Qemu
Re: Qemu
Lubuntu 14.04 in a virtual QEMU PowerPC machine with KVM-PR:
qemu-system-ppc -M mac99 -enable-kvm -m 2047 -boot c -hda Lubuntu_14.04_PowerPC_QEMU.img -g 1280x1024x32 -kernel vmlinux -initrd initrd -append "ro root=/dev/sda3" -device usb-mouse -nic user,model=e1000
Re: Qemu
Lubuntu 14.04 in a virtual G3 Beige QEMU machine with KVM-PR:
QEMU command:
qemu-system-ppc -M g3beige -enable-kvm -m 2047 -bios /home/amigaone/Lubuntu_14.04_PowerPC_QEMU/openbios-ppc -boot c -hda /home/amigaone/Lubuntu_14.04_PowerPC_QEMU/Lubuntu_14.04_PowerPC_QEMU.img -g 1280x1024x32 -kernel /home/amigaone/Lubuntu_14.04_PowerPC_QEMU/vmlinux -initrd /home/amigaone/Lubuntu_14.04_PowerPC_QEMU/initrd -append "ro root=/dev/sda3" -device pci-ohci,id=newusb -device usb-tablet -nic user,model=e1000
Re: Qemu
Usually we use a VirtIO GPU for our QEMU machines. (-device virtio-gpu-pci)
There is another possibility.
The Bochs VGA.
QEMU argument: -device VGA,vgamem_mb=256
Please note: If you want to use a higher resolution then please delete the xorg conf file with the fbdev entry and login again.
Re: Qemu
If you have wrong colors in the virtual display then try -display sdl.
Re: Qemu
Adding an IDE drive:
-drive id=disk,file=disk.qcow2,format=qcow2,if=none -device ahci,id=ahci -device ide-cf,drive=disk,bus=ahci.0
Hypex
Re: Qemu
Post by Hypex »
Can it boot a ppc64le Linux image? :P
Re: Qemu
Hypex wrote: Fri Aug 11, 2023 9:13 pm Can it boot a ppc64le Linux image? :P
I haven’t tested it yet.
Hypex
Re: Qemu
Post by Hypex »
Want to try one of these ppc64el images with my loader. But I need to add a LE ELF loader to do that. Could cheat and see if enabling LE in MSR before and after loading works but that seems dirty. By the looks of it the kernel brings up in BE mode. deals with the device tree, then starts and switches endian to LE when it really starts. I'll test a standard image and if it loads (then crashes eventually) I'll look into compiling an LE kernel. :D
Re: Qemu
Convert an img to a vmdk for VMware:
qemu-img convert fienix_6.0.1-noboot-r1.img -O vmdk fienix_6.0.1-noboot-r1.vmdk
