Kernel 5.10
Re: Kernel 5.10
Kernel 5.10 RC3 running fine on the AmigaOne X5000
Big picture http://www.skateman.nl/wp-content/uploa ... 175009.png
Re: Kernel 5.10
Skateman wrote: Mon Nov 09, 2020 4:54 pm Kernel 5.10 RC3 running fine on the AmigaOne X5000
Thanks a lot for testing the RC3! I was curious because of the latest DPAA updates but they seem to work on your X5000. :-)
Re: Kernel 5.10
The DPAA Network adapter has been working great!
I think that Kilaueabart has been also using his DPAA adapter for quite some time now.
All fine, i am happy!
skateman@X5000LNX:~$ dmesg | grep dpaa
[ 6.678373] fsl_dpaa_mac ffe4e6000.ethernet: FMan dTSEC version: 0x08240101
[ 6.684396] fsl_dpaa_mac ffe4e6000.ethernet: FMan MAC address: 00:04:a3:6b:41:7c
[ 6.690752] fsl_dpaa_mac ffe4e8000.ethernet: FMan dTSEC version: 0x08240101
[ 6.696746] fsl_dpaa_mac ffe4e8000.ethernet: FMan MAC address: 00:1e:c0:f8:31:b5
[ 6.703207] fsl_dpaa_mac ffe4f0000.ethernet: of_get_mac_address(/soc@ffe000000/fman@400000/ethernet@f0000) failed
[ 6.712415] fsl_dpaa_mac ffe4f0000.ethernet: of_get_phy_mode() for /soc@ffe000000/fman@400000/ethernet@f0000 failed. Defaulting to SGMII
[ 6.723580] fsl_dpaa_mac: 10G MAC driver only support 10G speed
[ 6.728305] fsl_dpaa_mac ffe4f0000.ethernet: mac_dev->init() = -22
[ 6.733293] fsl_dpaa_mac: probe of ffe4f0000.ethernet failed with error -22
[ 6.745214] fsl_dpaa_mac ffe4e6000.ethernet eth0: Probed interface eth0
[ 6.756691] fsl_dpaa_mac ffe4e8000.ethernet eth1: Probed interface eth1
It would be nice if it stopped looking for a device at ffe4f0000,,,?? not sure where or why this get triggered...
Re: Kernel 5.10
RC3 working here, too.
As for DPAA, it works fine as far as I can tell. Dmesg greps mine a bit different to Skateman's.
fienix@Fienix:~$ dmesg | grep dpaa
[    4.701436] fsl_dpaa_mac ffe4e6000.ethernet: of_get_mac_address(/soc@ffe000000/fman@400000/ethernet@e6000) failed
[    4.701743] fsl_dpaa_mac ffe4e6000.ethernet: FMan dTSEC version: 0x08240101
[    4.702234] fsl_dpaa_mac ffe4e8000.ethernet: of_get_mac_address(/soc@ffe000000/fman@400000/ethernet@e8000) failed
[    4.702483] fsl_dpaa_mac ffe4e8000.ethernet: FMan dTSEC version: 0x08240101
[    4.702988] fsl_dpaa_mac ffe4f0000.ethernet: of_get_mac_address(/soc@ffe000000/fman@400000/ethernet@f0000) failed
[    4.703211] fsl_dpaa_mac ffe4f0000.ethernet: of_get_phy_mode() for /soc@ffe000000/fman@400000/ethernet@f0000 failed. Defaulting to SGMII
[    4.703442] fsl_dpaa_mac: 10G MAC driver only support 10G speed
[    4.703541] fsl_dpaa_mac ffe4f0000.ethernet: mac_dev->init() = -22
[    4.703654] fsl_dpaa_mac: probe of ffe4f0000.ethernet failed with error -22
[    4.705399] fsl_dpaa_mac ffe4e6000.ethernet: Using random MAC address: 32:bd:c3:b1:21:e2
[    4.706482] fsl_dpaa_mac ffe4e6000.ethernet eth0: Probed interface eth0
[    4.708328] fsl_dpaa_mac ffe4e8000.ethernet: Using random MAC address: 3e:a4:c4:44:14:82
[    4.709590] fsl_dpaa_mac ffe4e8000.ethernet eth1: Probed interface eth1
fienix@Fienix:~$
Maybe Fienix vs. Ubuntu? I'll try it in Ubuntu the next time I get there.
Re: Kernel 5.10
Hi kilaueabart,
My guess is that you are using an older version of U-boot that cant read the MAC addressess of your onboard ethernet adapter.
That i think is why Linux is defaulting to a random MAC address as it shows: Using random MAC address: 32:bd:c3:b1:21:e2
You can check you systeminfo in U-boot and see if there are Mac addresses shown.
It not a big issues since your network adapter is working after all. :-)
Re: Kernel 5.10
RC3 working fine on my X5000.
Re: Kernel 5.10
kilaueabart wrote: Mon Nov 09, 2020 8:44 pm RC3 working here, too. As for DPAA, it works fine as far as I can tell. Dmesg greps mine a bit different to Skateman's.
acefnq wrote: Tue Nov 10, 2020 3:02 pm Christian
Many thanks for testing! :-)
Re: Kernel 5.10
I successfully tested the RC3 of kernel 5.10 on my X5000/20 with a MorphOS compatible hardware configuration today.
- A-EON AmigaOne X5000/20
- ATi Radeon X1950 PRO Extreme
- Creative Soundblaster LIVE Player 1024
- DPAA onboard ethernet
Screenshot:
The onboard ethernet still needs the unplug/replug trick.
If I don't replug the network cable then "nmcli dev status" reports:
DEVICE TYPE STATE CONNECTION
eth0 ethernet unavailable --
eth1 ethernet unavailable --
@Skateman
I have the same "dmesg | grep dpaa" output like you.
Re: Kernel 5.10
I think that you are still using an internal PCI ethernet adapter as well.
Maybe this PCI card is seen as the Default ethernet adapter and the network managers starts with this card enabled..
kilaueabart and I dont have any internal PCI adapters in use if i recall correctly.
What if you got rid of the PCI ethernet adapter, Reboot the machine at least twice.?
Re: Kernel 5.10
Skateman wrote: Tue Nov 10, 2020 6:42 pm I think that you are still using an internal PCI ethernet adapter as well.
I have had this unplug/replug issue from the beginning, but removing the PCI ethernet adapter did _not_ solve the problem.
