Mesa for Linux PPC
Re: Mesa for Linux PPC
I compiled Mesa 17.2.1 for the MATE PowerPC Remix 2017 today.
Download: MesaLib-17.2.1-1-without-llvm-powerpc-unofficial.tar.bz2
Installation instructions:
  1. Code: Select all
    sudo mv /usr/lib/powerpc-linux-gnu/dri/r600_dri.so /usr/lib/powerpc-linux-gnu/dri/r600_dri.so.bak
  2. Code: Select all
    sudo mv /usr/lib/powerpc-linux-gnu/mesa/libGL.so.1.2.0 /usr/lib/powerpc-linux-gnu/mesa/libGL.so.1.2.0.bak
  3. Code: Select all
    sudo cp /usr/local/mesa-17.2.1-without-llvm/lib/dri/r600_dri.so /usr/lib/powerpc-linux-gnu/dri/
  4. Code: Select all
    sudo cp /usr/local/mesa-17.2.1-without-llvm/lib/libGL.so.1.2.0 /usr/lib/powerpc-linux-gnu/mesa/
I successfully tested it on my X5000 and X1000.
Good news for our NI graphics cards.
Link: R600 Gallium3D Gets Some Last Minute Improvements In Mesa 18.0
I released the RC4 of Mesa 18.0.0 for testing today.
Download: mesa-18.0.0-rc4-linux-powerpc.tar.gz
  1. Code: Select all
    sudo cp -R mesa-18.0.0-rc4 /usr/local/
  2. Code: Select all
  3. Code: Select all
  4. Code: Select all
    sudo cp /usr/local/mesa-18.0.0-rc4/lib/dri/r600_dri.so /usr/lib/powerpc-linux-gnu/dri/
  5. Code: Select all
    sudo cp /usr/local/mesa-18.0.0-rc4/lib/libGL.so.1.2.0 /usr/lib/powerpc-linux-gnu/mesa/
I successfully tested it with the MATE PowerPC Remix (X1000) and with ubuntu MATE 16.04.3 LTS PowerPC (X5000) today.
The MATE PowerPC Remix 2017 with the RC4 of Mesa 18.0.0 on an AmigaOne X1000 with a Radeon HD6870:
ubuntu MATE 16.04.3 LTS PowerPC with the RC4 of Mesa 18.0.0 on an AmigaOne X5000 with a Radeon HD4870:
I compiled the final version of Mesa 18.0.0 today.
Build instructions:
./configure --prefix /usr/local/mesa-18.0.0 --with-gallium-drivers="r600,swrast" --enable-texture-float --enable-dri3
Output:
        prefix:          /usr/local/mesa-18.0.0
        exec_prefix:     ${prefix}
        libdir:          ${exec_prefix}/lib
        includedir:      ${prefix}/include
        OpenGL:          yes (ES1: yes ES2: yes)
        OSMesa:          no
        DRI platform:    drm
        DRI drivers:     r200 radeon swrast
        DRI driver dir:  ${libdir}/dri
        GLX:             DRI-based
        EGL:             yes
        EGL drivers:     builtin:egl_dri2 builtin:egl_dri3
        GBM:             yes
        EGL/Vulkan/VL platforms:   x11 surfaceless drm
        Vulkan drivers:  no
        llvm:            no
        Gallium drivers: r600 swrast
        Gallium st:      mesa
        HUD extra stats: no
        HUD lmsensors:   no
        Shared libs:     yes
        Static libs:     no
        Shared-glapi:    yes
        CFLAGS:          -g -O2 -Wall -Werror=implicit-function-declaration -Werror=missing-prototypes -Wmissing-prototypes -fno-math-errno -fno-trapping-math -std=c99
        CXXFLAGS:        -g -O2 -Wall -fno-math-errno -fno-trapping-math
        CXX11_CXXFLAGS:  -std=c++11
        LDFLAGS:
        Macros:          -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D__STDC_LIMIT_MACROS -D_GNU_SOURCE -DUSE_GCC_ATOMIC_BUILTINS -DMISSING_64BIT_ATOMICS -DNDEBUG -DTEXTURE_FLOAT_ENABLED -DHAVE_XLOCALE_H -DHAVE_SYS_SYSCTL_H -DHAVE_STRTOF -DHAVE_MKOSTEMP -DHAVE_TIMESPEC_GET -DHAVE_STRTOD_L -DHAVE_DL_ITERATE_PHDR -DHAVE_POSIX_MEMALIGN -DHAVE_ZLIB -DHAVE_LINUX_FUTEX_H -DHAVE_LIBDRM -DGLX_USE_DRM -DGLX_INDIRECT_RENDERING -DGLX_DIRECT_RENDERING -DGLX_USE_TLS -DHAVE_X11_PLATFORM -DHAVE_SURFACELESS_PLATFORM -DHAVE_DRM_PLATFORM -DHAVE_DRI3 -DENABLE_SHADER_CACHE -DHAVE_MINCORE
        PYTHON2:         python2.7
        Run 'make' to build Mesa
make
# make install
or
sudo make install
export LD_LIBRARY_PATH=/usr/local/mesa-18.0.0/lib/
glxinfo | grep -i opengl
LIBGL_DEBUG=verbose vblank_mode=0 glxgears
Download: mesa-18.0.0-linux-powerpc.tar.gz
  1. Code: Select all
    sudo cp -R mesa-18.0.0 /usr/local/
  2. Code: Select all
  3. Code: Select all
  4. Code: Select all
    sudo cp /usr/local/mesa-18.0.0/lib/dri/r600_dri.so /usr/lib/powerpc-linux-gnu/dri/
  5. Code: Select all
    sudo cp /usr/local/mesa-18.0.0/lib/libGL.so.1.2.0 /usr/lib/powerpc-linux-gnu/mesa/
Screenshot:
vox
Re: Mesa 9.2.2-1 and 10.0.0-1
Post by vox »
xeno74 wrote:Mesa unofficial 10.0.4 is available.
Download: MesaLib-10.0.4-powerpc-unofficial.tar.bz2
Does this resolve colour problem and 3D Gnome under PPC Linuxes on x1000?
I compiled Mesa 18.1.2 in a virtual e5500 QEMU PPC64 machine today.
Download: mesa-18.1.2-linux-powerpc.tar.gz
PLEASE test it.
seventhwonder
Post by seventhwonder »
@all
Are we in the same position regarding RadeonSI support on Linux PPC64 ?
AmigaOS4 Beta-Tester
seventhwonder wrote:@all
Yes, that's correct.
