Kernel 5.13
Kernel 5.13
The Linux 5.13 merge window is open. :-) Happy testing!
Download: linux-image-5.13-alpha1-X1000_X5000.tar.gz
Re: Kernel 5.13
Hate to get my computer "-dirty" again, and 513 sounds kind of unlucky, but I'm giving it a go and so far so good.
Re: Kernel 5.13
kilaueabart wrote: Tue Apr 27, 2021 8:25 pm Hate to get my computer "-dirty" again, and 513 sounds kind of unlucky, but I'm giving it a go and so far so good.
Thank you for testing! :-)
Re: Kernel 5.13
I compiled the latest Git kernel today. Unfortunately this kernel doesn't boot on the X5000 and X1000 anymore. It boots in a virtual e5500 QEMU machine.
I bisected today.
  1. Code: Select all
    git bisect start
  2. Code: Select all
    git bisect good 9f4ad9e425a1d3b6a34617b8ea226d56a119a717
    (Good: Linux 5.12)
  3. Code: Select all
    git bisect bad 9d31d2338950293ec19d9b095fbaa9030899dcb4
    (Bad: Merge tag 'net-next-5.13' -- 2021-04-29 11:57:23)
  4. git bisect good
  5. git bisect bad
  6. git bisect bad
  7. git bisect bad
  8. git bisect bad
  9. git bisect bad
  10. git bisect bad
  11. git bisect bad
  12. git bisect bad
  13. git bisect bad
  14. git bisect good
  15. git bisect good
  16. git bisect bad
  17. git bisect bad
Result: 434fb1e7444a2efc3a4ebd950c7f771ebfcffa31 is the first bad commit.
Author: Gustavo A. R. Silva <gustavoars@kernel.org>
Date:   Wed Feb 10 17:49:27 2021 -0600
    drm/radeon/nislands_smc.h: Replace one-element array with flexible-array member in struct NISLANDS_SMC_SWSTATE
    There is a regular need in the kernel to provide a way to declare having
    a dynamically sized set of trailing elements in a structure. Kernel code
    should always use “flexible array members”[1] for these cases. The older
    style of one-element or zero-length arrays should no longer be used[2].
    Use flexible-array member in struct NISLANDS_SMC_SWSTATE, instead of
    one-element array.
    Also, this helps with the ongoing efforts to enable -Warray-bounds by
    fixing the following warnings:
    drivers/gpu/drm/radeon/ni_dpm.c: In function ‘ni_convert_power_state_to_smc’:
    drivers/gpu/drm/radeon/ni_dpm.c:2521:20: warning: array subscript 1 is above array bounds of ‘NISLANDS_SMC_HW_PERFORMANCE_LEVEL[1]’ {aka ‘struct NISLANDS_SMC_HW_PERFORMANCE_LEVEL[1]’} [-Warray-bounds]
     2521 |   smc_state->levels[i].dpm2.MaxPS =
    drivers/gpu/drm/radeon/ni_dpm.c:2523:20: warning: array subscript 1 is above array bounds of ‘NISLANDS_SMC_HW_PERFORMANCE_LEVEL[1]’ {aka ‘struct NISLANDS_SMC_HW_PERFORMANCE_LEVEL[1]’} [-Warray-bounds]
     2523 |   smc_state->levels[i].dpm2.NearTDPDec = NISLANDS_DPM2_NEAR_TDP_DEC;
    drivers/gpu/drm/radeon/ni_dpm.c:2524:20: warning: array subscript 1 is above array bounds of ‘NISLANDS_SMC_HW_PERFORMANCE_LEVEL[1]’ {aka ‘struct NISLANDS_SMC_HW_PERFORMANCE_LEVEL[1]’} [-Warray-bounds]
     2524 |   smc_state->levels[i].dpm2.AboveSafeInc = NISLANDS_DPM2_ABOVE_SAFE_INC;
    drivers/gpu/drm/radeon/ni_dpm.c:2525:20: warning: array subscript 1 is above array bounds of ‘NISLANDS_SMC_HW_PERFORMANCE_LEVEL[1]’ {aka ‘struct NISLANDS_SMC_HW_PERFORMANCE_LEVEL[1]’} [-Warray-bounds]
     2525 |   smc_state->levels[i].dpm2.BelowSafeInc = NISLANDS_DPM2_BELOW_SAFE_INC;
    drivers/gpu/drm/radeon/ni_dpm.c:2526:35: warning: array subscript 1 is above array bounds of ‘NISLANDS_SMC_HW_PERFORMANCE_LEVEL[1]’ {aka ‘struct NISLANDS_SMC_HW_PERFORMANCE_LEVEL[1]’} [-Warray-bounds]
     2526 |   smc_state->levels[i].stateFlags |=
     2527 |    ((i != (state->performance_level_count - 1)) && power_boost_limit) ?
