Stack: 0x68cd2004 - 0x68ce1ffc, pointer @ 0x68ce1f40 (Cookie OK)
Signals: SigRec 0x00001000, SigWait 0x00000000
DST watcher (Waiting)
Stack: 0x68abc004 - 0x68acbffc, pointer @ 0x68acbf20 (Cookie OK)
datatypes.library (Waiting)
Stack: 0x68a64004 - 0x68a73ffc, pointer @ 0x68a73f10 (Cookie OK)
USB stack Process (Waiting)
Stack: 0x683c7004 - 0x683d6ffc, pointer @ 0x683d6ee0 (Cookie OK)
TCP/IP Log (Waiting)
Stack: 0x67f48004 - 0x67f57ffc, pointer @ 0x67f57f00 (Cookie OK)
ConClip (Waiting)
Stack: 0x67e37004 - 0x67e46ffc, pointer @ 0x67e46eb0 (Cookie OK)
Background CLI [c:awin] (Waiting)
Stack: 0x67d5f004 - 0x67d6effc, pointer @ 0x67d6ec50 (Cookie OK)
Background CLI [work:debug/memguard/MemGuard] (Waiting)
Stack: 0x67ceb004 - 0x67cfaffc, pointer @ 0x67cfaea0 (Cookie OK)
Signals: SigRec 0x0000f000, SigWait 0x00000100
RAWBInfo (Waiting)
Stack: 0x663f2004 - 0x66401ffc, pointer @ 0x66401ec0 (Cookie OK)
DefIcons (Waiting)
Stack: 0x664ba004 - 0x664c9ffc, pointer @ 0x664c9dc0 (Cookie OK)
ASYNCWB (Waiting)
Stack: 0x664d7004 - 0x664e6ffc, pointer @ 0x664e6e70 (Cookie OK)
Stack: 0x68b60000 - 0x68b60fa0, pointer @ 0x68b60f10 (Cookie OK)
Shell Process [] (Waiting)
Stack: 0x65c2a004 - 0x65c39ffc, pointer @ 0x65c39bd0 (Cookie OK)
Signals: SigRec 0x00000100, SigWait 0x80000000
Stack: 0x67f24004 - 0x67f33ffc, pointer @ 0x67f33de0 (Cookie OK)
Signals: SigRec 0xf8003000, SigWait 0x00000100
ramlib (Waiting)
Stack: 0x68cc4004 - 0x68ccdffc, pointer @ 0x68ccdf20 (Cookie OK)
dopus_arbiter (Waiting)
Stack: 0x628fe004 - 0x6297dffc, pointer @ 0x6297df00 (Cookie OK)
ContextMenus [] (Waiting)
Stack: 0x66366004 - 0x66375ffc, pointer @ 0x66375c50 (Cookie OK)
Signals: SigRec 0xe0001000, SigWait 0x00000100
Background CLI [work:debug/sashimi/Sashimi] (Waiting)
Stack: 0x67ca6004 - 0x67cb5ffc, pointer @ 0x67cb5a20 (Cookie OK)
Signals: SigRec 0x6000f000, SigWait 0x00000100
AmiDock (Waiting)
Stack: 0x66951004 - 0x66960ffc, pointer @ 0x669609b0 (Cookie OK)
Signals: SigRec 0x7f40d000, SigWait 0x00000000
« IPrefs » (Waiting)
Stack: 0x68bd4004 - 0x68be3ffc, pointer @ 0x68be3530 (Cookie OK)
Signals: SigRec 0x0000f000, SigWait 0x40000100
SGrab (Waiting)
Stack: 0x65aa4004 - 0x65ab3ffc, pointer @ 0x65ab3d20 (Cookie OK)
Signals: SigRec 0xc0007000, SigWait 0x00000100
TCP/IP Superserver [TCP/IP Superserver] (Waiting)
Stack: 0x67f08004 - 0x67f17ffc, pointer @ 0x67f17a00 (Cookie OK)
Signals: SigRec 0xd0000080, SigWait 0x00000100
System:Internet/Dialer (Waiting)
Stack: 0x63473004 - 0x63482ffc, pointer @ 0x63482710 (Cookie OK)
Signals: SigRec 0xfe001000, SigWait 0x00000000
TCP/IP Control (Waiting)
Stack: 0x67eec004 - 0x67efbffc, pointer @ 0x67efbdc0 (Cookie OK)
Signals: SigRec 0xf8009080, SigWait 0x00000000
ppp-ethernet.device (Crashed)
Stack: 0x6327a004 - 0x63289ffc, pointer @ 0x63289ea0 (Cookie OK)
Signals: SigRec 0xdc000000, SigWait 0xc8000000
State: Process (Crashed)
Picasso96 (Waiting)
Stack: 0x68b8f004 - 0x68b9effc, pointer @ 0x68b9edb0 (Cookie OK)
dialer animation server 1 (Waiting)
Stack: 0x633f4004 - 0x63403ffc, pointer @ 0x63403e50 (Cookie OK)
Signals: SigRec 0x8000f000, SigWait 0x00000100
dos_signal_server (Waiting)
Stack: 0x6ff25004 - 0x6ff26ffc, pointer @ 0x6ff26f10 (Cookie OK)
Signals: SigRec 0x0000e000, SigWait 0x00000000
ramlib.support (Waiting)
Stack: 0x68cb6004 - 0x68cbfffc, pointer @ 0x68cbff10 (Cookie OK)
Signals: SigRec 0x80004000, SigWait 0x00000100
dos_filedir_notify (Waiting)
Stack: 0x6fda2004 - 0x6fda5ffc, pointer @ 0x6fda5ad0 (Cookie OK)
Signals: SigRec 0x40000000, SigWait 0x00000000
dos_appdir_server (Waiting)
Stack: 0x6ff2b004 - 0x6ff2cffc, pointer @ 0x6ff2ccc0 (Cookie OK)
idle.task (Ready)
Stack: 0x6ff5f000 - 0x6ff60000, pointer @ 0x6ff5ffd0 (Cookie OK)
State: Task (Ready)
