Kernel 5.2
Re: Kernel 5.2
acefnq wrote:Christian
Sorry but I can't get any logs. Once it fails I have to reboot and remove thexorg.conf which in turn requires another reboot thus overwriting the log file we wish to access. RC6 boots fine to Firepro with logitech mouse working.
Hi Ace,
Thanks for your reply! :-) Can you switch with CTRL + ALT + F1 (F2, F3, F4 etc) to another terminal after booting with the xorg.conf?
Re: Kernel 5.2
RC6 is running fine on the AmigaOne X5000
Big picture http://www.skateman.nl/wp-content/uploa ... 204938.png
Re: Kernel 5.2
Skateman wrote:RC6 is running fine on the AmigaOne X5000
- Christian
Re: Kernel 5.2
FYI:
Christophe wrote:Le 02/07/2019 à 08:23, Christian Zigotzky a écrit :
> Hi All,
> I get the following error messages after compiling the RC7 of kernel 5.2:
> WARNING: vmlinux.o(.text+0x40e): Section mismatch in reference from the variable start_here_multiplatform to the function .init.text:.early_setup()
> The function start_here_multiplatform() references
> the function __init .early_setup().
> This is often because start_here_multiplatform lacks a __init
> annotation or the annotation of .early_setup is wrong.
Harmless warning.
Fix at https://git.kernel.org/pub/scm/linux/ke ... dc26eec86d
Will be cherry-picked by stable once merged into 4.3 I guess.
Christophe
Re: Kernel 5.2
Here is the RC7 of kernel 5.2 for the X5000 and X1000.
Download: linux-image-5.2-rc7_X1000_X5000.tar.gz
Screenshot of a Samba Active Directory Domain Controller 4.10.2 with the RC7 of kernel 5.2 on openSUSE Tumbleweed PPC64:
@SailorMH
@Allan (Ace)
Please test it with your two installed graphics cards and with your Logitech wireless USB mouse. Can you switch with CTRL-ALT-F1 (F2, F3, F4 etc) to another terminal after booting with the xorg.conf?
@Mechanic
Please test it with your JMB363 card.
Re: Kernel 5.2
Kernel 5.2 RC7 running fine on the AmigaOne X5000
Big picture http://www.skateman.nl/wp-content/uploa ... 220103.png
Sorry for the 1280x720 resolution screenshots due to a HDMI recorder between the X5K and the Monitor.
Re: Kernel 5.2
Skateman wrote:Kernel 5.2 RC7 running fine on the AmigaOne X5000
Thanks a lot for testing the RC7 and many thanks for the screenshot! :-)
Have a nice weekend!
Re: Kernel 5.2
The final kernel 5.2.0 is available. :-)
Download: linux-image-5.2-X1000_X5000.tar.gz
Thanks a lot to SailorMH and Mechanic for testing the kernels on the X1000 and many thanks to Skateman and Allan (acefnq) for testing the kernels on the X5000.
Screenshot of a Samba Active Directory Domain Controller 4.10.2 with the final kernel 5.2.0 on openSUSE Tumbleweed PPC64:
@SailorMH
Please test them with your CF cards.
@Allan (Ace)
Please test them with your two installed graphics cards and with your Logitech wireless USB mouse. Can you switch with CTRL-ALT-F1 (F2, F3, F4 etc) to another terminal after booting with the xorg.conf?
@Mechanic
Please test them with your JMB363 card.
Re: Kernel 5.2
I created a Tabor patch for the stable kernel 5.2 today. After that I compiled the stable kernel 5.2.11 for the Tabor board.
Download: linux-image-5.2.11-A1222.tar.gz
Could you also test it with all device tree blobs?
Downloads:
