Mesa & DRI for PPC
Re: Mesa & DRI for PPC
I compiled Mesa 18.1.2 in a virtual e5500 QEMU PPC64 machine today.
Download: mesa-18.1.2-linux-powerpc.tar.gz
PLEASE test it.
xeno74 wrote:Hi All,
PLEASE test it.
Installed and working fine with thanks
Allan
acefnq wrote: Installed and working fine with thanks
Allan
Hi Allan,
Many thanks for testing Mesa 18.1.2! I compiled it on ubuntu MATE 16.04 PowerPC yesterday. I think the problem with Casey’s Mesa is that he compiled it on a new Debian version and therefore it needs new libs which don’t exist on old Ubuntu versions.
Allan
Hi Allan,
I just appreciate all the work you guys put in for us mere users. It really has up the value I get out of my investment in my X5000.
Allan
Mesa 18.2.2 is available. :-)
Installation instructions:
  1. Code: Select all
    sudo cp -R mesa-18.2.2 /usr/local/
  2. Code: Select all
    sudo mv /usr/lib/powerpc-linux-gnu/dri/r600_dri.so /usr/lib/powerpc-linux-gnu/dri/r600_dri.so.bak
  3. Code: Select all
    sudo mv /usr/lib/powerpc-linux-gnu/mesa/libGL.so.1.2.0 /usr/lib/powerpc-linux-gnu/mesa/libGL.so.1.2.0.bak
  4. Code: Select all
    sudo cp /usr/local/mesa-18.2.2/lib/dri/r600_dri.so /usr/lib/powerpc-linux-gnu/dri/
  5. Code: Select all
    sudo cp /usr/local/mesa-18.2.2/lib/libGL.so.1.2.0 /usr/lib/powerpc-linux-gnu/mesa/
PLEASE test it.
I released the new Mesa 19.0.0 today. :-)
Installation instructions for Ubuntu:
  1. Code: Select all
    sudo cp -R mesa-19.0.0 /usr/local/
  2. Code: Select all
  3. Code: Select all
  4. Code: Select all
    sudo cp /usr/local/mesa-19.0.0/lib/dri/r600_dri.so /usr/lib/powerpc-linux-gnu/dri/
  5. Code: Select all
    sudo cp /usr/local/mesa-19.0.0/lib/libGL.so.1.2.0 /usr/lib/powerpc-linux-gnu/mesa/
Installation instructions for Fienix:
  1. Code: Select all
    su
  2. Code: Select all
  3. Code: Select all
  4. Code: Select all
    mv /usr/lib/powerpc-linux-gnu/libGL.so.1.7.0 /usr/lib/powerpc-linux-gnu/libGL.so.1.7.0.bak
  5. Code: Select all
  6. Code: Select all
  7. Code: Select all
    rm /usr/lib/powerpc-linux-gnu/libGL.so.1
  8. Code: Select all
    cd /usr/lib/powerpc-linux-gnu/
  9. Code: Select all
    ln -s libGL.so.1.2.0 libGL.so.1
Fienix result:
lrwxrwxrwx 1 root root      14 Mar 16 00:38 libGL.so.1 -> libGL.so.1.2.0
-rwxr-xr-x 1 root root 2978108 Mar 16 00:33 libGL.so.1.2.0
-rw-r--r-- 1 root root  853552 Aug 10  2018 libGL.so.1.7.0.bak
PLEASE test it.
Googling Mesa-18.1.2 and reading about your compilation for X5000 Linux gives me no hint at whether it does anything I would notice, or even if it would run on the machine I have. Could you give a hint?
Installed and working well on 16.04.6 with 2 cards in (using your older 5RC with no DRM).
Cheers
acefnq wrote:Christian
Cheers
Ace,
Many thanks for testing! :-)
@Kilaueabart
Do you mean improvements?
acefnq wrote: @Kilaueabart
No, I'm just wondering what it does, and if it sounds like something I could use, would I have to make any changes to my machine to use it.
Since I never do anything with graphics beyond what I can do with Scribus, I'm guessing it would be useless to me, but I couldn't help wondering.
