Kernel 5.13
Re: Kernel 5.13
I released the RC3 of kernel 5.13 for testing today.
Download: linux-image-5.13-rc3-X1000_X5000.tar.gz
Re: Kernel 5.13
RC3 up and running fine, so far.
Re: Kernel 5.13
Kernel 5.13 RC3 running fine on the AmigaOne X5000
Big picture http://www.skateman.nl/wp-content/uploa ... 103152.png
Re: Kernel 5.13
kilaueabart wrote: Mon May 24, 2021 7:36 pm RC3 up and running fine, so far.
Hi Kilaueabart,
Great that it works. Thanks a lot for testing! :-)
Skateman wrote: Tue May 25, 2021 8:34 am Kernel 5.13 RC3 running fine on the AmigaOne X5000
Many thanks for testing! :-) You helps me a lot.
Have a nice day,
Re: Kernel 5.13
KVM HV issue:
Nicholas Piggin wrote: Hmm, okay that probably rules out those notifier changes then.
Can you remind me were you able to rule these out as suspects?
8f6cc75a97d1 powerpc: move norestart trap flag to bit 0
8dc7f0229b78 powerpc: remove partial register save logic
c45ba4f44f6b powerpc: clean up do_page_fault
d738ee8d56de powerpc/64e/interrupt: handle bad_page_fault in C
ceff77efa4f8 powerpc/64e/interrupt: Use new interrupt context tracking scheme
097157e16cf8 powerpc/64e/interrupt: reconcile irq soft-mask state in C
3db8aa10de9a powerpc/64e/interrupt: NMI save irq soft-mask state in C
0c2472de23ae powerpc/64e/interrupt: use new interrupt return
dc6231821a14 powerpc/interrupt: update common interrupt code for
4228b2c3d20e powerpc/64e/interrupt: always save nvgprs on interrupt
5a5a893c4ad8 powerpc/syscall: switch user_exit_irqoff and trace_hardirqs_off order
Nick
  1. Code: Select all
    git clone git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git a
  2. Code: Select all
    git checkout 8f6cc75a97d1
    (8f6cc75a97d1 powerpc: move norestart trap flag to bit 0) Result: good
  3. Code: Select all
    git checkout 8dc7f0229b78
    (8dc7f0229b78 powerpc: remove partial register save logic) Result: good
  4. Code: Select all
    git checkout c45ba4f44f6b
    (c45ba4f44f6b powerpc: clean up do_page_fault) Result: good
  5. Code: Select all
    git checkout d738ee8d56de
    (d738ee8d56de powerpc/64e/interrupt: handle bad_page_fault in C) Result: good
  6. Code: Select all
    git checkout ceff77efa4f8
    (ceff77efa4f8 powerpc/64e/interrupt: Use new interrupt context tracking scheme) Result: good
  7. Code: Select all
    git checkout 097157e16cf8
    (097157e16cf8 powerpc/64e/interrupt: reconcile irq soft-mask state in C) Result:
    arch/powerpc/kernel/interrupt.o: In function `.syscall_exit_prepare':
    interrupt.c:(.text+0x278): undefined reference to `.schedule_user'
    arch/powerpc/kernel/interrupt.o: In function `.interrupt_exit_user_prepare':
    interrupt.c:(.text+0x340): undefined reference to `.schedule_user'
    Makefile:1199: recipe for target 'vmlinux' failed
    make: *** [vmlinux] Error 1
    Christophe Leroy wrote: Ah yes, I remember this problem.
    Can you select CONFIG_VIRT_CPU_ACCOUNTING_GEN in your configuration ?
    Otherwise, I can try to fix the branch.
    Christophe
    I selected this. After that it compiled. Result: good
  8. Code: Select all
    git checkout 3db8aa10de9a
    (3db8aa10de9a powerpc/64e/interrupt: NMI save irq soft-mask state in C) Result: good
  9. Code: Select all
    git checkout 0c2472de23ae
    (0c2472de23ae powerpc/64e/interrupt: use new interrupt return) Result: good
  10. Code: Select all
    git checkout dc6231821a14
    (dc6231821a14 powerpc/interrupt: update common interrupt code for) Result: good
  11. Code: Select all
    git checkout 4228b2c3d20e
    (4228b2c3d20e powerpc/64e/interrupt: always save nvgprs on interrupt) Result: good
  12. Code: Select all
    git checkout 5a5a893c4ad8
    (5a5a893c4ad8 powerpc/syscall: switch user_exit_irqoff and trace_hardirqs_off order) Result: good
Re: Kernel 5.13
Installed RC4 yesterday morning but probably didn't get around to rebooting and trying it out until now. Anyway, it works here. Thanks for all your work keeping things going, Christian.
Re: Kernel 5.13
kilaueabart wrote: Wed Jun 02, 2021 6:45 pm Installed RC4 yesterday morning but probably didn't get around to rebooting and trying it out until now. Anyway, it works here. Thanks for all your work keeping things going, Christian.
Re: Kernel 5.13
I tested the RC5 of kernel 5.13 today. Unfortunately the KVM HV issue still exists.
I also figured out, that '-smp 2' doesn't work either.
Summary:
-smp 1 -> works
-smp 2 -> doesn't work
-smp 3 -> works
-smp 4 -> doesn't work
Re: Kernel 5.13
I released the RC5 of kernel 5.13 for the X1000 and X5000 today.
Download: linux-image-5.13-rc5-X1000_X5000.tar.gz
