openSUSE Tumbleweed
Re: openSUSE Tumbleweed
There where a very big update to Open Suse (1564 files)
musa wrote:There where a very big update to Open Suse (1564 files)
Impressive! Did you update it?
yes but say no to the new mesa testing package.
I was hoping there was a solution to that firefox is unstable (segmentation fault)
but it was not this time.
If you want to see the splash screen then add splash=silent to the boot arguments.
If the automatic network configuration of openSUSE doesn't work then it is possible to configure the network manually.
Configuration instructions:
  1. Please check your IP configuration with the following command:
    # ip a
  2. If your network interface doesn't have an ip address, please configure it with the following command:
    # ip a add --your new ip address--/--subnet mask-- dev --network interface--
    For example:
    # ip a add 192.168.1.140/24 dev enP4096p4s4
  3. Activate the network interface with:
    # ip link set --network interface-- up
    For example:
    ip link set enP4096p4s4 up
  4. Please check the result with:
    # ip a show --network interface--
    For example:
    # ip a show enP4096p4s4
  5. After that please add the default gateway with the following command:
    # ip route add default via --ip address of your router--
    For example:
    # ip route add default via 192.168.1.1
  6. Please add a DNS server to the config file /etc/resolv.conf.
    /etc/resolv.conf:
    nameserver --ip address of your router--
    For example:
    nameserver 192.168.1.1
  7. Please test the internet connection with a web browser.
I created with dd an img of my openSUSE Tumbleweed 20170924 PPC64 installation today.
Be aware, that openSUSE is experimental and isn't supported. openSUSE Tumbleweed is alpha software! It's only for testing and tinkering!
Download: openSUSE_Tumbleweed_20170924_ppc64.img.tar.gz
Users:
root (password "amigaone")
openSUSE Tumbleweed 20170924 PPC64 on an AmigaOne X5000:
openSUSE Tumbleweed 20170924 PPC64 on an AmigaOne X1000:
Have a lot of fun with openSUSE Tumbleweed! :-)
I have recently released an update of the openSUSE Tumbleweed 20170924 PPC64 img.
  • Network configuration issue solved
  • YaST updated
Download: openSUSE_Tumbleweed_20170924-2_ppc64.img.tar.gz
SSH ACCESS
If you can't login to openSUSE Tumbleweed via SSH then deactivate the line PasswordAuthentication no with a hashtag (#) in the config file /etc/ssh/sshd_config. After that please restart the sshd service with rcsshd restart.
openSUSE Tumbleweed 20170924 PowerPC64 with a virtual S.u.S.E. Linux 5.0 x86 machine on an AmigaOne X5000. FVWM2 from 1997 and from 2017 together.
Hi Christian
Has some issues with repositories in opensuse tumbleweed.
I use these
http://download.opensuse.org/ports/ppc/ ... d/repo/oss
http://download.opensuse.org/ports/ppc/ ... po/non-oss
http://download.opensuse.org/ports/ppc/ ... repo/debug
but I get an error saying: can not resolve host download.opensuse.org
thanks
