Mesa & DRI for PPC
caseycullen
Re: Mesa & DRI for PPC
Post by caseycullen »
Are you using Ubuntu, Debian, or Christian’s release of MATE PowerPC Remix?
acefnq wrote:Hi Casey
Tried to install using Xeno's instructions but no luck. Stuck on 18.0.0 (obviously changed files to copy in his instructions). Any ideas of what I might be doing wrong?
Cheers
Allan
caseycullen wrote:Are you using Ubuntu, Debian, or Christian’s release of MATE PowerPC Remix?
Cheers
Allan
Ubuntu 16.04, I updated to 18.0.0 ok a while back and again followed those instructions with no luck.
Cheers
Allan
Allan,
Please post the output of ls -l /usr/lib/powerpc-linux-gnu/mesa/.
caseycullen
I think there is a problem with the download. I'll fix it this afternoon.
---Casey
acefnq wrote:Ubuntu 16.04, I updated to 18.0.0 ok a while back and again followed those instructions with no luck.
Cheers
Allan
caseycullen
My apologies! I uploaded the incorrect files, please try again.
http://ppcutopia.ddns.net/html/mesa-18.1.1.tar.gz
---Casey
caseycullen wrote:My apologies! I uploaded the incorrect files, please try again.
---Casey
Casey
No need to apologise, your theone doing the hard lifting here. I re-downloaded and copied over using Xeno's instructions, of course using 18.1.1, no go. All appears to copy ok but I get this output;
allan@ubuntu-mate:~$ glxinfo | grep "OpenGL version"
libGL error: unable to load driver: r600_dri.so
libGL error: driver pointer missing
libGL error: failed to load driver: r600
libGL error: unable to load driver: swrast_dri.so
libGL error: failed to load driver: swrast
X Error of failed request: GLXBadContext
Major opcode of failed request: 155 (GLX)
Minor opcode of failed request: 6 (X_GLXIsDirect)
Serial number of failed request: 49
Current serial number in output stream: 48
I then backtracked to 18.0.0rc4 worked fine. then 18.0.0 works fine I the tried your 18.03 once again no luck with similar or same output as above. Hope this helps.
Allan
Hi Casey,
Did you compile your Mesa versions on Debian PPC64?
caseycullen
No; 32-bit Debian.
Allan could you please post the output of
Christian have you tried to upgrade from the Mesa I compiled?
xeno74 wrote:Hi Casey,
caseycullen wrote:No; 32-bit Debian.
Hi Casey,
No, I haven’t upgraded it yet because I don’t have any AmigaOnes here (business trip). Currently, I cross compile the kernels on my PC and test them in virtual QEMU machines. If you compile Mesa on a new Debian version then it could be that it doesn’t work on ubuntu MATE 16.04 LTS.
[quote="caseycullen"]No; 32-bit Debian.
Casey
I have reverted back to 18.0.0. Do you want me to try again to get the output?
Cheers
Allan
