Void Linux
Re: Void Linux
xeno74 wrote: Tue Oct 12, 2021 10:29 am With xbps-install -Su you can update all packages.
Thanks! Does xbps 'archive' the downloaded packages on HD? If yes, is there some way to do a cleanup, just like with apt?
BTW, I tested the GTK+ Pipe Viewer for YouTube on Void today. It works well and it is a good alternative way to watch YouTube videos.
How did you install it? Is it available also for MintPPC?
Edit: I was able to install it to Void with the following command:
sudo xbps-install -S pipe-viewer
But also I have the problem that VLC opens and closes itself if trying to run videos. But copying the link with ViewTube and running it with VLC from terminal works normally (so, this is not a graphics board issue).
Re: Void Linux
Roland wrote: Tue Oct 12, 2021 3:22 pm Thanks! Does xbps 'archive' the downloaded packages on HD? If yes, is there some way to do a cleanup, just like with apt?
Yes, it downloads the packages on the HD. It's possible to remove packages from /var/cache/xbps manually.
Roland wrote: Tue Oct 12, 2021 3:22 pm How did you install it? Is it available also for MintPPC?
I installed it with "xbps-install gtk-straw-viewer". I haven't found it in Debian based distributions yet.
Re: Void Linux
Roland wrote: Tue Oct 12, 2021 3:22 pm But also I have the problem that VLC opens and closes itself if trying to run videos. But copying the link with ViewTube and running it with VLC from terminal works normally (so, this is not a graphics board issue).
It works with VLC with the latest Void img on my X5000. Maybe you need to configure VLC.
Amiguy
Re: Void Linux
Post by Amiguy »
xeno74 wrote: Tue Oct 12, 2021 3:08 pm
Amiguy wrote: Tue Oct 12, 2021 1:27 pm Very interesting ! I installed Pipe-viewer, but am not able to view the videos. When I select a video in Pipe-viewer, VLC opens in full screen, then closes without playing the video. How to assign the video to Interweb?
(Sorry, apparently I am no longer allowed to attach a screenshot ...)
Which graphics card is installed in your X5000?
Radeon Sapphire R7 250X
Re: Void Linux
Amiguy wrote: Tue Oct 12, 2021 5:30 pm Radeon Sapphire R7 250X
Unfortunately you can't use hardware acceleration for videos and games. You can try to tweak the VLC settings. Please try to configure VLC.
Video playback and hardware 3D acceleration work well with RadeonHD 4xxx, 5xxx, and 6xxx graphics cards.
The best graphics card for Linux PPC is the Radeon HD 6990. I use Radeon HD 6970 graphics cards in my AmigaOnes.
Amiguy
Re: Void Linux
Post by Amiguy »
xeno74 wrote: Wed Oct 13, 2021 10:28 am The best graphics card for Linux PPC is the Radeon HD 6990. I use Radeon HD 6970 graphics cards in my AmigaOnes.
The problem is, that means you have to change cards every time you switch from Amiga to Linux and vice versa :(
Re: Void Linux
Amiguy wrote: Wed Oct 13, 2021 1:47 pm The problem is, that means you have to change cards every time you switch from Amiga to Linux and vice versa :(
I know but unfortunately there isn't a sulution for this issue available.
Re: Void Linux
xeno74 wrote: Tue Oct 12, 2021 4:26 pm
I run all the updates for Void... Now VLC does not exit immediately after pipe-viewer has evoked it but seems to load the video link and change it's window to the maximum size, but after that it exits.
There is always this error message in the terminal:
VLC media player 3.0.16 Vetinari (revision 3.0.13-8-g41878ff4f2)
libEGL warning: DRI2: failed to authenticate
LLVM ERROR: Relocation type not implemented yet!
Aborted
What does that mean? vlcrc does not have either DR12 or LLVM mentioned.
BTW, the problem with some of the VLC menus (also causing VLC to exit) is still present.
Re: Void Linux
Roland wrote: Wed Oct 13, 2021 2:49 pm There is always this error message in the terminal:
Aborted
Does hardware 3D acceleration work?
Re: Void Linux
xeno74 wrote: Wed Oct 13, 2021 2:54 pm
Aborted
No, as I have currently a R7 240 in this machine.
But I got now the streams running also via pipe-viewer! It looks like the VLC update overwrote today my customized vlcrc, so that videos did not run anymore from HD, either. So, after all the updates pipe-viewer seems to work now.
Attention:
@Amiguy
Please try to set in vlc's Video settings "Output" to "X11 video output (XBC)"
