Void Linux
Re: Void Linux
Amiguy wrote: Sun Oct 03, 2021 4:22 pm My server does not allow this connection.
A simple way to configure a static network configuration is to add the necessary ip commands to the "/etc/rc.local" file. With "ip a", you can figure out which name your network interface has.
For example for the network interface eth0:
ip link set dev eth0 up
ip addr add 192.168.1.2/24 brd + dev eth0
ip route add default via 192.168.1.1
After that disable the service "dhcpcd" with the command "rm /var/service/dhcpcd".
Re: Void Linux
ip addr add 192.168.1.2/24 dev eth0 should also works. I don't know if we really need brd + in the line.
Amiguy
Re: Void Linux
Post by Amiguy »
Thank you very much for your valuable advice. I managed to get the connection to work, but using enP4096p6s0 instead of the usual eth0. I love Void-Linux :D . Its setting is interesting and the possibilities seem HUGE.
Small clarification: I do not know whether "brd" is essential either. Anyway, I added it as instructed and it works fine.
It seems essential to me to specify my DNS addresses. Can you show me how to do it?
Re: Void Linux
Amiguy wrote: Sun Oct 03, 2021 6:41 pm It seems essential to me to specify my DNS addresses. Can you show me how to do it?
You can add your DNS server ip address to the file "/etc/resolv.conf".
For example:
nameserver	192.168.1.2
Amiguy
Re: Void Linux
Post by Amiguy »
Thanks Christian, it works fine ;)
Re: Void Linux
Amiguy wrote: Sun Oct 03, 2021 8:31 pm Thanks Christian, it works fine ;)
Great! :-)
Amiguy
Re: Void Linux
Post by Amiguy »
Hello Void Friends ;)
This project is really exciting. OK, software like Synaptic is missing, but xbps is a good replacement that is not difficult to drive. I was even able to install other environments. xfce is amazing and works flawlessly. For KDE (plasma X11), I do have the typical plasma reception, but I do not go beyond displaying the pointer in the dark.
On all environments, including Mate, I have no sound :cry: . My sound card (Sound Blaster Audigy Fx) is not recognized. I have installed all the ALSA resources, but nothing helps. It's amazing, because on Fienix, it worked without problem...
What could possibly be missing?
The documentation for xbps : https://docs.voidlinux.org/xbps/index.html
A very clear video about xbps : https://www.youtube.com/watch?v=44I2i1QynbM
Re: Void Linux
Amiguy wrote: Mon Oct 04, 2021 6:08 pm On all environments, including Mate, I have no sound :cry: . My sound card (Sound Blaster Audigy Fx) is not recognized. I have installed all the ALSA resources, but nothing helps.
Have you copied the kernel modules directory of your current kernel to /lib/modules yet?
Amiguy
Re: Void Linux
Post by Amiguy »
Aaaaah ! Of course, that's it ! I forgot the modules :lol: . I do see the modules for X1000, but those for X5000 are missing. I will take care of it tomorrow. Tonight, that will no longer be possible. Thank you again.
Amiguy
Re: Void Linux
Post by Amiguy »
Hello Christian,
The 5.15 modules make it possible to restore sound. Not wonder, knowing that the module of my Sound Blaster audio card is included.
However, I have a strange behaviour that I do not see on Fienix. Internet connection is extremely slow on Mate and does not work on xfce. With the same resources on Fienix, I do not encounter this problem: uImage-5.15-rc4 and uInitrd-5.5. When I use uInitrd-5.12, UBoot does not start.
For the record, my network configuration is configured in /etc/rc.local