Please, take a look at this, and i can help with all possibly testings and so on. You also can send me debug version of ppp-ethernet.device and can grab GR with normal offsets.
Maybe its all of course in the internal bug-tracker already, but maybe not. So i think its worth to mention one more time here.
Elwood
Re: ppp-ethernet.device issue
Post by Elwood »
If I look at this page about the Dlink 2500U, it says it is a modem-router so, AFAIK it must not be used with Dialer. :? I mean Dialer should be used with modem devices like this one.
Philippe "Elwood" Ferrucci
Sam460 owner
AmigaOS 4 betatester
kas1e
Post by kas1e »
As it already works with this device (and i can connect to internet and use it for a while), and the big part of russia use those modems as default on their winxp/linux/macintoshes by plain and the same by logic "dialers", i assume the bug still should be fixed (By GR it looks like some NULL-Pointer access). I mean if device already start to works, and crashes after a while - then it can works, just crashes because of some bug in ppp-ethernet.device. If ppp-ethernet.device not support something, then just need to skip it from the code , and if it just some broken handling of something, then need to fix the code itself. Anyone from os4developer team can build debug version of ppp-ethernet.device, and i can found by addr2line the code where it crashes.
Hypex
Post by Hypex »
Elwood wrote:I mean Dialer should be used with modem devices like
What's the difference? Thay both look like 1 port ADSL2+ modems to me! :-?
Hypex
Post by Hypex »
kas1e wrote:As it already works with this device
This looks like a standard one port ADSL modem router connected by Ethernet? If that is the case the Dialer certainly should not be used! Unless you speciifcally need to dial in to it. But the modem should contain your user/pass needed for ADSL connection and connect to the computer using a simple Ethernet setup with DHCP. Does it work if you try setting it up as a LAN connection from the Wizard?
Or do you actually need PPPoE? But I agree a crash shouldn't happen. Even with an invalld setup.
Elwood
Post by Elwood »
Oh yes, you're right.
modem-only probably don't exist anymore anyway...
Sam460 owner
kas1e
Post by kas1e »
@Hypex
I already found some workorounds which works. But the post its exactly about "crash should not happens at all even in anvalid setup" (while its not invalid setup, its the same as i use the same modem on winxp/linux, with their dialer kind programms). So its more not like "how to make my modem works without using a dialer", but "aos4 component have some bug which need to fix to make aos4 better and working in all possible variants for end users".
@elwood
Can you please fill bug-report on bugzilla with all the info i provide ? (or you already did ?)
Hypex
Post by Hypex »
@kas1e
I see your point. I missed making a point that in both a valid and invalid setup it shouldn't crash. But I haven't used PPPoE myself so can see now why the Dialer is needed, The a1serial.device is also suspect as this can drop out after a few minutes. I wonder if this is all related to Roadhow internals.
Examing the log the PPP device task was calling an Exec function (module kernel) and it looks like it was manipulating a node. Or rather lack thereof. :-)
Rigo
Post by Rigo »
@kas1e
The link to that crashlog no longer works, perhaps you could embed it in the report( with the hidden tag) so that when, or if, someone gets to look at this, they can at least access the information.
Simon
samo79
Post by samo79 »
Rigo wrote:@kas1e
Simon
Mmm here I can load it without any problem, i will repost his log above:
* crash log removed and pasted into the OP comment * Rigo