     2528 |    PPSMC_STATEFLAG_POWERBOOST : 0;
    drivers/gpu/drm/radeon/ni_dpm.c:2442:20: warning: array subscript 1 is above array bounds of ‘NISLANDS_SMC_HW_PERFORMANCE_LEVEL[1]’ {aka ‘struct NISLANDS_SMC_HW_PERFORMANCE_LEVEL[1]’} [-Warray-bounds]
     2442 |   smc_state->levels[i + 1].aT = cpu_to_be32(a_t);
    [1] https://en.wikipedia.org/wiki/Flexible_array_member
    [2] https://www.kernel.org/doc/html/v5.9/process/deprecated.html#zero-length-and-one-element-arrays
    Link: https://github.com/KSPP/linux/issues/79
    Link: https://github.com/KSPP/linux/issues/109
    Build-tested-by: kernel test robot <lkp@intel.com>
    Link: https://lore.kernel.org/lkml/6023ed54.BfIY+9Uz81I6nq19%25lkp@intel.com/
    Signed-off-by: Gustavo A. R. Silva <gustavoars@kernel.org>
    Signed-off-by: Alex Deucher <alexander.deucher@amd.com>
:040000 040000 825941c1622038715917db88900263261697ff43 44e16f7b0c4f28a6ca1fb7cc71a6d6a7a9db668f M	drivers
git revert 434fb1e7444a2efc3a4ebd950c7f771ebfcffa31
Output:
[master 437344379819] Revert "drm/radeon/nislands_smc.h: Replace one-element array with flexible-array member in struct NISLANDS_SMC_SWSTATE"
 1 file changed, 5 insertions(+), 5 deletions(-)
After a new compiling, the kernel boots without any problems.
I created a patch for reverting the bad commit:
diff -rupN a/drivers/gpu/drm/radeon/nislands_smc.h b/drivers/gpu/drm/radeon/nislands_smc.h
--- a/drivers/gpu/drm/radeon/nislands_smc.h     2021-04-30 12:53:11.426435827 +0200
+++ b/drivers/gpu/drm/radeon/nislands_smc.h     2021-04-30 12:52:35.298525162 +0200
@@ -134,11 +134,11 @@ typedef struct NISLANDS_SMC_HW_PERFORMAN
-       uint8_t                             flags;
-       uint8_t                             levelCount;
-       uint8_t                             padding2;
-       uint8_t                             padding3;
-       NISLANDS_SMC_HW_PERFORMANCE_LEVEL   levels[];
+    uint8_t                             flags;
+    uint8_t                             levelCount;
+    uint8_t                             padding2;
+    uint8_t                             padding3;
+    NISLANDS_SMC_HW_PERFORMANCE_LEVEL   levels[1];
 typedef struct NISLANDS_SMC_SWSTATE NISLANDS_SMC_SWSTATE;
The kernel compiles and boots with this patch on my X1000 and X5000.
Re: Kernel 5.13
The same commit is also available for SI graphics cards.
Linux Git
Please also test the alpha2 with Radeon SI graphics cards. It could be, that your AmigaOne doesn't boot. I only patched the alpha2 for NI Radeons.
Re: Kernel 5.13
I think maybe I have an SI card, but too senile to remember for sure, or how to find out. In any event, 5.13-a2 seems to be working as it should.
Re: Kernel 5.13
kilaueabart wrote: Fri Apr 30, 2021 7:35 pm I think maybe I have an SI card, but too senile to remember for sure, or how to find out. In any event, 5.13-a2 seems to be working as it should.
Thanks a lot for testing the alpha2! You can figure out your graphics card with lspci.
@Skateman
Does the alpha2 boots on your X5000?
Re: Kernel 5.13
5.13a2 boots and runs fine for me.
Re: Kernel 5.13
acefnq wrote: Sat May 01, 2021 4:54 pm 5.13a2 boots and runs fine for me.
Hi Ace,
Great! Thank you for testing! :-) Which graphics card is installed in your X5000?
