openSUSE Tumbleweed
Re: openSUSE Tumbleweed
xeno74 wrote:[
Yes, you’re right because of OpenOffice. There are only debug packages of OpenOffice available. I don’t use Caja. Please try it with /usr/bin/xdg-su -c caja.
I can reboot and shutdown the X1000 with XFCE. Can you shutdown or reboot your X1000 with MATE?
No, not in the Mate not CFCE and not at login (top right) (This feature is gostet)
Caja and other programs starts as root. Thanks
Musa
musa wrote: No, not in the Mate not CFCE and not at login (top right) (This feature is gostet)
That's strange. You can also power off your X1000 with sudo systemctl poweroff.
Hi Musa,
I have a solution because of the issue with "reboot" and "poweroff".
Please open the Polkit configuration file "/etc/polkit-1/rules.d/90-default-privs.rules" as root (su).
Change the reboot and power-off entries of org.freedesktop.login1 from
[ 'auth_admin_keep', 'auth_admin_keep', 'auth_admin_keep' ],
to
[ 'yes', 'yes', 'yes' ],
I changed the following entries:
'org.freedesktop.login1.power-off':
'org.freedesktop.login1.power-off-multiple-sessions':
'org.freedesktop.login1.reboot':
'org.freedesktop.login1.reboot-multiple-sessions':
xeno74 wrote:Hi Musa,
to
Hi Christian.
Many thanks for your interest in my problem. I had discovered that when I logged in as root I had no trouble restarting or closing the computer. So I was aware that the problem was because I didn't have the right rights to that action. Your solution to the problem works. Also in the menu at the login screen.
Many thanks for your help
Peter
Hi
I have successfully compiled Worker 3.15.4
Cheers
musa wrote:Hi
Great! Well done!
musa wrote:Hi
Great! Well done!
Thanks Christian
Have a nice day
Peter
musa wrote: Thanks Christian
Have a nice day
Peter
You too! :-) I released the new stable kernel 5.1.6 yesterday. You can use it with your openSUSE if you like.
— Christian
I released a new image of openSUSE Tumbleweed 20190521 for the X5000 and X1000 today.
  • Renamed the libglamoregl.so to libglamoregl.so.bak for using openSUSE Tumbleweed 20190521-2 PPC64 with Radeon SI graphics cards
  • The issue with "reboot" and "poweroff" has been fixed through configuring /etc/polkit-1/rules.d/90-default-privs.rules
  • MATE desktop added (version 1.22.1)
  • Mesa updated to version 19.0.5
  • Samba AD-DC 4.10.2 added
Download: openSUSE_Tumbleweed_20190521-2_ppc64.img.tar.gz (3.5GB)
md5sum for the tar.gz: a81b03ef98f5e4bc11ffaa864b630028
md5sum for the uncompressed img: 9bf6cc871f6e7f793d06572c642fbf63
Users:
root (password "amigaone")
Screenshot of openSUSE Tumbleweed 20190521-2 PPC64 with MATE 1.22.1:
Old packages like SuperTuxkart 0.8.1 for openSUSE PPC64: opensuse.blizoo.mk
